I purchased an ADATA SD600 SSD with the intention of using in on my new Raspberry Pi 4B which is running headless via SSH. I attached the SSD to the USB 3 port and was able to reformat it to ext4 and copied some smaller files using SSH to it no problems but when I tried to copy several large (~1.6GB) files the transfer locked up and the system slowed to a crawl. dmesg indicated a large number of usb controller resets and other strange kernel warnings. I was unable to kill the transfer so I attempted a reboot which hung. So I powered down and reset but the pi would not even boot. I removed the ssd and the system booted. A second attempt to copy the files produced similar results so I connected the SSD to a USB 2.0 port to see if that would work. It did. SSD is working fine on USB 2.0 no boot problems and no errors recorded after 3 days of testing it. I then moved the SSD to my old Toshiba laptop running Ubuntu 18.04 and tested it there to see if the problem is with the drive. I seems to work perfectly connected to my laptop 3.0 ports so the problem must be with drivers/firmware in raspberry pi. My question: Can this be issue be fixed or is there a work around? ADATA SD600 is a very popular and low priced device. It would be a shame it raspberry can not support it.
Here is example of error messages with SSD plugged into 3.0 port:
/var/log/messages:Jul 8 22:52:23 rpi5 kernel: [10590.758686] sd 0:0:0:0: [sda] tag#19 uas_eh_abort_handler 0 uas-tag 7 inflight: CMD OUT
/var/log/messages:Jul 8 22:52:23 rpi5 kernel: [10590.758699] sd 0:0:0:0: [sda] tag#19 CDB: opcode=0x2a 2a 00 00 39 10 00 00 00 08 00
/var/log/messages:Jul 8 22:56:10 rpi5 kernel: [10818.604454] sd 0:0:0:0: [sda] tag#19 uas_eh_abort_handler 0 uas-tag 9 inflight: CMD OUT
/var/log/messages:Jul 8 22:56:10 rpi5 kernel: [10818.604466] sd 0:0:0:0: [sda] tag#19 CDB: opcode=0x2a 2a 00 00 32 38 60 00 00 08 00
Re: AData SD600 ssd not working on USB 3 ports
I think I found the issue. The AData SD600 does not seem to support UAS, at least not on the raspberry. The work around is to blacklist UAS for the device. I did this by adding the following argument to the boot command line (/boot/cmdline.txt) and rebooting:
usb-storage.quirks=125f:a68a:u
Where 125f:a68a is the device id from lsusb for the SSD
After reboot dmesg reports UAS is blacklisted:
[ 125.203379] usb 2-1: Product: SD600
[ 125.203391] usb 2-1: Manufacturer: ADATA
[ 125.203402] usb 2-1: SerialNumber: ***************
[ 125.206337] usb 2-1: UAS is blacklisted for this device, using usb-storage instead
[ 125.206428] usb 2-1: UAS is blacklisted for this device, using usb-storage instead
[ 125.206442] usb-storage 2-1:1.0: USB Mass Storage device detected
[ 125.207122] usb-storage 2-1:1.0: Quirks match for vid 125f pid a68a: 800000
[ 125.207251] scsi host0: usb-storage 2-1:1.0
The drive now works without error and is 10 times faster on USB3 than USB2
This cmdline trick also "repaired" my USB3 incompatible enclosure. This topic should be pinned and called "How to make a USB3 incompatible drive work".
I had to do the same to get my SSD to run from a USB3 port. It ran fine on a USB2 port.
SATA controller:
ID 152d:1561 JMicron Technology Corp. JMS561U
SSD:
KINGSTON SA400S37240G; firmware revision SBFKB1D1
SATA controller:
SSD:
Self-education is, I firmly believe, the only kind of education there is - Isaac Asimov
My chip is 152d:0578 - also JMicron
ejjaquay, hallelujah!
Thanks for saving my sanity (even though some may say that it's long gone...)!
I had done a few days of trying to get this to work with different combinations and I was about to order a new, much more expensive SSD box when another user linked me to this thread. JMicron 152d:0578, of course.
I have the SSD on one of the USB 3 ports, a Logitech Unifying on the other (works just as well on the USB 2 port, of course) and a Tellstick Duo on one of the USB 2 ports. I am going to do a few hours boot cycle first of all now. It's based on MQTT, to make it a bit more random. Node-RED connects to the broker and reboots the Pi when it gets a particular signal from any of the Termostats in the Z-Wave network, so it varies between five seconds after Node-RED is started and up to maybe a minute. So far more than 15 reboots without problems. And they're blistering fast compared to both the Pi 3 with SSD and Pi 4 with an SD card.
I think I'm seeing the same problem with my Toshiba drive - in that the symptoms sound the same. It's performance when connected on a USB2 port is as expected (that is, same as the older Pi it replaced) But I face problems when it is connected to USB3 port - I can mount the drive ok, it's recognisable and browsable (Samba) but copying to/from is woefully slow (WAY slower than USB2) and the Pi slowly grounds to a halt.
However, I cannot seem to blacklist UAS for the Toshiba - and I think I've followed the instructions.
lsusb
cmdline.txt
The drive is mounted with the UUID in fstab. I'm not seeing confirmation of the blacklisting in dmesg however. Where am I going wrong?
lsusb
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 003: ID 0480:a20b Toshiba America Inc
Bus 002 Device 002: ID 05e3:0612 Genesys Logic, Inc. Hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
cmdline.txt
dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=PARTUUID=54315418-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
usb-storage.quirks=0480:a20b:u
Thanks, that's given me something to go on. Mine's a SCSI drive and I don't know whether that changes things. I've started a new thread.drgeoff wrote: ↑Thu Jul 18, 2019 8:38 amSee sticky https://www.raspberrypi.org/forums/view ... 8&t=245931
Thanks again for this thread, still very current and helpful.
I've had trouble today with a Crucial BX500 in an external USB enclosure. Worked on USB2, did not work on USB3.
After adding to the cmdline.txt everything appears to be fine now.
I'm now successfully booting off the drive.
After adding
usb-storage.quirks=152d:0578:u
I created an account just to say thank you because I have been looking for a fix for ages.
Same issue with my Samsung SSD 860 EVO (152d:0578 JMicron Technology Corp). It was working for a while since I bought it in January and then out of nowhere started appearing on and off and disappearing in the middle of transfers...
