pedrotduarte
Docker image for raspbian
Thu Feb 28, 2019 3:19 pm
Hello
I have a system setup in which I setup and configure a raspberrypi with some custom scripts. But in order to avoid having to setup a new box "every time" I need to test the overall system, I though about using docker to create an image of the base raspbian and test it locally on my machine (mac).
So, I did:
1- Downloaded 2018-11-13-raspbian-stretch-lite.img
2- Created 2018-11-13-raspbian-stretch-lite.tar.gz
3- Created Dockerfile:
FROM scratch
ADD ./2018-11-13-raspbian-stretch-lite.tar.gz /
4- Ran: docker build -t myproject .
5- Ran: docker run -it myproject bash
After running, apparently all is well. BUT: although in my system, the file /proc/cpuinfo has Serial Number, when I run it with docker as described, /proc/cpuinfo does not contain Serial Number.
What am I missing? Any ideas? If /proc/cpuinfo does not always contain the serial number, where else can it be depending on the image?
Thank you for any pointers
Heater
Re: Docker image for raspbian
Thu Feb 28, 2019 3:37 pm
How about giving your Docker container access to files outside the container. See Docker documentation and all kind of blogs around the net. For example: https://www.digitalocean.com/community/ ... d-the-host
Or pass the serial number into the Docker container when you start it with the -e option to the run command:
https://docs.docker.com/engine/referenc ... dline/run/
