sandric
Connect RPI3 and Goodix Touchscreen
Wed May 08, 2019 7:54 am
Hi, I'm completely new to rpi, I have problems interfacing my 9 inch Goodix touch panel to rpi via i2c. I read viewtopic.php?t=185503 topic, and connected my touch panel https://www.buydisplay.com/default/9-in ... asperry-pi to mine raspberry pi zero w via 6 pins. I connected rpi pins such way (physical pinout):
1 (3.3v) - vcc
3 (sda) - sda
5 (scl) - scl
7 (gpio4) - INT
9 (ground) - ground
11 (gpio17) - RST
I have read INT and RST pins here https://github.com/raspberrypi/firmware ... ays/README:
Info: Enables I2C connected Goodix gt9271 multiple touch controller using
GPIOs 4 and 17 (pins 7 and 11 on GPIO header) for interrupt and reset.
Load: dtoverlay=goodix,<param>=<val>
Params: interrupt GPIO used for interrupt (default 4)
reset GPIO used for reset (default 17)
I tried to interface it via i2cdetect:
pi@raspberrypi:~ $ sudo i2cdetect -y 1
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- UU -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
Trying to read i2c data via that code:
import smbus
from time import sleep
bus = smbus.SMBus(1)
SLAVE_ADDRESS = 0x14
def request_reading():
    reading = int(bus.read_byte(SLAVE_ADDRESS))
    print(reading)
while True:
    request_reading()
    sleep(0.25)
I get error saying no such device on 0x14 address.
So my question is why do I get "UU" and not address to communicate, is this ok? Why do I get error running my python code? Is there other way to read touch event via linux? I mean can I just tail touch panel device file, can you suggest terminal command to do so? Thanks.
sandric
Re: Connect RPI3 and Goodix Touchscreen
Wed May 08, 2019 8:47 am
Actually its my fault I think, it looks like those ribbon 0.5mm flex cable connections are not too good and vobble a bit, so now I get address normally:
10: -- -- -- -- 14 -- -- -- -- -- -- -- -- -- -- --
And my code is actually run now without any error, but the thing is that no matter how I touch it, I constantly get 0 as output in terminal. Anyone have any idea why/how to get touch position properly? Should I change my post to other branch (sorry, new to community)?
PhilE
Wed May 08, 2019 8:50 am
[ Moved to Interfacing ]
sandric
Wed May 08, 2019 10:38 am
Ok, here's update, if anyone also tries to figure things out. It looks like you can read device like that, at least in my example:
cat -s /dev/input/event0
Now next problem is actually understand format of output to this file - I see it populates at touching event, but its abracadabra, is there any document describing how to read such data from input device?
P.S. Also it looks like the "UU" thing does not actually effects this output - from time to time after reboot (dont know reason - maybe its ribbon cable not rigid), I get i2cdetect output not with "14" address, but "UU" - and this device is still readable.
sandric
Thu May 09, 2019 10:59 am
Update
I figured out how to read device output - with evdev library, usage and installation for raspberry described here https://diyprojects.io/python-library-e ... NP8N477S00.
Figuring out debugging is made via command:
python /usr/local/lib/python2.7/dist-packages/evdev/evtest.py
Here's mine quick test script to get touch events (keycodes can be found by upper command):
from evdev import InputDevice
from select import select
dev = InputDevice('/dev/input/event0')
while True:
   r,w,x = select([dev], [], [])
   for event in dev.read():
       print(event)
The only thing I wish to figure out now - how can interface TWO touch panels (need in my project)? Does anyone tried to implement smth similar? I need 6 pins on raspberry to interface one touch panel - but apart from ground and vcc I need sda/scl and 2 pins - INT (GPIO 4) and RES (GPIO 17). Because of those two are set in kernel as I understood - how can I parallel them? As for i2c sda/scl - I guess I will need i2c multiplexer right? I never implemented anything like that, any help will be very appreciated, thanks.
Golia20
Mon May 11, 2020 3:51 pm
Hello i'm Leonardo, i was try use this touchscreen with this Chip Goodix, you finish or you have found a solution ?
Thanks !
dst
Sat Dec 19, 2020 11:07 pm
As I understand "UU" means reserved by the kernel. (I didn't read everything so not sure if you found that)
To configure twp chips with same i2c you will need a multiplexer - but I think that might make the drivers hard.
If you can, just configure the pi to use another i2c bus and put the second touch controller on that bus.
You'll need to modify the dtc file to create a second device tree overlay for the goodix controller to use the other bus.
