drotosclerosi
Let's give voice to my robot... Speaker problem
Fri Jun 14, 2019 9:23 am
Hiya people,
I hope this is the right section.
I have a problem that seems complex to me but maybe it is not.
I just assembled a smart car kit with the pi3 b+ that occupy some of the gpio connectors (the 3v one and other three).
I already planned to add an usb microphone, it has a camera and an ultrasonic sensor and now I would like to add a speaker.
Unfortunately all the hats (like phat) needs all of the gpios.
I planned to buy A 3.5mm speaker but it would need too much space and I don't think it would be very powerful. Are there any usb micro speakers or speaker modules which needs only some gpios and don't need an amp?
hippy
Re: Let's give voice to my robot... Speaker problem
Fri Jun 14, 2019 1:46 pm
There are lots of mini speakers which can be broken open to reveal a tiny PCB and speaker which can be used with a 5V supply and plugs straight into the 3.5mm audio jack.
Example, rather than recommendation - https://images.mobilefun.co.uk/graphics ... 0254/1.jpg
omegaman477
Fri Jun 14, 2019 1:56 pm
You dont need a hat for basic sound.
So most RPI boards have an Analogue Audio Out via a 3.5mm TRS audio jack, like a PC or Smartphone. Audio needs to be enabled in both firmware and software first, see https://www.raspberrypi.org/documentati ... -config.md
The Audio out is Line level, not speaker level, and will not drive a standard impedance speaker (4-16 ohms) directly. A high impedance piezo speaker may make some noise, but unlikely.
You will need an Amplifier. Discrete and not a hat., like https://www.adafruit.com/product/1552.
This amp will drive anything. I would look for a naked compact speaker driver or element from a mobile phone, tiny but you can drive them hard. I have used this tiny speaker with the Amp i described https://core-electronics.com.au/mini-me ... gIpVfD_BwE
..the only thing worse than a stupid question is a question not asked.
amcdonley
Fri Jun 14, 2019 7:23 pm
My current bot first used a "Wired Rechargeable Speaker": https://www.amazon.com/Otimo-Rechargeab ... B01DQ6RE4O
This was an OK speaker, but a bit of a pain because I needed to recharge it separate from recharging the bot, and I had to get on the floor with the bot to see where to plug the recharging cable into the speaker.
Here is a video with that speaker: Carl's First Words
Currently I am using a single speaker from a "Laptop USB powered Wired Stereo Speaker Set". It draws 40-50mA continuously which took an hour off my robot's play time, but it is ultimately more convenient, more powerful, and very clean audio. Small or light, it is neither.
BTW, this are my text-to-speech functions, time of day aware whisper(), say(), shout() https://github.com/slowrunner/Carl/blob ... b/speak.py
drotosclerosi
Fri Jun 14, 2019 11:14 pm
Thank you everybody.
I think I will first try that mini jack speaker, even if needs a recharge.
THe fact is that i'm already in big pain installing opencv for facial recognition so I will (and i mean it) look for other solutions (like the first reply) later.
Disassembling a speaker should be ok also due to the fact that the 5V gpio is free... so why not
OutoftheBOTS
Sat Jun 15, 2019 6:41 am
I usually just use a blue tooth speaker for my RPi sound
hippy
Sat Jun 15, 2019 12:05 pm
Indeed. It did work when audio PWM is also directed to a GPIO pin and the piezo placed across the pin and 0V was but was extremely quiet.
That should be improved upon by using a MAX 232 type serial buffer, turning 0V/3V3 to +10V/-10V to drive the piezo harder.
amcdonley
Re: Installing OpenCV
Sat Jun 15, 2019 12:42 pm
If you are willing to use Python and not virtual environments:
(From https://www.pyimagesearch.com/2018/09/1 ... ll-opencv/)
sudo apt-get update && sudo apt-get upgrade
sudo apt-get install libhdf5-dev libhdf5-serial-dev libhdf5-100
sudo apt-get install libqtgui4 libqtwebkit4 libqt4-test python3-pyqt5
sudo apt-get install libatlas-base-dev
sudo apt-get install libjasper-dev
wget https://bootstrap.pypa.io/get-pip.py
sudo python3 get-pip.py
**** OPTION A: INSTALL OpenCV to RPi system (not virtual environments)
sudo pip install opencv-contrib-python
There is a bug in the install package that does not install the opencv data so:
== get opencv/data/ ===
(browse to https://opencv.org/releases, find OpenCV - 3.4.4, click Sources to dnld zip) or
cd ~/Carl/Examples/OpenCV/
wget https://github.com/opencv/opencv/archive/3.4.4.zip
unzip *.zip
data is in ~/Carl/Examples/OpenCV/opencv-3.4.4/data
My face reco in image and in pycam: https://github.com/slowrunner/Carl/tree ... enCV/Faces
drotosclerosi
Mon Jun 17, 2019 11:28 am
unzip *.zip
I ended up doing that with OpenCV 4 following a tutorial and managed to install.
I haven't tried any recognition, also because I think it will go like 1-2 fps on the barebone raspberry pi 3 b+, but i'll try it later when i'll get the intel compute stick v2
I would like to understand more of this.
I'm not very practical with connecting a piezo speaker to the raspberry, what should I do to do that? Just buy a piezo speaker w/ 32ohm and connect the gpios with some kind of tutorial?
hippy
Mon Jun 17, 2019 1:03 pm
No; don't do that or you'll burn out the GPIO pin.
You either need to use a high impedance piezo to limit current drawn, which means it will be quiet. Or you need an amplifier which allows more current through that piezo which makes it louder.
Most typical means of putting a voltage through a piezo will limit the output voltage to the power supply rails, 5V or 3V3.
An RS232 serial driver will typically convert an input signal to +/-10V, effectively boosting the 3V3 input to a 20V output.
drotosclerosi
Wed Jun 19, 2019 2:29 pm
So i bought this little speaker.
https://www.amazon.it/gp/product/B01MZ1 ... UTF8&psc=1
It should be ok, it's very small.
I'm just worried about the weight: could a 42grams speaker connected to the 3.5 mm jack damage it in any way?
I have no support to place it on.
amcdonley
Thu Jun 20, 2019 5:46 pm
Use a short extension cable and velcro the speaker to your bot.
