kadisi
Oops - unable to determine board type... model: 17
Tue Sep 10, 2019 9:24 am
Hi there,
I'm trying to test my Pi 4. and run:
gpio readall
When I use: "gpio -v" I get:
gpio -v
gpio version: 2.50
Copyright (c) 2012-2018 Gordon Henderson
This is free software with ABSOLUTELY NO WARRANTY.
For details type: gpio -warranty
Raspberry Pi Details:
  Type: Unknown17, Revision: 01, Memory: 0MB, Maker: Sony
  * Device tree is enabled.
  *--> Raspberry Pi 4 Model B Rev 1.1
  * This Raspberry Pi supports user-level GPIO access.
Does anybody knows what I must do?
Re: Oops - unable to determine board type... model: 17
Tue Sep 10, 2019 10:42 am
Old version of the wiring library?
pcmanbob
Tue Sep 10, 2019 11:29 am
Hi.
If you run
sudo apt update
sudo apt full-upgrade
it should update wiring pi
or
you could just update wiringpi with
sudo apt-get install wiringpi
http://wiringpi.com/download-and-install/
Ernst
Tue Sep 10, 2019 12:15 pm
The road to insanity is paved with static ip addresses
wni5378
Mon Feb 24, 2020 3:18 pm
This worked for me. Thanks.
mustash
Thu May 14, 2020 11:43 pm
Worked for me as well !
DemonicTubes
Tue Jun 09, 2020 8:35 pm
Hi.
If you run
sudo apt update
or
This did not work for me but this did:
http://wiringpi.com/wiringpi-updated-to ... rry-pi-4b/
setuid
Sun Nov 08, 2020 9:37 pm
And still, no released sources for that packaged binary, as required by the terms of the LGPL-3.0+ he agreed to when he licensed that distribution.
It shouldn't take months to release source to a binary you've already distributed. That's not how the license works.
DarkElvenAngel
Sun Nov 08, 2020 9:48 pm
That's because Gordon isn't realease anything ATM due the this post http://wiringpi.com/wiringpi-deprecated/ there have been offers of other people taking over.
trejan
Sun Nov 08, 2020 9:57 pm
DanielK? Is that you?
What licensing obligations? He's the author so there are no obligations imposed on him by the license. The license obligations are only for third parties since he's licensing the code to them under the GPL. The only obligation he would have is if there were any GPL licensed contributions but AFAIK he wrote everything himself.
Sun Nov 08, 2020 10:52 pm
Not surprised Gordon gave up with this if the uninformed post above is anything to go by.
hippy
Mon Nov 09, 2020 1:37 pm
Thanks, and for the timely bump, because I just ran into the "unable to determine board type" issue myself. Update instructions there worked a treat for my Pi 4B 1GB. Do they also work for a Pi 400 and CM4 ?
I honestly can't remember, and don't want to flash a new image just to check, but is Gordon's WiringPi and the 'gpio' utility included by default with a Raspberry Pi OS install ?
If it is it might be time to try and find a way to keep it updated to support all the Pi boards as they arrive or, exclude it as deprecated and encourage people towards 'raspi-gpio' use.
hippy
Mon Nov 09, 2020 1:52 pm
I'm sure you are right, but, if his original work was released under some GPL licence, then further work on that creates a derivative work of that, so that would seem to fall under the obligations of the GPL licence. I can see why some would interpret it that way.
I suppose the argument is he didn't create a derivative work from the GPL licensed release, but created a derivative work from something exactly the same which doesn't have a GPL licence. And, as you say, as author he's setting the rules for others who use it, not setting rules for himself.
B.Goode
Mon Nov 09, 2020 1:54 pm
According to the .info manifest on the official Downloads server it is in the Full and Desktop only variants, but not included in Lite.
LeahC
Thu Nov 26, 2020 12:29 pm
I was receiving the same "unable to determine board type" error but i was using an Octporint image.
Update and Upgrade did not fix it.
I eventually worked around it by using raspi-gpio that was installed on the image by default.
Very easy to ise for simple output, help file is available raspi-gpio help
Commands work within crontab to set things up on @reboot / IO in/out and level etc
PhilE
Thu Nov 26, 2020 2:10 pm
raspi-gpio is quite functional now, just don't read the source - it will make your eyes bleed.
6by9
Fri Nov 27, 2020 10:52 am
It's what happens when you let hardware guys write software, and a manager at that! :D
