Jmccart
Control Arduino with Raspberry pi
Sun Mar 24, 2019 9:25 pm
Hi, I am working on a robotics project and I want to control servos connected to my Arduino, from my raspberry pi, how would I go about doing this??
gordon77
Re: Control Arduino with Raspberry pi
Sun Mar 24, 2019 9:35 pm
You can connect the pi and Arduino Uno with a usb cable and send and receive serial data.
Here's a simple example to show the principle.
viewtopic.php?f=91&t=186364&hilit=Uno#p1177157
Jmccart
Sun Mar 31, 2019 8:01 pm
Sorry, but which code do I upload to my arduino, and which code do i run on my raspberry pi to control the arduino? these directions are very vague
gordon77
Sun Mar 31, 2019 8:23 pm
For the Pi...
#! /usr/bin/env python
import serial
import time
ser = serial.Serial(port='/dev/ttyACM0',baudrate = 9600,parity=serial.PARITY_NONE,
        stopbits=serial.STOPBITS_ONE,bytesize=serial.EIGHTBITS,timeout=1)
# Wait to read from Arduino
while 1:
   try:
       time.sleep(10)
       # send an R to the arduino
       ser.write("R")
       #read data from arduino
       myData = ser.readline()
       print myData
   except KeyboardInterrupt:
       exit()
For the Arduino Uno...
       float flow = 500.06;
    void setup() {
      Serial.begin( 9600 );}
    void loop() {
        if (Serial.available()>0) {
            if (Serial.read() == 'R') {
                 Serial.print(flow)
                 Serial.write("\n");
gordon77
Tue Apr 02, 2019 3:45 pm
This will control 2 servos connected to an Arduino Uno, connected to pins 3 & 4, and 5v and gnd.
It uses 2 sliders to set their positions. It sends commands like A1000, range A0500 to A2500, which the Arduino code will decode.
Raspberry Pi python script..
#!/usr/bin/python3
import os
import pygame, sys
from pygame.locals import *
import serial
import time
# open serial port
if os.path.exists('/dev/ttyACM0') == True:
   ser = serial.Serial(port='/dev/ttyACM0',baudrate = 115200,parity=serial.PARITY_NONE,
elif os.path.exists('/dev/ttyACM1') == True:
   ser = serial.Serial(port='/dev/ttyACM1',baudrate = 115200,parity=serial.PARITY_NONE,
time.sleep(2)
# initilaise pygame
pygame.init()
windowSurfaceObj = pygame.display.set_mode((600,100),1,16)
redColor = pygame.Color(255,0,0)
blackColor = pygame.Color(0,0,0)
whiteColor = pygame.Color(255,255,255)
#starting position
pygame.draw.line(windowSurfaceObj, whiteColor, (0,50),   (600,50))
for m in range (2,600,35):
    pygame.draw.line(windowSurfaceObj, whiteColor, (m,48),   (m,52))
xA = 312
pygame.draw.rect(windowSurfaceObj,redColor,Rect(xA,5,10,40))
xB = 312
pygame.draw.rect(windowSurfaceObj,redColor,Rect(xB,55,10,40))
pygame.display.update(pygame.Rect(0,0,600,100))
s = 0
while s == 0:
    # read mouse button and position
    button = pygame.mouse.get_pressed()
    if button[0] != 0:
       pos = pygame.mouse.get_pos()
       x = pos[0]
       y = pos[1]
       a = x - 5
       if a < 0:
          a = 0
       # control servo A
       if y < 50:
          xA = a
          pygame.draw.rect(windowSurfaceObj,blackColor,Rect(0,0,600,100/2))
          j = "A" + str(500 + int(xA * 3.368)).zfill(4)
          b = j.encode()
          # send to the Arduino eg. A1000
          ser.write(b)
          pygame.display.update(pygame.Rect(0,0,600,45))
          time.sleep(.1)
          # read from Arduino
          myData = (ser.readline()).strip().decode("utf-8")
          print ("A" + myData)
       # control servo B
       else:
          xB = a
          pygame.draw.rect(windowSurfaceObj,blackColor,Rect(0,50,600,100))
          j = "B" + str(500 + int(xB * 3.368)).zfill(4)
          b = j.encode()
          # send to the Arduino eg. B1000
          ser.write(b)
          pygame.display.update(pygame.Rect(0,55,600,100))
          time.sleep(.1)
          # read from Arduino
          print ("B" + myData)
   # check for ESC key pressed, or pygame window closed, to quit
    for event in pygame.event.get():
       if event.type == QUIT:
          pygame.quit()
          sys.exit()
       elif event.type == KEYDOWN:
          if event.key == K_ESCAPE:
             pygame.quit()
             sys.exit()
Arduino Uno code...
int servopinA = 3;
int servopinB = 4;
int pulseA = 1500;
int pulseB = 1500;
int valByte = 1500;
int inByte1 = 'a';
int inByte2 = 'a';
int inByte3 = 'a';
int inByte4 = 'a';
int inByte5 = 'a';
int Byte = 'a';
void setup()
  pinMode(servopinA, OUTPUT);
  pinMode(servopinB, OUTPUT);
  Serial.begin(115200);
  delay (1);
void loop()
  if (Serial.available() > 4)
       { inByte1 = Serial.read();
         // check for valid commamd eg. A1000
         if (inByte1 == 'A' or inByte1 == 'B')
            // read the next 4 characters
             inByte2 = Serial.read();
             inByte3 = Serial.read();
             inByte4 = Serial.read();
             inByte5 = Serial.read();
             valByte = (1000 * int(inByte2 - 48) +  100 * int(inByte3 - 48) + 10 * int(inByte4 - 48) + int(inByte5 - 48));
             Serial.print(valByte);
             Serial.write("\n");
             if (valByte > 499 and valByte < 2501 and inByte1 == 'A') {pulseA = valByte;}
             if (valByte > 499 and valByte < 2501 and inByte1 == 'B') {pulseB = valByte;}
          // empty serial buffer if not valid
         if (inByte1 != 'A' && inByte1 != 'B')
            { while (Serial.available()>0){
              Byte = Serial.read();}}
  digitalWrite(servopinA,HIGH);
  delayMicroseconds(int(pulseA));
  digitalWrite(servopinA, LOW);
  digitalWrite(servopinB,HIGH);
  delayMicroseconds(int(pulseB));
  digitalWrite(servopinB, LOW);
  delay(20);
Tank1334
Thu Jun 04, 2020 2:01 am
hey, i have an Arduino currently controlling 2 servos and seperatly a raspberry pi b3+ being controlled by a telegram bot, how would i go about that??
code for telegram bot(on pi) its in python
#coder :- Salman Faris
import sys
import time
import random
import datetime
import telepot
import RPi.GPIO as GPIO
#LED
def on(pin):
        GPIO.output(pin,GPIO.HIGH)
        return
def off(pin):
        GPIO.output(pin,GPIO.LOW)
        return
# to use Raspberry Pi board pin numbers
GPIO.setmode(GPIO.BOARD)
# set up GPIO output channel
GPIO.setup(11, GPIO.OUT)
def handle(msg):
    chat_id = msg['chat']['id']
    command = msg['text']
    print 'Got command: %s' % command
    if command == 'on' or command == 'On':
       bot.sendMessage(chat_id, on(11))
    elif command =='off' or command =='Off':
       bot.sendMessage(chat_id, off(11))
bot = telepot.Bot('Bot Token')
bot.message_loop(handle)
print 'I am listening...'
while 1:
     time.sleep(10)
I dont use raspberry pi to much for this kind of stuff so i am kind of a newbie.
my arduino code is:
#include <Servo.h>
#include <IRremote.h>
int servoPin = 3;
int servo1Pin = 8;
const int RECV_PIN = 7;
IRrecv irrecv(RECV_PIN);
decode_results results;
Servo Servo1;
Servo servo2;
void setup() {
  irrecv.enableIRIn();
  irrecv.blink13(true);
  Servo1.attach(3);  // attaches the servo on pin 3 to the servo object
  servo2.attach(8);
void loop() {
  if (irrecv.decode(&results)) {
    switch (results.value) {
      case 16726215: //Keypad button "5"
        on2();
        break;
      case 16730805:
        off2();
        break;
    irrecv.resume();
  void on2() {
  servo2.write(180);
  delay(500);
  Servo1.writeMicroseconds(850);
void off2() {
    Servo1.writeMicroseconds(2500);
     delay(500);
     servo2.writeMicroseconds(850);
gordon77
Thu Jun 04, 2020 3:32 pm
If you look at the 5th mail on this thread the code controls 2 servos connected to an arduino
