Hi. It is to be noted that we do get small dropouts (about 3ms) without any trace in dmesg or journal. We do get them when playing DSD256 in DoP mode.
Those are the logs you requested:
DMESG
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.65-v7+ (volumio@udoo-x86) (gcc version 4.8.3 20140106 (prerelease) (crosstool-NG linaro-1.13.1-4.8-2014.01 - Linaro GCC 2013.11) ) #1 SMP Thu Jul 19 18:43:14 UTC 2018
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt:Machine model: Raspberry Pi Compute Module 3 Rev 1.0
[ 0.000000] cma: Reserved 8 MiB at 0x3b800000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 245760
[ 0.000000] free_area_init_node: node 0, pgdat 80c6f380, node_mem_map baf86000
[ 0.000000] Normal zone: 2160 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 245760 pages, LIFO batch:31
[ 0.000000] percpu: Embedded 14 pages/cpu @baf41000 s25600 r8192 d23552 u57344
[ 0.000000] pcpu-alloc: s25600 r8192 d23552 u57344 alloc=14*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 243600
[ 0.000000] Kernel command line: bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:1F:E8:6F vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 splash quiet plymouth.ignore-serial-consoles dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0xF dwc_otg.nak_holdoff=1 imgpart=/dev/mmcblk0p2 imgfile=/volumio_current.sqsh elevator=noop rootwait smsc95xx.turbo_mode=N bootdelay=5 logo.nologo vt.global_cursor_default=0 loglevel=0 consoleblank=0
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 942104K/983040K available (7168K kernel code, 486K rwdata, 2012K rodata, 1024K init, 770K bss, 32744K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xbc800000 - 0xff800000 (1072 MB)
lowmem : 0x80000000 - 0xbc000000 ( 960 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x80800000 (8160 kB)
.init : 0x80b00000 - 0x80c00000 (1024 kB)
.data : 0x80c00000 - 0x80c7981c ( 487 kB)
.bss : 0x80c7b000 - 0x80d3b964 ( 771 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000018] Switching to timer-based delay loop, resolution 52ns
[ 0.000273] Console: colour dummy device 80x30
[ 0.000291] console [tty0] enabled
[ 0.000311] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000326] pid_max: default: 32768 minimum: 301
[ 0.000605] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000615] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001683] Disabling memory control group subsystem
[ 0.001752] CPU: Testing write buffer coherency: ok
[ 0.001786] ftrace: allocating 22388 entries in 66 pages
[ 0.048943] CPU0: update cpu_capacity 1024
[ 0.048956] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.048993] Setting up static identity map for 0x100000 - 0x100034
[ 0.050893] CPU1: update cpu_capacity 1024
[ 0.050900] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.051555] CPU2: update cpu_capacity 1024
[ 0.051561] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.052201] CPU3: update cpu_capacity 1024
[ 0.052207] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.052297] Brought up 4 CPUs
[ 0.052307] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.052311] CPU: All CPU(s) started in HYP mode.
[ 0.052314] CPU: Virtualization extensions available.
[ 0.053048] devtmpfs: initialized
[ 0.064292] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.064558] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.064574] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.065122] pinctrl core: initialized pinctrl subsystem
[ 0.066034] NET: Registered protocol family 16
[ 0.068417] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.077411] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.077417] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.077561] Serial: AMBA PL011 UART driver
[ 0.079447] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.149799] bcm2835-dma 3f007000.dma: DMA legacy API manager at bc80f000, dmachans=0x1
[ 0.151661] SCSI subsystem initialized
[ 0.151818] usbcore: registered new interface driver usbfs
[ 0.151893] usbcore: registered new interface driver hub
[ 0.151983] usbcore: registered new device driver usb
[ 0.158746] raspberrypi-firmware soc:firmware: Attached to firmware from 2018-07-17 13:23
[ 0.160311] clocksource: Switched to clocksource arch_sys_counter
[ 0.204609] VFS: Disk quotas dquot_6.6.0
[ 0.204683] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.204880] FS-Cache: Loaded
[ 0.205132] CacheFiles: Loaded
[ 0.217390] NET: Registered protocol family 2
[ 0.218259] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.218367] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.218552] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.218644] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.218686] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.218897] NET: Registered protocol family 1
[ 0.219314] RPC: Registered named UNIX socket transport module.
[ 0.219319] RPC: Registered udp transport module.
[ 0.219323] RPC: Registered tcp transport module.
[ 0.219327] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.219565] Trying to unpack rootfs image as initramfs...
[ 1.092344] Freeing initrd memory: 10444K
[ 1.098387] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 1.100762] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 1.116999] FS-Cache: Netfs 'nfs' registered for caching
[ 1.117977] NFS: Registering the id_resolver key type
[ 1.118001] Key type id_resolver registered
[ 1.118006] Key type id_legacy registered
[ 1.120437] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 1.120550] io scheduler noop registered (default)
[ 1.120555] io scheduler deadline registered
[ 1.120857] io scheduler cfq registered
[ 1.126570] BCM2708FB: allocated DMA memory fb910000
[ 1.126592] BCM2708FB: allocated DMA channel 0 @ bc80f000
[ 1.136225] Console: switching to colour frame buffer device 80x30
[ 1.143321] bcm2835-rng 3f104000.rng: hwrng registered
[ 1.143428] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.143936] vc-sm: Videocore shared memory driver
[ 1.158764] brd: module loaded
[ 1.167634] loop: module loaded
[ 1.167645] Loading iSCSI transport class v2.0-870.
[ 1.168161] usbcore: registered new interface driver smsc95xx
[ 1.168176] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.396217] Core Release: 2.80a
[ 1.396226] Setting default values for core params
[ 1.396256] Finished setting default values for core params
[ 1.596648] Using Buffer DMA mode
[ 1.596653] Periodic Transfer Interrupt Enhancement - disabled
[ 1.596657] Multiprocessor Interrupt Enhancement - disabled
[ 1.596664] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.596674] Dedicated Tx FIFOs mode
[ 1.597012] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xbb904000 dma = 0xfb904000 len=9024
[ 1.597035] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 1.597041] dwc_otg: Microframe scheduler enabled
[ 1.597089] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x8057e2c8
[ 1.597099] WARN::hcd_init_fiq:460: FIQ ASM at 0x8057e624 length 36
[ 1.597109] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbc87a000
[ 1.597169] dwc_otg 3f980000.usb: DWC OTG Controller
[ 1.597202] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 1.597233] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ 1.597279] Init: Port Power? op_state=1
[ 1.597283] Init: Power Port (0)
[ 1.597488] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.597498] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.597506] usb usb1: Product: DWC OTG Controller
[ 1.597514] usb usb1: Manufacturer: Linux 4.9.65-v7+ dwc_otg_hcd
[ 1.597522] usb usb1: SerialNumber: 3f980000.usb
[ 1.598330] hub 1-0:1.0: USB hub found
[ 1.598368] hub 1-0:1.0: 1 port detected
[ 1.599038] dwc_otg: FIQ enabled
[ 1.599042] dwc_otg: NAK holdoff enabled
[ 1.599046] dwc_otg: FIQ split-transaction FSM enabled
[ 1.599060] Module dwc_common_port init
[ 1.599292] usbcore: registered new interface driver usb-storage
[ 1.599530] mousedev: PS/2 mouse device common for all mice
[ 1.600586] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 1.600876] bcm2835-cpufreq: min=600000 max=1200000
[ 1.601289] sdhci: Secure Digital Host Controller Interface driver
[ 1.601293] sdhci: Copyright(c) Pierre Ossman
[ 1.603451] sdhost-bcm2835 3f202000.sdhost: could not get clk, deferring probe
[ 1.603654] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.604073] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.604167] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.604338] usbcore: registered new interface driver usbhid
[ 1.604343] usbhid: USB HID core driver
[ 1.605081] vchiq: vchiq_init_state: slot_zero = 0xbb980000, is_master = 0
[ 1.606428] [vc_sm_connected_init]: start
[ 1.615069] [vc_sm_connected_init]: end - returning 0
[ 1.615439] Initializing XFRM netlink socket
[ 1.615462] NET: Registered protocol family 17
[ 1.615561] Key type dns_resolver registered
[ 1.616133] Registering SWP/SWPB emulation handler
[ 1.616816] registered taskstats version 1
[ 1.622196] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 1.622261] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ 1.625721] sdhost: log_buf @ bb907000 (fb907000)
[ 1.700345] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 1.700455] of_cfs_init
[ 1.700637] of_cfs_init: OK
[ 1.721906] Freeing unused kernel memory: 1024K
[ 1.810459] Indeed it is in host mode hprt0 = 00021501
[ 1.860078] initramfs: Booting Volumio for BCM2835
[ 1.860244] initramfs: This script mounts rootfs RO with an overlay RW layer.
[ 1.875410] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.881050] initramfs: IMGPART=/dev/mmcblk0p2
[ 1.881188] initramfs: IMGFILE=/volumio_current.sqsh
[ 1.881390] initramfs: Boot delay (except first time) will be 5 seconds
[ 1.881705] initramfs: /dev/mmcblk0p2 not detected,retrying mdev in 5 seconds
[ 1.898253] random: fast init done
[ 1.901658] mmc0: new high speed MMC card at address 0001
[ 1.902363] mmcblk0: mmc0:0001 MAG2GC 14.6 GiB
[ 1.902615] mmcblk0boot0: mmc0:0001 MAG2GC partition 1 4.00 MiB
[ 1.902863] mmcblk0boot1: mmc0:0001 MAG2GC partition 2 4.00 MiB
[ 1.903100] mmcblk0rpmb: mmc0:0001 MAG2GC partition 3 4.00 MiB
[ 1.906485] mmcblk0: p1 p2 p3
[ 2.010352] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.010479] Indeed it is in host mode hprt0 = 00001101
[ 2.240594] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.240605] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.241332] hub 1-1:1.0: USB hub found
[ 2.241422] hub 1-1:1.0: 5 ports detected
[ 2.526596] initramfs: /dev/mmcblk0p2:
[ 2.547020] EXT4-fs (mmcblk0p2): recovery complete
[ 2.548226] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.550703] initramfs: Doing a 5 second delay here to give kernel load a headstart
[ 2.560384] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.690605] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.690616] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.693459] smsc95xx v1.0.5
[ 2.783965] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:1f:e8:6f
[ 2.880345] usb 1-1.4: new high-speed USB device number 4 using dwc_otg
[ 3.010579] usb 1-1.4: New USB device found, idVendor=0424, idProduct=2412
[ 3.010590] usb 1-1.4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.011236] hub 1-1.4:1.0: USB hub found
[ 3.011328] hub 1-1.4:1.0: 2 ports detected
[ 3.110341] usb 1-1.5: new high-speed USB device number 5 using dwc_otg
[ 3.241108] usb 1-1.5: New USB device found, idVendor=0bda, idProduct=b720
[ 3.241118] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.241126] usb 1-1.5: Product: 802.11n WLAN Adapter
[ 3.241133] usb 1-1.5: Manufacturer: Realtek
[ 3.241141] usb 1-1.5: SerialNumber: 00e04c000001
[ 3.340339] usb 1-1.4.2: new high-speed USB device number 6 using dwc_otg
[ 3.471016] usb 1-1.4.2: New USB device found, idVendor=2772, idProduct=0230
[ 3.471027] usb 1-1.4.2: New USB device strings: Mfr=1, Product=3, SerialNumber=0
[ 3.471034] usb 1-1.4.2: Product: Pre Box S2 Digital
[ 3.471042] usb 1-1.4.2: Manufacturer: Pro-Ject
[ 3.474563] input: Pro-Ject Pre Box S2 Digital as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4.2/1-1.4.2:1.3/0003:2772:0230.0001/input/input0
[ 3.540579] hid-generic 0003:2772:0230.0001: input,hidraw0: USB HID v1.10 Device [Pro-Ject Pre Box S2 Digital] on usb-3f980000.usb-1.4.2/input3
[ 7.554549] initramfs: Checking for USB updates
[ 7.653665] initramfs: No USB device detected (when incorrect, try adding 'bootdelay=5' to your boot cmdline)
[ 7.832584] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 7.921750] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 9.366926] EXT4-fs (mmcblk0p3): 3 orphan inodes deleted
[ 9.366935] EXT4-fs (mmcblk0p3): recovery complete
[ 9.385714] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[ 9.388730] initramfs: With Option:
[ 9.514053] initramfs: VOLUMIO_VERSION="1.018"
[ 9.514210] initramfs: Finish initramfs, continue booting Volumio
[ 9.879961] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[ 9.880286] systemd[1]: Detected architecture 'arm'.
[ 10.007057] NET: Registered protocol family 10
[ 10.008624] systemd[1]: Inserted module 'ipv6'
[ 10.011224] systemd[1]: Set hostname to <stack-audio-link>.
[ 10.273236] systemd[1]: [/lib/systemd/system/mpd.service:19] Unknown lvalue 'ProtectKernelTunables' in section 'Service'
[ 10.273300] systemd[1]: [/lib/systemd/system/mpd.service:20] Unknown lvalue 'ProtectControlGroups' in section 'Service'
[ 10.273358] systemd[1]: [/lib/systemd/system/mpd.service:21] Unknown lvalue 'ProtectKernelModules' in section 'Service'
[ 10.273430] systemd[1]: [/lib/systemd/system/mpd.service:24] Unknown lvalue 'RestrictNamespaces' in section 'Service'
[ 10.305834] systemd[1]: [/lib/systemd/system/volumio-kiosk.service:11] CPU scheduling priority is out of range, ignoring: 1
[ 10.327611] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[ 10.585329] fuse init (API version 7.26)
[ 10.626729] i2c /dev entries driver
[ 10.695233] systemd-udevd[207]: starting version 215
[ 11.108527] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 11.627465] Bluetooth: Core ver 2.22
[ 11.627531] NET: Registered protocol family 31
[ 11.627536] Bluetooth: HCI device and connection manager initialized
[ 11.627556] Bluetooth: HCI socket layer initialized
[ 11.627569] Bluetooth: L2CAP socket layer initialized
[ 11.627603] Bluetooth: SCO socket layer initialized
[ 11.648621] btbcm: loading out-of-tree module taints kernel.
[ 11.648625] btbcm: loading out-of-tree module taints kernel.
[ 11.666162] usbcore: registered new interface driver btusb
[ 11.668844] Bluetooth: hci0: rtl: examining hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=8723
[ 11.668859] Bluetooth: hci0: rtl: loading rtl_bt/rtl8723b_fw.bin
[ 11.709995] Bluetooth: hci0: rom_version status=0 version=1
[ 11.986361] snd_usb_audio: unknown parameter 'nrpacks' ignored
[ 11.986374] snd_usb_audio: unknown parameter 'nrpacks' ignored
[ 12.018731] usbcore: registered new interface driver snd-usb-audio
[ 12.261127] systemd-journald[200]: Received request to flush runtime journal from PID 1
[ 12.774161] systemd-journald[200]: Received request to flush runtime journal from PID 1
[ 13.958997] random: crng init done
[ 14.177269] RTL871X: module init start
[ 14.177281] RTL871X: rtl8723bu v4.3.6.11_12942.20141204_BTCOEX20140507-4E40
[ 14.177285] RTL871X: rtl8723bu BT-Coex version = BTCOEX20140507-4E40
[ 14.362194] RTL871X: rtw_ndev_init(wlan0)
[ 14.364011] usbcore: registered new interface driver rtl8723bu
[ 14.364018] RTL871X: module init ret=0
[ 15.453796] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 16.275267] RTL871X: RTW_ADAPTIVITY_EN_
[ 16.275280] AUTO, chplan:0x20, Regulation:0,0
[ 16.275286] RTL871X: RTW_ADAPTIVITY_MODE_
[ 16.275290] NORMAL
[ 17.002886] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
[ 21.619275] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 22.339674] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 22.546843] nf_conntrack version 0.5.0 (15360 buckets, 61440 max)
[ 23.254693] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 23.254703] Bluetooth: BNEP filters: protocol multicast
[ 23.254723] Bluetooth: BNEP socket layer initialized
[ 28.807225] RTL871X: assoc success
[ 43.141893] uart-pl011 3f201000.serial: no DMA platform data
[ 5955.806874] FS-Cache: Netfs 'cifs' registered for caching
[ 5955.807249] Key type cifs.spnego registered
[ 5955.807257] Key type cifs.idmap registered
lsusb -t
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/5p, 480M
|__ Port 1: Dev 3, If 0, Class=Vendor Specific Class, Driver=smsc95xx, 480M
|__ Port 4: Dev 4, If 0, Class=Hub, Driver=hub/2p, 480M
|__ Port 2: Dev 6, If 3, Class=Human Interface Device, Driver=usbhid, 480M
|__ Port 2: Dev 6, If 1, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 2: Dev 6, If 2, Class=Application Specific Interface, Driver=, 480M
|__ Port 2: Dev 6, If 0, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 5: Dev 5, If 0, Class=Wireless, Driver=btusb, 480M
|__ Port 5: Dev 5, If 1, Class=Wireless, Driver=btusb, 480M
|__ Port 5: Dev 5, If 2, Class=Vendor Specific Class, Driver=rtl8723bu, 480M
