HankB
TL-WN725N no joy on Buster
Tue Jul 23, 2019 2:25 am
I'm trying to upgrade a Pi 2B to Buster with a clean install. I'm using this TP-Linbk adapter and the LAN is not coming up. I'm working with 2019-07-10-raspbian-buster.img.
I first tried putting wpa_supplicant.conf in the /boot partition:
country=US
update_config=1
network={
    ssid="Giant Voice System"
    scan_ssid=1
    psk="your_real_password"
    key_mgmt=WPA-PSK
(Not actually my real password)
I also tried w/out this and configuring from the GUI. When I click on the up/down arrow icon it reports "No wireless interfaces found." raspi-config->Network Options -> N2 Wi-Fi reports the same.
Other information:
Info from dmesg when I plug in this adapter
[   73.712352] usb 1-1.5: new high-speed USB device number 6 using dwc_otg
[   73.843828] usb 1-1.5: New USB device found, idVendor=0bda, idProduct=8179, bcdDevice= 0.00
[   73.843858] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[   73.843871] usb 1-1.5: Product: 802.11n NIC
[   73.843886] usb 1-1.5: Manufacturer: Realtek
[   73.843916] usb 1-1.5: SerialNumber: 00E04C0001
[   73.936824] lib80211: common routines for IEEE802.11 drivers
[   73.936851] lib80211_crypt: registered algorithm 'NULL'
[   73.967611] r8188eu: module is from the staging directory, the quality is unknown, you have been warned.
[   73.992533] Chip Version Info: CHIP_8188E_Normal_Chip_TSMC_D_CUT_1T1R_RomVer(0)
[   74.029680] usbcore: registered new interface driver r8188eu
[   74.992671] MAC Address = 60:e3:27:1a:08:3e
[   74.996486] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   84.065424] logitech-hidpp-device 0003:046D:1017.0007: HID++ 1.0 device connected.
From lsusb
pi@raspberrypi:~ $ lsusb
Bus 001 Device 006: ID 0bda:8179 Realtek Semiconductor Corp. RTL8188EUS 802.11n Wireless Network Adapter
Bus 001 Device 005: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 004: ID 04d9:0132 Holtek Semiconductor, Inc.
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
pi@raspberrypi:~ $
From network utilities
pi@raspberrypi:~ $ ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether b8:27:eb:aa:e6:2f brd ff:ff:ff:ff:ff:ff
    inet 192.168.1.156/24 brd 192.168.1.255 scope global noprefixroute eth0
    inet6 2601:249:e00:6b24::16a9/128 scope global dynamic noprefixroute
       valid_lft 7038sec preferred_lft 4338sec
    inet6 2601:249:e00:6b24:722f:c402:c3eb:544c/64 scope global dynamic mngtmpaddr noprefixroute
       valid_lft 86388sec preferred_lft 14388sec
    inet6 fe80::2d51:b30b:140a:9dd6/64 scope link
3: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
    link/ether 60:e3:27:1a:08:3e brd ff:ff:ff:ff:ff:ff
pi@raspberrypi:~ $ ifconfig wlan0
wlan0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether 60:e3:27:1a:08:3e  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
pi@raspberrypi:~ $
modules
pi@raspberrypi:~ $ lsmod|egrep "8188|80211"
r8188eu               438272  0
lib80211               16384  1 r8188eu
cfg80211              614400  1 r8188eu
rfkill                 28672  2 cfg80211
pi@raspberrypi:~ $
Firmware
pi@raspberrypi:~ $ dpkg -l firmware-realtek
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name             Version           Architecture Description
ii  firmware-realtek 1:20190114-1+rpt2 all          Binary firmware for Realtek wired/wifi/BT adapters
pi@raspberrypi:~ $
This worked with Stretch with no difficulty. What is needed to get it working with Buster?
Do I need to follow the instructions at https://www.raspberrypi.org/forums/view ... 28&t=62371? Pretty sure I did not need that with Stretch.
Edit: If I plug the card into a Pi 3B I am able to use raspi-config to enter country, SSID and password and bring up the on board WiFi.
MrEngman
Re: TL-WN725N no joy on Buster
Tue Jul 23, 2019 8:37 pm
I've had issues using the built in 8188eu wifi driver with Buster, as others have, but the driver I compile works OK.
You can download the driver from http://downloads.fars-robotics.net/wifi ... u-drivers/.
Download the file with the file name that matches the output from command uname -a, for kernel version and build number.
Untar the file and run the script ./install.sh to install the driver, then reboot to activate it.
Installing my driver will disable the built in r8188eu driver.
MrEngman
HankB
Tue Jul 23, 2019 9:24 pm
Hi MrEngman. Thank you for the help.
The implication of this is that if the kernel is upgraded, then I need to update the drivers as well (until this is fixed.) Is that correct. That is a non-starter for headless systems which is how i operate most of my Pis.
I just tried an install image for Stretch (2019-04-08-raspbian-stretch.img) and this dongle works fine with this image. I guess I'll keep the systems that use this adapter on Stretch for now.
thanks,
hank
Edit.0: https://github.com/raspberrypi/linux/issues/3102
dmtech
Mon Sep 30, 2019 9:54 am
MrEngman
Hi MrEngman,
Your driver works fine for me on Buster (V4.19.66), however the dongle LED no longer works. Is there a way to enable it ?
It would really be useful if it could be configured to flash or not to flash.
MrEngman
Mon Sep 30, 2019 3:34 pm
MrEngman
Hi MrEngman,
Seems like the LED was not enabled in the source I am currently using. I have enabled the LED and recompiled the drivers and tried it on a Pi4 using Buster and the LED is working OK now.
You will need to download and reinstall the driver. I have currently updated drivers for kernel version 4.19.66 and all later versions.
MrEngman
