tartiflette74
No audio passthrough (DTS) on Pi 4
Wed Sep 04, 2019 6:07 pm
I can't get audio passthrough in Kodi (in system settings > audio, there is a "passthrough" section, but it is empty, nothing to enable in it) nor in VLC (the receivere gets stereo when I select "stereo mode > original", whatever audio device I choose).
Pi 4 (2 GB), official HDMI cable in left HDMI port (I get video but no audio at all when using the other port), latest raspian, kodi 17.6. I'm not using "sync playback to display".
The same video file plays fine with DTS passthrough from a kodi (older version) android player connected to the same home cinema on the same HDMI port.
Here is my current config.txt:
hdmi_force_hotplug=1
hdmi_group=1
hdmi_mode=16
hdmi_ignore_cec_init=1
dtparam=audio=on
no_hdmi_resample=1
hdmi_stream_channels=1
[pi4]
dtoverlay=vc4-fkms-v3d
max_framebuffers=2
[all]
gpu_mem=256
What should I try?
Thasnks!
tartiflette74
Re: No audio passthrough (DTS) on Pi 4
Thu Sep 05, 2019 7:37 am
Not sure if these entries in kodi.log are to be expected:
 NOTICE: ARM Features: Neon disabled
Found 1 Lists of Devices
Enumerated ALSA devices:
    Device 1
        m_deviceName      : @
        m_displayName     : Default (bcm2835 ALSA bcm2835 ALSA)
        m_displayNameExtra:
        m_deviceType      : AE_DEVTYPE_PCM
        m_channels        : FL,FR
        m_sampleRates     : 8000,11025,16000,22050,32000,44100,48000,64000,88200,96000
        m_dataFormats     : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_U8
        m_streamTypes     : No passthrough capabilities
What is wrong? Here is the complete log:
  NOTICE: special://profile/ is mapped to: special://masterprofile/
 NOTICE: -----------------------------------------------------------------------
 NOTICE: Starting Kodi from Debian (17.6 Debian package version: 2:17.6+dfsg1-4+b1). Platform: Linux ARM 32-bit
 NOTICE: Using Release Kodi from Debian x32 build
 NOTICE: Kodi from Debian compiled from 2:17.6+dfsg1-4+b1 by GCC 8.2.0 for Linux ARM 32-bit version 4.18.20 (266772)
 NOTICE: Running on Raspbian GNU/Linux 10 (buster), kernel: Linux ARM 32-bit version 4.19.66-v7l+
 NOTICE: FFmpeg version/source: 4.1.4-1+rpt1~deb10u1
 NOTICE: Host CPU: ARMv7 Processor rev 3 (v7l), 4 cores available
 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi
 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi/addons
 NOTICE: special://masterprofile/ is mapped to: /home/pi/.kodi/userdata
 NOTICE: special://envhome/ is mapped to: /home/pi
 NOTICE: special://home/ is mapped to: /home/pi/.kodi
 NOTICE: special://temp/ is mapped to: /home/pi/.kodi/temp
 NOTICE: special://logpath/ is mapped to: /home/pi/.kodi/temp
 NOTICE: The executable running is: /usr/lib/arm-linux-gnueabihf/kodi/kodi.bin
 NOTICE: Local hostname: raspi
 NOTICE: Log File is located: /home/pi/.kodi/temp//kodi.log
  ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
 NOTICE: load settings...
  ERROR: PulseAudio: Failed to connect context
 NOTICE: PulseAudio might not be running. Context was not created.
 NOTICE: Found 1 Lists of Devices
 NOTICE: Enumerated ALSA devices:
 NOTICE:     Device 1
 NOTICE:         m_deviceName      : @
 NOTICE:         m_displayName     : Default (bcm2835 ALSA bcm2835 ALSA)
 NOTICE:         m_displayNameExtra:
 NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
 NOTICE:         m_channels        : FL,FR
 NOTICE:         m_sampleRates     : 8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000
 NOTICE:         m_dataFormats     : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_U8
 NOTICE:         m_streamTypes     : No passthrough capabilities
 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
 NOTICE: Loaded settings file from special://profile/advancedsettings.xml
 NOTICE: Contents of special://profile/advancedsettings.xml are...
                  <advancedsettings>
                    <video>
                      <!-- cleandatetime: first subpattern returns title, second subpattern returns year; (?:) is a non-capturing parenthesis -->
                      <!-- <cleandatetime>(.*) \((?:.+, )?(19\d\d|20[0-2][0-9])\)\.</cleandatetime> -->
                      <cleandatetime>(.*) \((?:.+, )?(19\d\d|20[0-2][0-9])\)[^\(\)]*\.</cleandatetime>
                      <!-- cleanstrings: match is cleaned, as well as all remaining text on the right -->
                      <cleanstrings action="append">
                        <!-- <regexp>( \(.*\)\.)</regexp> -->
                      </cleanstrings>
                    </video>
                  </advancedsettings>
                  <!-- search for "No information found for item" in kodi.log -->
 NOTICE: Default Video Player: VideoPlayer
 NOTICE: Default Audio Player: paplayer
 NOTICE: Disabled debug logging due to GUI setting. Level 0.
 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
 NOTICE: Loaded playercorefactory configuration
 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
 NOTICE: Running database version Addons27
 NOTICE: ADDONS: Using repository repository.xbmc.org
 NOTICE: Checking resolution 16
 NOTICE: CWinSystemX11GLESContext::CreateNewWindow
 NOTICE: CWinSystemX11GLESContext::GetVisual() m_pGLContext:(nil) GetVisual
 NOTICE: Create new CGLContextEGL at CWinSystemX11GLESContext::CreateNewWindow, m_dpy=0x14f3768
 NOTICE: Using visual 0x21
 NOTICE: GL_VENDOR = Broadcom
 NOTICE: GL_RENDERER = V3D 4.2
 NOTICE: GL_VERSION = OpenGL ES 3.0 Mesa 19.1.0-devel
 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 3.00
 NOTICE: GL_EXTENSIONS = GL_EXT_blend_minmax GL_EXT_multi_draw_arrays GL_EXT_texture_format_BGRA8888 GL_OES_compressed_ETC1_RGB8_texture GL_OES_depth24 GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_mapbuffer GL_OES_rgb8_rgba8 GL_OES_standard_derivatives GL_OES_stencil8 GL_OES_texture_3D GL_OES_texture_float GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_npot GL_OES_vertex_half_float GL_EXT_texture_sRGB_decode GL_OES_EGL_image GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_type_2_10_10_10_REV GL_OES_get_program_binary GL_APPLE_texture_max_level GL_EXT_discard_framebuffer GL_EXT_read_format_bgra GL_EXT_frag_depth GL_NV_fbo_color_attachments GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_vertex_array_object GL_EXT_occlusion_query_boolean GL_EXT_texture_rg GL_EXT_unpack_subimage GL_NV_draw_buffers GL_NV_read_buffer GL_NV_read_depth GL_NV_read_depth_stencil GL_NV_read_stencil GL_EXT_draw_buffers GL_EXT_map_buffer_range GL_KHR_debug GL_KHR_texture_compression_astc_ldr GL_OES_depth_texture_cube_map GL_OES_required_internalformat GL_OES_surfaceless_context GL_EXT_color_buffer_float GL_EXT_sRGB_write_control GL_EXT_separate_shader_objects GL_EXT_shader_integer_mix GL_EXT_base_instance GL_EXT_compressed_ETC1_RGB8_sub_texture GL_EXT_draw_elements_base_vertex GL_EXT_texture_border_clamp GL_KHR_context_flush_control GL_OES_draw_elements_base_vertex GL_OES_texture_border_clamp GL_OES_texture_stencil8 GL_EXT_float_blend GL_KHR_no_error GL_KHR_texture_compression_astc_sliced_3d GL_OES_EGL_image_external_essl3 GL_MESA_shader_integer_functions GL_KHR_parallel_shader_compile GL_EXT_texture_query_lod
  ERROR: GLES: Vertical Blank Syncing unsupported
 NOTICE: Running database version ViewModes6
 NOTICE: Running database version Textures13
 NOTICE: Running database version MyMusic60
 NOTICE: Running database version MyVideos107
 NOTICE: Running database version TV29
 NOTICE: Running database version Epg11
 NOTICE: start dvd mediatype detection
 NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
 NOTICE: UpdateLibraries: Starting video library startup scan
 NOTICE: initialize done
 NOTICE: Running the application...
 NOTICE: starting zeroconf publishing
 NOTICE: CWebServer[8080]: Started
 NOTICE: starting upnp client
  ERROR: JSONRPC Server: Failed to connect to sdpd
 NOTICE: ES: Starting UDP Event server on port 9777
 NOTICE: UDP: Listening on port 9777 (ipv6 : true)
 NOTICE: VideoInfoScanner: Starting scan ..
 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:00
 NOTICE: Skin Helper Backgrounds --> BackgroundsUpdater - started
 NOTICE: Skin Helper Service --> WebService - start helper webservice on port 52307
 NOTICE: Skin Helper Service --> Skin Helper Service version 1.1.3 started
Kendek
Thu Sep 05, 2019 7:53 am
I can't get audio passthrough in Kodi (in system settings > audio, there is a "passthrough" section, but it is empty, nothing to enable in it)...
Just switch to Expert mode...
tartiflette74
Thu Sep 05, 2019 9:00 am
Yes, expert mode enabled (the passthrough section is shown, but empty).
tartiflette74
Thu Sep 05, 2019 9:28 am
In addition, here is the result of tvservice / edidparser (seems to correctly claim DTS support):
Enabling fuzzy format match...
Parsing jerome.edid...
HDMI:EDID version 1.3, 1 extensions, screen size 96x54 cm
HDMI:EDID features - videodef 0x80 !standby !suspend active off; colour encoding:RGB444|YCbCr422; sRGB is not default colourspace; preferred format is native; does not support GTF
HDMI:EDID found monitor range descriptor tag 0xfd
HDMI:EDID monitor range offsets: V min=0, V max=0, H min=0, H max=0
HDMI:EDID monitor range: vertical is 49-61 Hz, horizontal is 15-69 kHz, max pixel clock is 150 MHz
HDMI:EDID monitor range does not support GTF
HDMI:EDID found monitor name descriptor tag 0xfc
HDMI:EDID monitor name is VSX-930
HDMI:EDID found preferred CEA detail timing format: 1920x1080i @ 60 Hz (5)
HDMI:EDID found CEA detail timing format: 720x480p @ 60 Hz (2)
HDMI:EDID established timing I/II bytes are 00 00 00
HDMI:EDID standard timings block x 8: 0x0101 0101 0101 0101 0101 0101 0101 0101
HDMI:EDID parsing v3 CEA extension 0
HDMI:EDID monitor support - underscan IT formats:no, basic audio:yes, yuv444:yes, yuv422:yes, #native DTD:2
HDMI:EDID found CEA detail timing format: 1920x1080i @ 50 Hz (20)
HDMI:EDID found CEA detail timing format: 1280x720p @ 60 Hz (4)
HDMI:EDID found CEA detail timing format: 1280x720p @ 50 Hz (19)
HDMI:EDID found CEA format: code 5, 1920x1080i @ 60Hz (native)
HDMI:EDID found CEA format: code 4, 1280x720p @ 60Hz
HDMI:EDID found CEA format: code 3, 720x480p @ 60Hz
HDMI:EDID found CEA format: code 15, 1440x480p @ 60Hz
HDMI:EDID found CEA format: code 14, 1440x480p @ 60Hz
HDMI:EDID found CEA format: code 7, 1440x480i @ 60Hz
HDMI:EDID found CEA format: code 6, 1440x480i @ 60Hz
HDMI:EDID found CEA format: code 20, 1920x1080i @ 50Hz
HDMI:EDID found CEA format: code 19, 1280x720p @ 50Hz
HDMI:EDID found CEA format: code 18, 720x576p @ 50Hz
HDMI:EDID found CEA format: code 30, 1440x576p @ 50Hz
HDMI:EDID found CEA format: code 29, 1440x576p @ 50Hz
HDMI:EDID found CEA format: code 22, 1440x576i @ 50Hz
HDMI:EDID found CEA format: code 21, 1440x576i @ 50Hz
HDMI:EDID found CEA format: code 11, 2880x480i @ 60Hz
HDMI:EDID found CEA format: code 10, 2880x480i @ 60Hz
HDMI:EDID found CEA format: code 26, 2880x576i @ 50Hz
HDMI:EDID found CEA format: code 25, 2880x576i @ 50Hz
HDMI:EDID found CEA format: code 35, 2880x480p @ 60Hz
HDMI:EDID found CEA format: code 36, 2880x480p @ 60Hz
HDMI:EDID found CEA format: code 37, 2880x576p @ 50Hz
HDMI:EDID found CEA format: code 38, 2880x576p @ 50Hz
HDMI:EDID found CEA format: code 16, 1920x1080p @ 60Hz
HDMI:EDID found CEA format: code 31, 1920x1080p @ 50Hz
HDMI:EDID found CEA format: code 32, 1920x1080p @ 24Hz
HDMI:EDID found CEA format: code 1, 640x480p @ 60Hz
HDMI:EDID found audio format 2 channels PCM, sample rate: 32|44|48|88|96|176|192 kHz, sample size: 16|20|24 bits
HDMI:EDID found audio format 8 channels PCM, sample rate: 32|44|48|88|96|176|192 kHz, sample size: 16|20|24 bits
HDMI:EDID found audio format 6 channels AC3, sample rate: 32|44|48 kHz, bitrate: 640 kbps
HDMI:EDID found audio format 7 channels DTS, sample rate: 44|48|88|96 kHz, bitrate: 1536 kbps
HDMI:EDID found audio format 6 channels One Bit Audio, sample rate: 44 kHz, codec define: 0
HDMI:EDID found audio format 8 channels Dobly Digital+, sample rate: 44|48 kHz, codec define: 1
HDMI:EDID found audio format 8 channels DTS-HD, sample rate: 44|48|88|96|176|192 kHz, codec define: 1
HDMI:EDID found audio format 8 channels MLP, sample rate: 44|48|88|96|176|192 kHz, codec define: 1
HDMI:EDID found HDMI VSDB length 6
HDMI:EDID HDMI VSDB has physical address 2.5.0.0
HDMI:EDID HDMI VSDB supports AI:yes, dual link DVI:no
HDMI:EDID HDMI VSDB deep colour support - 48-bit:no 36-bit:no 30-bit:no DC_yuv444:no
HDMI:EDID HDMI VSDB has no latency information
HDMI:EDID adding mandatory support for DMT (4) 640x480p @ 60Hz
HDMI:EDID adding mandatory support for CEA (17) 720x576p @ 50Hz
HDMI:EDID filtering formats with pixel clock unlimited MHz or h. blanking unlimited
HDMI:EDID best score mode initialised to CEA (1) 640x480p @ 60 Hz with pixel clock 25 MHz (score 0)
HDMI:EDID best score mode is now CEA (1) 640x480p @ 60 Hz with pixel clock 25 MHz (score 61864)
HDMI:EDID best score mode is now CEA (2) 720x480p @ 60 Hz with pixel clock 27 MHz (score 4566472)
HDMI:EDID CEA mode (3) 720x480p @ 60 Hz with pixel clock 27 MHz has a score of 66472
HDMI:EDID CEA mode (4) 1280x720p @ 60 Hz with pixel clock 74 MHz has a score of 3635592
HDMI:EDID DMT mode (4) 640x480p @ 60 Hz with pixel clock 25 MHz has a score of 18432
HDMI:EDID best score mode is now CEA (5) 1920x1080i @ 60 Hz with pixel clock 74 MHz (score 5398248)
HDMI:EDID CEA mode (6) 1440x480i @ 60 Hz with pixel clock 27 MHz has a score of 45736
HDMI:EDID CEA mode (7) 1440x480i @ 60 Hz with pixel clock 27 MHz has a score of 45736
HDMI:EDID CEA mode (10) 2880x480i @ 60 Hz with pixel clock 54 MHz has a score of 45736
HDMI:EDID CEA mode (11) 2880x480i @ 60 Hz with pixel clock 54 MHz has a score of 45736
HDMI:EDID CEA mode (14) 1440x480p @ 60 Hz with pixel clock 54 MHz has a score of 66472
HDMI:EDID CEA mode (15) 1440x480p @ 60 Hz with pixel clock 54 MHz has a score of 66472
HDMI:EDID CEA mode (16) 1920x1080p @ 60 Hz with pixel clock 148 MHz has a score of 273832
HDMI:EDID CEA mode (17) 720x576p @ 50 Hz with pixel clock 27 MHz has a score of 66472
HDMI:EDID CEA mode (18) 720x576p @ 50 Hz with pixel clock 27 MHz has a score of 66472
HDMI:EDID CEA mode (19) 1280x720p @ 50 Hz with pixel clock 74 MHz has a score of 3117160
HDMI:EDID CEA mode (20) 1920x1080i @ 50 Hz with pixel clock 74 MHz has a score of 4232360
HDMI:EDID CEA mode (21) 1440x576i @ 50 Hz with pixel clock 27 MHz has a score of 45736
HDMI:EDID CEA mode (22) 1440x576i @ 50 Hz with pixel clock 27 MHz has a score of 45736
HDMI:EDID CEA mode (25) 2880x576i @ 50 Hz with pixel clock 54 MHz has a score of 45736
HDMI:EDID CEA mode (26) 2880x576i @ 50 Hz with pixel clock 54 MHz has a score of 45736
HDMI:EDID CEA mode (29) 1440x576p @ 50 Hz with pixel clock 54 MHz has a score of 66472
HDMI:EDID CEA mode (30) 1440x576p @ 50 Hz with pixel clock 54 MHz has a score of 66472
HDMI:EDID CEA mode (31) 1920x1080p @ 50 Hz with pixel clock 148 MHz has a score of 232360
HDMI:EDID CEA mode (32) 1920x1080p @ 24 Hz with pixel clock 74 MHz has a score of 124532
HDMI:EDID CEA mode (35) 2880x480p @ 60 Hz with pixel clock 108 MHz has a score of 66472
HDMI:EDID CEA mode (36) 2880x480p @ 60 Hz with pixel clock 108 MHz has a score of 66472
HDMI:EDID CEA mode (37) 2880x576p @ 50 Hz with pixel clock 108 MHz has a score of 66472
HDMI:EDID CEA mode (38) 2880x576p @ 50 Hz with pixel clock 108 MHz has a score of 66472
HDMI0:EDID preferred mode remained as CEA (5) 1920x1080i @ 60 Hz with pixel clock 74 MHz
HDMI:EDID has HDMI support and audio support
/opt/vc/bin/edidparser exited with code 0
Kendek
Thu Sep 05, 2019 12:40 pm
So I think this only works in LibreELEC right now. Currently lot of feature is missing from Kodi if you on Raspbian.
Thu Sep 05, 2019 12:50 pm
As stated ad-infinitum the version of Kodi in the Raspbian Buster repositories is not yet optimised for the Raspberry Pi SBC.
There are various posts regarding "unofficial" releases of latest Kodi release.
Though at present as you rightly concluded LibreElec is the best option.
tartiflette74
Thu Sep 05, 2019 1:19 pm
Thanks for suggesting LibreElec; as this is a "Just enough OS" for Kodi, does this mean that it will be harder to install other things on the Raspberry? I'm currently using samba server, NTFS, ExFAT, jdownloader, Wi-Fi routing (Acces Point), and much more coming, and I'd like to be able to use occasionally GUI Linux applications as well (VLC…)
Or should I try unofficial Kodi 18 ports for raspbian? Which? (I would have thought that these would be less optimized for raspberry…)
Kendek
Thu Sep 05, 2019 1:37 pm
Well, that's why I'm using two RPi4. The LibreELEC is just a read-only system image, with Kodi as a main user interface.
Thu Sep 05, 2019 1:42 pm
LibreElec is not for you then...
...Kodi 18.3
https://www.raspberrypi.org/forums/view ... 8&t=246837
tartiflette74
Fri Sep 06, 2019 2:24 pm
I installed Kodi 18.4 from https://www.raspberrypi.org/forums/view ... 1#p1530531, and passthough and hardware decoding are now working :)
There are some other issues with this build (it only works with the confluence skin, and leave me in a text terminal on exit), but I hope this will soon be fixed!
