auto514
Why am I getting a name resolution error with my cron job?
Mon Apr 08, 2019 6:47 am
This is a follow up to this thread.
I am trying to get a cron job to run and unfortunately for some reason nothing happens. I decided to have the script run on boot and surprisingly, this time around, my var/mail/pi file told me that something is wrong with my script.
Here is the contents:
  File "/home/pi/Desktop/directory/file.py", line 106, in <module>
    function(param)
  File "/home/pi/Desktop/directory/file", line 13, in function
    server = IMAPClient(host, use_uid=True)
  File "/usr/local/lib/python3.5/dist-packages/imapclient/imapclient.py", line 254, in __init__
    self._imap = self._create_IMAP4()
  File "/usr/local/lib/python3.5/dist-packages/imapclient/imapclient.py", line 289, in _create_IMAP4
    self._timeout)
  File "/usr/local/lib/python3.5/dist-packages/imapclient/tls.py", line 44, in __init__
    imaplib.IMAP4.__init__(self, host, port)
  File "/usr/lib/python3.5/imaplib.py", line 189, in __init__
    self.open(host, port)
  File "/usr/local/lib/python3.5/dist-packages/imapclient/tls.py", line 49, in open
    sock = socket.create_connection((host, port), self._timeout.connect)
  File "/usr/lib/python3.5/socket.py", line 694, in create_connection
    for res in getaddrinfo(host, port, 0, SOCK_STREAM):
  File "/usr/lib/python3.5/socket.py", line 733, in getaddrinfo
    for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Temporary failure in name resolution
This script runs without error manually, but for some reason whenever I try to run it with cron it does nothing. I changed paths and tested this script on a PC in Task Scheduler and did not have any problems.
pcmanbob
Re: Why am I getting a name resolution error with my cron job?
Mon Apr 08, 2019 7:49 am
" Temporary failure in name resolution " would suggest that when you are running the program you do not have access to the internet.
Do you have internet access can you browse the web ?
If you run the script manually after your pi has booted does it work then ?
auto514
Mon Apr 08, 2019 3:32 pm
Thank you Bob,
I currently do have internet. My Raspberry Pi uses a wifi connection to access the internet. After I boot my pi I can run the script manually on my pi without any problems.
scruss
Mon Apr 08, 2019 3:48 pm
Are you running this as a @reboot clause in your crontab? If so, it'll run long before the system has a wifi connection.
There are a couple of ways around this:
  1. put a sleep 30 ; before your command in the crontab entry. This is a simplistic way of waiting for the network; or
  2. enable wait for network in raspi-config in its boot options; or
  3. use systemd, and write a service file that includes a After=network-online.target directive, as in here: viewtopic.php?p=1439963#p1441713
Pronouns: he/him
B.Goode
Mon Apr 08, 2019 3:49 pm
Thank you Bob,
You have network access currently.
What @pcmanbob wrote was
Maybe the Network is not ready when Cron runs that task at reboot?
There via a Wait for Network option in the raspi-config utility that might help?
auto514
Mon Apr 08, 2019 5:52 pm
I was thinking about what the problem might be, and this was something I considered. I added a sleep to my script then rebooted my pi and it works. I think I will use the second option, though. It is less of a hassle.
