why does my Raspberry pi 4 shows armv7l at lscpu command?
Architecture: armv7l
Byte Order: Little Endian
CPU(s): 4
On-line CPU(s) list: 0-3
Thread(s) per core: 1
Core(s) per socket: 4
Socket(s): 1
Vendor ID: ARM
Model: 3
Model name: Cortex-A72
Stepping: r0p3
CPU max MHz: 1500.0000
CPU min MHz: 600.0000
BogoMIPS: 108.00
Flags: half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm crc32
uname -a
Linux kalipi-cj 4.19.55-Re4son-v7l+ #1 SMP Sun Jun 30 15:39:30 AEST 2019 armv7l GNU/Linux
shouldn't it say v8 and 64bit somewhere?
root@kalipi-cj:~# cat /proc/cpuinfo
processor : 0
model name : ARMv7 Processor rev 3 (v7l)
BogoMIPS : 108.00
Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm crc32
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 1
BogoMIPS : 108.00
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 2
BogoMIPS : 108.00
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 3
BogoMIPS : 108.00
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
Hardware : BCM2835
Revision : c03111
Serial : 10000000994a9b6c
also the chip number miss matches too the rpi4 should be:
Broadcom BCM2711, Quad core Cortex-A72 (ARM v8) 64-bit SoC @ 1.5GHz
betta fsck yourself before you wreck yo self.
Re: Raspberry pi 4 shows armv7l at lscpu command?
This is normal.
Raspbian is 32 bit and the ARM cores are running 32 bit mode (AArch32) which shows up as armv7.
In the FAQ:
In the FAQ:
Why does cpuinfo report I have a BCM2835?
The upstream Linux kernel developers had decided that all models of Raspberry Pi return bcm2835 as the SoC name. At Raspberry Pi we like to use as much upstream kernel code as possible, as it makes software maintenance much easier, so we use this code. Unfortunately it means that cat /proc/cpuinfo is inaccurate for the Raspberry Pi 2, Raspberry Pi 3 and Raspberry Pi 4, which use the bcm2836/bcm2837, bcm2837 and bcm2711 respectively. You can use cat /proc/device-tree/model to get an accurate description of the SoC on your Pi model.
- DougieLawson
It's a quirk of the way the Linux Kernel (upstream) decided to set things up for ARM processors. The RPF/RP(T) folks could fix it, but they have better, harder, more important, more useful things to spend their time on than wasting it on a cosmetic change.
If you need to know the processor model use cat /sys/firmware/devicetree/base/model;echo
but i have 64 bit kali arm installed...then too?
You've got 32 bit Kali. There is no 64 bit version yet for RPi 4.
That is up to the Kali developers then.
@jamesh
the 64 bit version of kali that i had on my 3b+ loaded just fine into my rpi4 everything works...
i just put the sd card in and bam there it was. then i ran apt update && apt -y full-upgrade, rebooted a few times and still works...??
does this mean it automatically dumbed down because it knew it needed too?
- DougieLawson
I think you'll find that Kali steal all of your hard work in Raspbian Lite for the base of their operating system and then add some hacking tools.
As already explained by others, everything is as expected. The Cortex-A72 processor is listed above and it is running in 32-bit ARMv7 mode. There will likely be multiple 64-bit distributions as soon as a few pesky bugs in the Linux driver stack are ironed out. Fortunately, the current performance is still more than double the previous model and for many tasks about the same as full 64-bit mode anyway.careyjames wrote: ↑Mon Jul 15, 2019 9:07 pmwhy does my Raspberry pi 4 shows armv7l at lscpu command?
CPU(s): 4
Socket(s): 1
Vendor ID: ARM
Model: 3
Stepping: r0p3
BogoMIPS: 108.00
Your guess is as good as mine when the 64-bit kernels will be good enough for a reliable third-party distribution to appear. My guess says sometime between the end of summer and Christmas.
