Samba share whole external drive
What do I have to do to share an whole external USB hard drive with all folders and files via Samba for the network under Raspbian? All the way from installing Samba to setting it up.
Re: Samba share whole external drive
for starters...search the internet regarding installing and configuring samba (believe me, there are numerous sites on the wild wild web)
then read and fully understand the instructions on those web pages
once its up and running and you encounter some road blocks, come back here and some of us will guide you what to do next...
the next move is yours to make...
Some people be like:
As said, follow one of the numerous guides already written. Get it working how you want with 'something' shared from the SD Card, adjust that to share the whole card, then adjust again for sharing the whole external disk.
It is basically -
Repeat the last two until you have it working how you want.
It is basically -
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install samba
sudo smbpasswd -a pi
sudo nano /etc/samba/smb.conf
sudo systemctl restart smbd
Hi there.
For my uses, I set this up to auto mount the USB drive on boot, always to the same location, and share that location in samba (for my windows machines) and in nfs for the linux machines here. I haven't focused on security on the local network, so that's a whole different topic.
This guide is useful for getting samba set up:
https://www.raspberrypi.org/magpi/samba-file-server/
The key for me was making sure that the permissions on the share directory were set correctly. At first I made the share directory with this command, which didn't work even after changing the permissions after the fact:
But if I followed the instructions in the above link when creating the directory, problems went away:
If it's a clean/empty USB drive and you want to format it, you can use gparted. I used the ext4 file format for the USB drive to avoid permissions issues. Since the raspberry pi has the same permissions, it was able to share those permissions over samba and nfs. (Originally I tried using exfat and was able to get either windows samba sharing or nfs sharing working, but struggled to get both working and reliable without gotchas. So ext4 it was.)
This youtube tutorial covered the gparted side of things:
https://www.youtube.com/watch?v=JYvUQXfiTz8
So with the drive mounting, and with smb.conf sharing the mount point, I edited /etc/fstab. I did brick my pi for a brief while with this, so obviously do at your own risk. (FWIW, the nofail part was my lucky fix. with nofail added in my new fstab entry, the pi was unbricked.)
This was the guide I followed for fstab:
https://www.raspberrypi.org/documentati ... storage.md
It's worth noting, though, that umask doesn't work with ext4, so I deviated from the instructions there. This was the link that told me why:
https://ubuntuforums.org/showthread.php?t=1376379
Testing the fstab is worth doing rather than rebooting every time, and you can test the fstab mounting by running:
If that fails, you can test why it failed by using this command:
Which I found in this thread:
https://ubuntuforums.org/showthread.php?t=1294786
After fstab is set up to use the UUID of the external drive, it should auto mount on boot and share over samba.
As I said, do at your own risk, etc. And I make no claims as to the security or safety of these steps!
Hopefully this helps.
mkdir /share
sudo mkdir -m 1777 /share
sudo mount -a
dmesg |tail -20
- DougieLawson
You'll want the drive mounted at boot time. So you either need to add a line to /etc/fstab (complete with the nofail option) or create a Systemd mount file.
You need to find the UUID for the device. Use the blkid command. Note I'm using a root shell started with sudo -s so I don't have to prefix every command with sudo.
Your PARTUUIDs and UUIDs will be hex strings.
So /dev/sda1 is /dev/disk/by-uuid/qqqqqqqq-rrrr-ssss-tttt-uuuuuuuuuuuu
So the /etc/fstab line would look like
Or we can mount with System (the rule is the *.mount file needs to match the mount point name with '/' changed to '-' if needed.
/etc/systemd/system/share.mount
Which you enable (for the next boot) with systemctl enable share.mount and activate with systemctl start share.mount
root@eagle:~# blkid
/dev/mmcblk0p1: LABEL_FATBOOT="boot" LABEL="boot" UUID="xxxx-yyyy" TYPE="vfat" PARTUUID="zzzzzzzz-01"
/dev/mmcblk0p2: UUID="aaaaaaaa-bbbb-cccc-dddd-eeeeeeeeeeee" TYPE="ext2" PARTUUID="zzzzzzzz-02"
/dev/sda1: UUID="qqqqqqqq-rrrr-ssss-tttt-uuuuuuuuuuuu" TYPE="ext2" PARTUUID="aabbccdd-01"
/dev/mmcblk0: PTUUID="zzzzzzzz" PTTYPE="dos"
root@eagle:~#
UUID=qqqqqqqq-rrrr-ssss-tttt-uuuuuuuuuuuu /share ext4 defaults,nofail 0 0
[Unit]
Description=Mount share directory
# Replaces this line in fstab
#UUID=qqqqqqqq-rrrr-ssss-tttt-uuuuuuuuuuuu /share ext4 defaults,notfail 0 0
[Mount]
What=/dev/disk/by-uuid/qqqqqqqq-rrrr-ssss-tttt-uuuuuuuuuu
Where=/share
Type=ext4
Options=defaults
[Install]
WantedBy=multi-user.target
Intro:
This document will explain:
How to install a SAMBA server on Raspbian OS
Mount an external hard drive to Raspbian OS
Maintain mounted hard drive after Pi reboot
Shear external hard drive on SAMBA server
Commands:
SAMBA Install:
sudo apt-get update
sudo service smbd restart
After Hard Drive Mount:
ADD: (at the bottom of the file):
[RaspberryPi NAS]
comment = Pi Server
public = no
writeable = yes
browsable = yes
path = /mnt/external-disk
create mask = 0777
directory mask = 0777
(CTRL+X) then (Y) then (ENTER)
FTFS Support:
sudo apt-get install ntfs-3g
External Hard drive mount:
sudo blkid
sudo mkdir /mnt/external-disk
sudo mount /dev/sda1 /mnt/external-disk
ls /mnt/external-disk/
sudo blkid
sudo nano /etc/fstab
ADD: “UUID=DE94190D9418EA33 /mnt/external-disk NTFS defaults,auto,users,rw,nofail,x-systemd.device-timeout=30,umask=000 0 0” (UUID from the blkid list)
sudo reboot now
Other Commands - In case of errors:
sudo umount /dev/sda1
fstab 2nd option: /dev/sda1 /mnt/location ntfs defaults 0 0
Target is busy:
sudo apt update
sudo apt install lsof
lsof /mnt/location
Commands with explanation:
SAMBA Install:
sudo smbpasswd -a pi (Set SAMBA password)
sudo service smbd restart (Restart service so changes take effect)
sudo blkid (List hard drive partitions and their respective names, this is used for locating and mounting them)
sudo mkdir /mnt/external-disk (Make a folder so the external hard drive can be mounted, this is the location the hard drive files folders/files will show up, a bit like “This PC” in windows.)
sudo mount /dev/sda1 /mnt/external-disk (Mount the hard drive to the new folder, marked in red is the name location of the hard drive you will want to mount, this might change)
Ls /mnt/external-disk/ (Check that the files/folders in the external drive are showing up, you will want to have placed some files in the drive so you can confirm this.)
sudo nano /etc/fstab (This is the file that tells the OS what hard drives to mount on startup)
sudo reboot now (Reboot the Pi to check if this is working)
Ls /mnt/external-disk/ (Again this is used for checking the files/folders)
Commands:
SAMBA Install:
sudo apt-get update
[RaspberryPi NAS]
comment = Pi Server
public = no
writeable = yes
browsable = yes
create mask = 0777
FTFS Support:
sudo blkid
sudo blkid
sudo reboot now
Target is busy:
sudo apt update
lsof /mnt/location
SAMBA Install:
If you run into issues with how clients mount the samba share (under linux), be aware that proper uid and gid are required in order to keep permissions, timestamps and file attributes when copying them to the samba server. In one case I needed to use "gcp" instead of cp to retain my timestamps. I have a rpi_zero client that automatically backs up iphone photos to the samba server, and I needed "gcp" to keep the original timestamps.
In my opinion, you are making the best low-cost, low-power file server there is today. My 1GB RPi4 serves files for me and my family... the same box plays 4k videos on the TV it is attached to, downloads legal-ish torrents and is a sftp and ssh server to the external world (with fail2ban).
I have 2 external drives connect to my RPi4, each configured as samba shares without any issue.
I have 30 minute timers configured locally on the external drives for them to spin down (save power).
I also have one off-site backup (remember to always have 3 copies of all your important data, including one off-site).
Hi
I wondered what script you ran for the 30 min timer to close down the drives?
