bedtime
[SOLVED] kworker hogging cpu
Wed Feb 27, 2019 12:35 pm
I am extremely mindful of how much cpu my RPI 3b+ uses. It consistently idles between 99.2% and 99.5%. It took a lot of work to get it there... Last night all was working fine. I woke up and turned the RPI on and the idle was 95%. It seems that these root processes are the hoggers:
  323 root      20           4.3   0:01.56 kworker/u8:3
   65 root     -51           3.0   0:10.44 irq/92-mmc1
pi user seems to use regular amount of cpu.
I was monkeying around with shells and the chsh command and also mksh-static. I have returned the default shell to mksh, and the problem persists, though it was working perfectly, even with a reboot, before I went to bed. As I said, I am anal about cpu usage.
I have my keyboard and mouse plugged into the USB as usual—no other devices. Raspian is running on the regular sd card.
I tried installing perf to solve the issue, and upon running, I get:
$ perf
/usr/bin/perf: line 13: exec: perf_4.14: not found
E: linux-perf-4.14 is not installed.
$ sudo apt-get install linux-perf-4.14
Reading package lists... Done
Building dependency tree
E: Unable to locate package linux-perf-4.14
E: Couldn't find any package by glob 'linux-perf-4.14'
E: Couldn't find any package by regex 'linux-perf-4.14'
$ sudo apt-get install linux-perf-4*
E: Unable to locate package linux-perf-4*
E: Couldn't find any package by glob 'linux-perf-4*'
E: Couldn't find any package by regex 'linux-perf-4*'
$ sudo perf
/boot/config.txt:
# http://rpf.io/configtxt
disable_splash=1
hdmi_safe=0
disable_overscan=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=800
#framebuffer_height=480
hdmi_force_hotplug=1
hdmi_group=2
hdmi_mode=9
#hdmi_drive=2
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
#dtoverlay=lirc-rpi
dtparam=audio=on
gpu_mem=256
#dtoverlay=vc4-kms-v3d
#scaling_kernel=8
#dtoverlay=vc4-fkms-v3d
/boot/cmdline.txt:
dwc_otg.lpm_enable=0 dwc_otg.fiq_fix_enable=1 console=serial0,115200 console=tty1 root=PARTUUID=a4b62e48-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash loglevel=3 rd.udev.log_priority=0 vt.global_cursor_default=0
Any ideas on how to investigate this?
*** EDIT ***
Progress! I've found out that the issue is something to do with the wireless; I turned it off and the issue went away. I have to go out now, but I'll be back. Thought I'd quickly add this info before I go. :)
*** EDIT 2 ***
FIXED! Reset the modem and all good. Gotta go or will be late! :D
