woodc
Redirect serial output to file
Sun Nov 25, 2012 11:23 pm
I have an Arduino connected to my Pi and it seems to be working as expected. If I run the Arduino IDE and use the serial monitor pointed to /dev/ttyACM0 I see the data expected.
If I try to cat /dev/ttyACM0 I also see some data however it immediately returns to the command prompt instead of staying open and showing continued serial data.
This brings me to my question: How can I redirect the serial output to a file? On the beaglebone and other linux boxes I simply cat /dev/ttyACM0 >> /home/blah/serial.log then I can use tail to get the most recent data for use by scripts/posting to Cosm, etc from the serial.log file. On the Pi this does not work...it creates the file but immediately closes.
Thanks all
pluggy
Re: Redirect serial output to file
Mon Nov 26, 2012 12:14 am
I use minicom capturing to a file
minicom -C /root/capture >> /dev/null
I run it from rc.local. Then I cat and tail the capture file. I also make a copy periodically and tail the copy back to the capture file to keep it from growing indefinitely.
On another arm linux box I just cat and tail the device as you described. The above is a Pi workaround.
woodc
Wed Nov 28, 2012 2:32 am
Thanks for the reply :) I will try that again but I am fairly certain this was also dying/quitting instead of running nonstop....
lindymood
Thu Feb 07, 2013 4:13 pm
Check out my recent post. Perhaps this may help?
http://www.raspberrypi.org/phpBB3/viewt ... 37&t=26285
