Hi
I am trying to run a script that uses beautiful soup, but I get error 'no module named bs4'
First line of code is:
From bs4 import Beautifulsoup
Python version is 2.7.13
OS: raspbian
I installed beautiful with:
Pip install beautifulsoup4
Pip install bs4
Does it make a difference what path I run the above. Have tried in same folder as python and where my script is.
Also tried a few other things I have seen online but nothing seems to work.
Can anybody help or point me in the right direction.
- DougieLawson
Re: No module named bs4
Why are you using python2, it's a much better idea to use python3 for everything.
To install BS4 use sudo pip install beautifulsoup4; sudo pip3 install beautifulsoup4 to get it for both python versions.
Thanks for the reply
I have also tried using pip3, and i still got same error. I am using python 2 as it came with raspbian os. Is there and easy way of upgrading this?
- DougieLawson
BOTH python2 (aka python) and python3 are installed with Raspbian Stretch.
Run python 3.6 programs with the python3 command.
I think I have installed an older version raspbian. I will try with stretch.
Make sure you install modules globally using 'sudo pip' or 'sudo pip3'.
In general you should not use 'sudo' to start your scripts.
