pcdimoticanerd33
Wifi 5GHz not working
Sun Dec 16, 2018 9:09 am
hello everyone i have problem i can not connect 5GHz wifi to raspberry pi knows someone how this is coming
Last edited by pcdimoticanerd33 on Mon Dec 17, 2018 7:40 am, edited 2 times in total.
Re: Wifi 5G
Sun Dec 16, 2018 10:06 am
Make sure you have set the correct country code using raspi configuration.
pcdimoticanerd33
Re: Wifi 5G
Sun Dec 16, 2018 10:26 am
that's okay on BE wants to work only on 2.4GHz and not on 5GHz or sometimes have to adjust something
Re: Wifi 5G
Sun Dec 16, 2018 11:46 am
It's almost always due to having a badly or unset country code....that is definitely set?
pcdimoticanerd33
Re: Wifi 5G
Sun Dec 16, 2018 12:30 pm
This is my /etc/wpa_supplicant/wpa_supplicant.conf
ctrl_interface = DIR = / var / run / wpa_supplicant GROUP = netdev
update_config = 1
country = BE
network = {
         ssid = "ASUS_5G_Guest2"
         psk = "password"
         pid_str = "Guest"
DarkPlatinum
Contact: YouTube
Re: Wifi 5G
Sun Dec 16, 2018 1:22 pm
Are you using raspbian lite? if not, you can usually see which wifi signals are 5G from the internet menu on the desktop.
bensimmo
Re: Wifi 5G
Sun Dec 16, 2018 2:10 pm
update_config = 1
country = BE
network = {
         psk = "password"
         pid_str = "Guest"
try
ctrl_interface=/var/run/wpa_supplicant  GROUP = netdev
update_config=1
country=BE
network={
	ssid="ASUS_5G_Guest2"
	psk="password"
	key_mgmt=WPA-PSK
if you do need to use pid_str, it should be id_str with no 'p'. It's also not needed for normal use.
n67
Re: Wifi 5G
Sun Dec 16, 2018 3:01 pm
There are (at least) two possible interpretations of what OP means by "Wifi 5G".
I assumed he meant the upcoming new standard (we have 3G, and 4G. 5G is just around the corner!)
Everyone else seems to have assumed he meant 5Ghz.
"L'enfer, c'est les autres"
G fytc hsqr rum umpbq rm qyw rm rfc kmbq md rfgq dmpsk:
Epmu Sn!
J lnacjrw njbruh-carppnanm vxm rb mnuncrwp vh yxbcb!
Re: Wifi 5G
Sun Dec 16, 2018 3:24 pm
It seems pretty obvious to me. The clue is "WiFi". The other "5G" is mobile internet, not WiFi.
drgeoff
Re: Wifi 5G
Sun Dec 16, 2018 3:38 pm
+1
Also mentions of country code BE and the OP writing "only on 2.4GHz and not on 5GHz" in one of his posts.
n67
Re: Wifi 5G
Sun Dec 16, 2018 3:59 pm
hello everyone i have problem i can not connect 5G wifi to raspberry pi knows someone how this is coming
I don't see any references to 2.4Ghz or 5Ghz in the above text. Maybe I need glasses...
Epmu Sn!
bensimmo
Re: Wifi 5G
Sun Dec 16, 2018 4:22 pm
his second post gives a clue. viewtopic.php?f=63&t=229082&p=1404829#p1404746
But WiFi, as mentioned, is the big giveaway. 5G mobile is pretty rare and I've not seen many 5G pitches.
none of this is helping him though.
drgeoff
Re: Wifi 5G
Sun Dec 16, 2018 4:53 pm
@n67
See the third post in this thread. Which was almost 5 hours before your suggestion of mobile.
pcdimoticanerd33
Re: Wifi 5GHz
Mon Dec 17, 2018 7:34 am
Sorry maybe a bit confusing it is 5GHz not 5g for mobile
my /etc/wpa_supplicant/wpa_supplicant.conf is now
ctrl_interface = / var / run / wpa_supplicant GROUP = netdev
update_config = 1
country = BE
network = {
         ssid = "ASUS_5G_Gues1"
         psk = "password"
         key_mgmt = WPA2-PSK
[moderator added code tags]
bensimmo
Re: Wifi 5GHz not working
Mon Dec 17, 2018 7:54 am
When you are posting, you'll see a row of tools above the box, one of them says Code, this lets you post you text as you type it (it's what I used above)
It should save you having to edit and add all the spaces etc.
I've also thought of a question.
Which Pi model is it?
Only the 3B+ and 3A+ models have the 5GHz band.
pcdimoticanerd33
Mon Dec 17, 2018 7:59 am
Mijn model is 3B+
how can you give static ip address to wlan0 and eth0
Yours sincerely
Will5455
Mon Dec 17, 2018 12:58 pm
but my rpi3 model b connected to my 5ghz band no questions asked? :?
I do strange things and am sometimes the techhead stereotype.
deal with it!
pcdimoticanerd33
Mon Dec 17, 2018 2:22 pm
what have you done in interfaces and wpa_supplicant.conf
HawaiianPi
Re: Wifi 5GHz
Mon Dec 17, 2018 5:35 pm
Not possible. The 3B does not support 5GHz.
update_config = 1
country = BE
network = {
         psk = "password"
         key_mgmt = WPA2-PSK
You have a lot of extra spaces in there. The wpa_supplicaqnt.conf file should look like this:
update_config=1
country=GB
network={
	ssid="Your network SSID"
	psk="Your WPA/WPA2 security key"
	key_mgmt=WPA-PSK
pcdimoticanerd33
Mon Dec 17, 2018 6:00 pm
it is the model 3 Model B +
DarkPlatinum
Contact: YouTube
Mon Dec 17, 2018 7:21 pm
You should have stated this. I think most of us assumed that you used a 5GHz wifi dongle. Have you tried what I told you to do? Going on Raspbian Desktop and using the wifi settings to connect to 5GHz wifi?
We can't help you if you don't want to listen.
bensimmo
Mon Dec 17, 2018 7:47 pm
He said it was a 3B+ when I asked, (none was mentioned in the opening post that I remember)
It was another chap that said his 3B connected at 5GHz band.
Though it's quite easy to ignore the + when posting, especially if you are new to this.
_______
Anyway,
--- does 2.4GHz work ?
--- Does anything else connect to your router/access point, what is it ?
Can you try a fresh new Raspbian Desktop image juat to see if something was messed up.
pcdimoticanerd33
Mon Dec 17, 2018 7:52 pm
yes 2.4GHz works
at 5GHz all my laptops are connected and that works
where I can find the log files maybe the error
bensimmo
Mon Dec 17, 2018 8:09 pm
Check you last attempts SSID, you spelt Guest1 wrong in the copy you pasted on here.
So double check spellings etc.
From the man pages on the web for wpasupplicant
The easiest way to debug problems, and to get debug log for bug reports, is to start wpa_supplicant on foreground with debugging enabled:
wpa_supplicant -c/etc/wpa_supplicant.conf -iwlan0 -d
So alter as needed.
HawaiianPi
Mon Dec 17, 2018 9:07 pm
That part of my reply was to Will5455 who claimed his 3B connected to 5GHz. You had already confirmed you had a 3B+ model.
  1. Can you see your 5GHz network when searching for networks in range?
  2. Do you have your SSID hidden?
  3. Do you have MAC address filtering or DHCP limits set in your router which could be preventing your Pi connecting?
You can have multiple networks in wpa_supplicant.conf as follows:
update_config=1
country=US
network={
        ssid="Your 2.4GHz WiFi SSID"
        psk="Your 2.4GHz network passphrase"
        key_mgmt=WPA-PSK
network={
        ssid="Your 5GHz WiFi SSID"
        psk="Your 5GHz network passphrase"
        key_mgmt=WPA-PSK
Basically, two (or more) complete network sections. You can even specify priorities.
