flibble
/proc/cpuinfo on the raspberry pi 4
Thu Jun 27, 2019 7:54 pm
Could any kind user who already has their Pi 4 post me the output of 'cat /proc/cpuinfo'. Feel free to miss out any serial number if present.
dickon
Re: /proc/cpuinfo on the raspberry pi 4
Thu Jun 27, 2019 7:56 pm
flibble
Thu Jun 27, 2019 8:01 pm
Many thanks, that was fast :)
dickon
Thu Jun 27, 2019 8:04 pm
Slower than it might have been -- I had to install pastebinit, and the machine is currently doing H.264p24...
omxplayer works a treat, which is nice. Next up: get it running as a wifi AP, doing the 1wire temperature stuff I need, and seeing if I can get LibreELEC's Kodi running on Raspbian. Already dumped systemd, of course; what an horrific heap of junk...
Just waiting for an official netboot, as having critical bits like /boot on the sdcard doesn't fill me with confidence.
Nuncio
Fri Aug 02, 2019 10:16 am
This is what my cpuinfo shows. I could swear the ARM A72 was supposed to be ARMv8, but I could be wrong.
Also I thought it was Broadcom BCM2711. I've heard the RPi manufacturers can't change this without a lot of hassle, though.
pi@raspberrypi4:~ $ cat /proc/cpuinfo
processor : 0
model name : ARMv7 Processor rev 3 (v7l)
BogoMIPS : 108.00
Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm crc32
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 1
BogoMIPS : 108.00
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 2
BogoMIPS : 108.00
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 3
BogoMIPS : 108.00
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
Hardware : BCM2835
Revision : c03111
Fri Aug 02, 2019 10:31 am
processor : 0
BogoMIPS : 108.00
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 1
BogoMIPS : 108.00
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 2
BogoMIPS : 108.00
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 3
BogoMIPS : 108.00
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
Hardware : BCM2835
Revision : c03111
BCM2835 is what the Linux Kernel reports for ALL Raspberry Pi SBC.
Raspbian Buster is ARMHF ARMv7 32bit.
Maybe ?
lscpu
Last edited by fruitoftheloom on Fri Aug 02, 2019 10:35 am, edited 1 time in total.
Fri Aug 02, 2019 10:34 am
Use the revision code not the hardware line to determine the CPU type. This is an upstream issue, I have no idea why they have decided it's a good idea to display the wrong CPU id, but the amount of questions that come up about it on here is ridiculous, so I think they are wrong.
https://www.raspberrypi.org/documentati ... /README.md
You can also use cat /sys/firmware/devicetree/base/model
Or use raspinfo (a recent addition so may not be on your distro yet) to get a full dump of system data.
arachnaut
Thu Sep 05, 2019 1:03 am
When I use
$ cat /sys/firmware/devicetree/base/model
I see this:
pi@raspberrypi:~ $ cat /sys/firmware/devicetree/base/model
Raspberry Pi 4 Model B Rev 1.1pi@raspberrypi:~ $
Which has no proper new line due to a NUL character in the output.
This affects the output of raspbian 'raspinfo' script making the output text file appear truncated in 'Text Editor' (leafpad).
I fixed the script for me using sed to remove NULs:
cat /sys/firmware/devicetree/base/model | sed -e "s/[\x0]//g"
The full raspbian script mods I use look like this:
#!/bin/bash
# mod by Jim Hurley
# Aug 28, 2019
# Some of the regex's used in sed
# Catch basic IP6 address   "s/\([0-9a-fA-F]\{1,4\}:\)\{7,7\}[0-9a-fA-F]\{1,4\}/y.y.y.y.y.y.y.y/g"
# Catch y::y.y.y.y          "s/[0-9a-fA-F]\{1,4\}:\(:[0-9a-fA-F]\{1,4\}\)\{1,4\}/y::y.y.y.y/g"
# IP4 d.d.d.d decimal	    "s/\([0-9]\{1,3\}\.\)\{3,3\}[0-9]\{1,3\}/x.x.x.x/g"
# mac address	            "s/\([0-9a-fA-F]\{2,2\}\:\)\{5,5\}[0-9a-fA-F]\{2,2\}/m.m.m.m/g"
# strip NUL characters      "s/[\x0]//g"
OUT=raspinfo.txt
rm -f $OUT
exec > >(tee -ia $OUT)
echo System Information
echo ------------------
echo
# there is a NUL here
echo
echo
cat /etc/os-release | head -4
echo
cat /etc/rpi-issue
echo
uname -a
cat /proc/cpuinfo | tail -3
echo "Throttled flag  : "`vcgencmd get_throttled`
echo "Camera          : "`vcgencmd get_camera`
echo
echo "Videocore information"
echo "---------------------"
echo
vcgencmd version
echo
vcgencmd mem_reloc_stats
echo
echo "Filesystem information"
echo "----------------------"
df
echo
cat /proc/swaps
echo
echo "Package version information"
echo "---------------------------"
apt-cache policy raspberrypi-ui-mods | head -2
apt-cache policy raspberrypi-sys-mods | head -2
apt-cache policy openbox | head -2
apt-cache policy lxpanel | head -2
apt-cache policy pcmanfm | head -2
apt-cache policy rpd-plym-splash | head -2
echo
echo "Networking Information"
echo
ifconfig | sed -e "s/\([0-9a-fA-F]\{1,4\}:\)\{7,7\}[0-9a-fA-F]\{1,4\}/y.y.y.y.y.y.y.y/g" | sed -e "s/[0-9a-fA-F]\{1,4\}:\(:[0-9a-fA-F]\{1,4\}\)\{1,4\}/y::y.y.y.y/g" | sed -e "s/\([0-9]\{1,3\}\.\)\{3,3\}[0-9]\{1,3\}/x.x.x.x/g" | sed -e "s/\([0-9a-fA-F]\{2,2\}\:\)\{5,5\}[0-9a-fA-F]\{2,2\}/m.m.m.m/g"
echo
echo "USB Information"
echo "---------------"
echo
lsusb -t
echo
echo "config.txt"
echo "----------"
echo
#cat /boot/config.txt | egrep -v "^\s*(#|^$)"
vcgencmd get_config int
vcgencmd get_config str
echo
echo "cmdline.txt"
echo "-----------"
cat /proc/cmdline
echo
echo "raspi-gpio settings"
echo "-------------------"
echo
raspi-gpio get
echo
echo "vcdbg log messages"
echo "------------------"
echo
sudo vcdbg log msg 2>&1
echo
echo "dmesg log"
echo "---------"
echo
dmesg | sed -e "s/\([0-9a-fA-F]\{1,4\}:\)\{7,7\}[0-9a-fA-F]\{1,4\}/y.y.y.y.y.y.y.y/g" | sed -e "s/[0-9a-fA-F]\{1,4\}:\(:[0-9a-fA-F]\{1,4\}\)\{1,4\}/y::y.y.y.y/g" | sed -e "s/\([0-9a-fA-F]\{2,2\}\:\)\{5,5\}[0-9a-fA-F]\{2,2\}/m.m.m.m/g"
Jim Hurley
anssi_s
Wed Nov 20, 2019 12:07 pm
ARMv8 is 64-bits, no? I'd like to see what /proc/cpuinfo shows if the RPi4 is booted to a 64-bit Linux. Especially interested in whether the crypto extensions are present or not which should show in the output.
jahboater
Wed Nov 20, 2019 12:11 pm
Also available from:
/proc/device-tree/model
But I see its still NUL terminated.
dickon
Wed Nov 20, 2019 12:27 pm
root@telly-aarch64:~# cat /proc/cpuinfo
processor       : 0
BogoMIPS        : 108.00
Features        : fp asimd evtstrm crc32 cpuid
CPU architecture: 8
CPU variant     : 0x0
CPU part        : 0xd08
CPU revision    : 3
processor       : 1
BogoMIPS        : 108.00
CPU architecture: 8
CPU variant     : 0x0
CPU part        : 0xd08
CPU revision    : 3
processor       : 2
BogoMIPS        : 108.00
CPU architecture: 8
CPU variant     : 0x0
CPU part        : 0xd08
CPU revision    : 3
processor       : 3
BogoMIPS        : 108.00
CPU architecture: 8
CPU variant     : 0x0
CPU part        : 0xd08
CPU revision    : 3
Hardware        : BCM2835
Revision        : b03111
Serial          : 10000000b5b897d0
Model           : Raspberry Pi 4 Model B Rev 1.1
Wed Nov 20, 2019 1:51 pm
AIUI, Crypto extensions are built in to the HW, so if they are not on the Pi4 in 32bit mode, they won't be in 64bit mode either.
