Hi all,
I got a B3+ with a POE hat where I can't control the fan (both arrived 1 month ago, no old hardware). I read the common threads here and run every search I can in google. But nothing seems to stop the fan from blowing.
I use fresh buster 4.19.57-V7+ # 1244.
I see the overlay rpi-poe.dtbo in /boot/overlay and tried a lot of configuration in the /boot/config.txt. Even editing the overlay or the github overlays won't work.
The output from vcdbg log msd says that the overlay is loaded and the dtparam were fine, but still no change in fan speed.
Pi runs 24/7 with max of 38*Celsius and the fan make incredible noise right at boot.
I need help to stop the noise, please!
POE fan control?
- ShiftPlusOne
Re: POE fan control?
It's noisy at boot and then stops being noisy or it's always noisy? Does the speed get adjusted at all with temperature? I don't think it should be on t all once booted at 38C, but I don't remember the exact behaviour before the driver loads.
On boot ist starts a few seconds with full spin and than came down to a "middle" level with a very little bit of fluctuation.
But it never turns off !
Even blacklist the rpi-poe-fan module stops him from spinnig. It woks like hardwired and not software powered??
I have this behaviour on a set of 8 Raspberry 3b+ with POE.
- ShiftPlusOne
What behaviour would you like? I'll try to reproduce it here and send you my changes. Then we can troubleshoot if it's still not working after that.
Should be completly turned off under 55*celsius. Above that level two steps to maximum spin would be great!
- ShiftPlusOne
When the temperature is under 45 and the fan is on, could you please post the output of these commands?
cat /sys/class/thermal/cooling_device*/cur_state
cat /sys/class/thermal/thermal_zone*/trip*
cat /sys/class/hwmon/hwmon*/*pwm*
vcgencmd measure_temp
cat /boot/config.txt
I'm sorry, I don't know the right way to post the output. May be you can help me out? At first I try it this way:
cur_state, trip* and *pwm* do not exist.
temp=37.6'C
# http://rpf.io/configtxt
#hdmi_safe=1
disable_overscan=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
#dtoverlay=lirc-rpi
dtparam=audio=on
[pi4]
# Enable DRM VC4 V3D driver on top of the dispmanx display stack
dtoverlay=vc4-fkms-v3d
max_framebuffers=2
[all]
#dtoverlay=vc4-fkms-v3d
- ShiftPlusOne
That's fine8686hso wrote:At first I try it this way
That's a problem.8686hso wrote:cur_state, trip* and *pwm* do not exist.
Can you post 'dmesg', 'lsmod', 'uname -a' and 'sudo vcdbg log msg'?
pi@raspberrypi:~ $ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.19.57-v7+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1244 SMP Thu Jul 4 18:45:25 BST 2019
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] cma: Reserved 8 MiB at 0x3ac00000
[ 0.000000] On node 0 totalpages: 242688
[ 0.000000] Normal zone: 2133 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 242688 pages, LIFO batch:63
[ 0.000000] random: get_random_bytes called from start_kernel+0xac/0x4b4 with crng_init=0
[ 0.000000] percpu: Embedded 17 pages/cpu s39488 r8192 d21952 u69632
[ 0.000000] pcpu-alloc: s39488 r8192 d21952 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 240555
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=95da7f7b-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 939088K/970752K available (8192K kernel code, 629K rwdata, 2176K rodata, 1024K init, 821K bss, 23472K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xbb800000 - 0xff800000 (1088 MB)
lowmem : 0x80000000 - 0xbb400000 ( 948 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x(ptrval) - 0x(ptrval) (9184 kB)
.init : 0x(ptrval) - 0x(ptrval) (1024 kB)
.data : 0x(ptrval) - 0x(ptrval) ( 630 kB)
.bss : 0x(ptrval) - 0x(ptrval) ( 822 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 26351 entries in 78 pages
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000018] Switching to timer-based delay loop, resolution 52ns
[ 0.000276] Console: colour dummy device 80x30
[ 0.000295] console [tty1] enabled
[ 0.000337] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000354] pid_max: default: 32768 minimum: 301
[ 0.000692] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000707] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001617] CPU: Testing write buffer coherency: ok
[ 0.002080] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002736] Setting up static identity map for 0x100000 - 0x10003c
[ 0.002886] rcu: Hierarchical SRCU implementation.
[ 0.003692] smp: Bringing up secondary CPUs ...
[ 0.004532] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.005462] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.006332] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.006456] smp: Brought up 1 node, 4 CPUs
[ 0.006468] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.006474] CPU: All CPU(s) started in HYP mode.
[ 0.006479] CPU: Virtualization extensions available.
[ 0.007448] devtmpfs: initialized
[ 0.020674] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.020916] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.020935] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.021524] pinctrl core: initialized pinctrl subsystem
[ 0.022378] NET: Registered protocol family 16
[ 0.025435] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.031202] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.031212] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.031414] Serial: AMBA PL011 UART driver
[ 0.033708] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.068642] bcm2835-dma 3f007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
[ 0.070324] SCSI subsystem initialized
[ 0.070549] usbcore: registered new interface driver usbfs
[ 0.070610] usbcore: registered new interface driver hub
[ 0.070705] usbcore: registered new device driver usb
[ 0.090136] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-07-09 14:40, variant start
[ 0.100396] raspberrypi-firmware soc:firmware: Firmware hash is 6c3fe3f096a93de3b34252ad98cdccadeb534be2
[ 0.111843] clocksource: Switched to clocksource arch_sys_counter
[ 0.200560] VFS: Disk quotas dquot_6.6.0
[ 0.200643] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.200834] FS-Cache: Loaded
[ 0.201046] CacheFiles: Loaded
[ 0.211048] NET: Registered protocol family 2
[ 0.211814] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ 0.211906] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.212017] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.212203] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.212347] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.212394] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.212704] NET: Registered protocol family 1
[ 0.213270] RPC: Registered named UNIX socket transport module.
[ 0.213276] RPC: Registered udp transport module.
[ 0.213282] RPC: Registered tcp transport module.
[ 0.213288] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.215018] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 0.217979] Initialise system trusted keyrings
[ 0.218170] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 0.227984] FS-Cache: Netfs 'nfs' registered for caching
[ 0.228544] NFS: Registering the id_resolver key type
[ 0.228569] Key type id_resolver registered
[ 0.228575] Key type id_legacy registered
[ 0.228592] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.230852] Key type asymmetric registered
[ 0.230862] Asymmetric key parser 'x509' registered
[ 0.230910] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.231068] io scheduler noop registered
[ 0.231075] io scheduler deadline registered (default)
[ 0.231251] io scheduler cfq registered
[ 0.231259] io scheduler mq-deadline registered (default)
[ 0.231266] io scheduler kyber registered
[ 0.233533] bcm2708_fb soc:fb: FB found 1 display(s)
[ 0.292295] Console: switching to colour frame buffer device 240x67
[ 0.325602] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1920x1080
[ 0.327798] bcm2835-rng 3f104000.rng: hwrng registered
[ 0.328098] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 0.328646] vc-sm: Videocore shared memory driver
[ 0.328962] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 0.339955] brd: module loaded
[ 0.350470] loop: module loaded
[ 0.351091] Loading iSCSI transport class v2.0-870.
[ 0.351788] libphy: Fixed MDIO Bus: probed
[ 0.351970] usbcore: registered new interface driver lan78xx
[ 0.352028] usbcore: registered new interface driver smsc95xx
[ 0.352045] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.379909] dwc_otg 3f980000.usb: base=(ptrval)
[ 0.580155] Core Release: 2.80a
[ 0.580166] Setting default values for core params
[ 0.580201] Finished setting default values for core params
[ 0.780514] Using Buffer DMA mode
[ 0.780523] Periodic Transfer Interrupt Enhancement - disabled
[ 0.780528] Multiprocessor Interrupt Enhancement - disabled
[ 0.780536] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.780553] Dedicated Tx FIFOs mode
[ 0.781031] WARN::dwc_otg_hcd_init:1045: FIQ DMA bounce buffers: virt = bad14000 dma = 0xfad14000 len=9024
[ 0.781061] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 0.781069] dwc_otg: Microframe scheduler enabled
[ 0.781127] WARN::hcd_init_fiq:457: FIQ on core 1
[ 0.781139] WARN::hcd_init_fiq:458: FIQ ASM at 80650d3c length 36
[ 0.781151] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
[ 0.781170] dwc_otg 3f980000.usb: DWC OTG Controller
[ 0.781204] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 0.781240] dwc_otg 3f980000.usb: irq 56, io mem 0x00000000
[ 0.781292] Init: Port Power? op_state=1
[ 0.781298] Init: Power Port (0)
[ 0.781560] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.781572] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.781581] usb usb1: Product: DWC OTG Controller
[ 0.781591] usb usb1: Manufacturer: Linux 4.19.57-v7+ dwc_otg_hcd
[ 0.781601] usb usb1: SerialNumber: 3f980000.usb
[ 0.782278] hub 1-0:1.0: USB hub found
[ 0.782335] hub 1-0:1.0: 1 port detected
[ 0.782925] dwc_otg: FIQ enabled
[ 0.782931] dwc_otg: NAK holdoff enabled
[ 0.782937] dwc_otg: FIQ split-transaction FSM enabled
[ 0.782948] Module dwc_common_port init
[ 0.783218] usbcore: registered new interface driver usb-storage
[ 0.783401] mousedev: PS/2 mouse device common for all mice
[ 0.784253] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 0.784469] bcm2835-cpufreq: min=600000 max=1400000
[ 0.784909] sdhci: Secure Digital Host Controller Interface driver
[ 0.784915] sdhci: Copyright(c) Pierre Ossman
[ 0.785300] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
[ 0.785686] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ 0.785807] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.787328] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.787478] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.787690] usbcore: registered new interface driver usbhid
[ 0.787696] usbhid: USB HID core driver
[ 0.788523] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
[ 0.790189] [vc_sm_connected_init]: start
[ 0.801275] [vc_sm_connected_init]: end - returning 0
[ 0.802416] Initializing XFRM netlink socket
[ 0.802441] NET: Registered protocol family 17
[ 0.802563] Key type dns_resolver registered
[ 0.803151] Registering SWP/SWPB emulation handler
[ 0.803793] registered taskstats version 1
[ 0.803813] Loading compiled-in X.509 certificates
[ 0.811179] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 0.811265] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 81, base_baud = 0) is a PL011 rev2
[ 0.813315] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 0.813328] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[ 0.839579] sdhost: log_buf @ (ptrval) (fad13000)
[ 0.875173] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 0.876760] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.878344] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.881187] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 0.888196] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 0.889517] of_cfs_init
[ 0.889613] of_cfs_init: OK
[ 0.890266] Waiting for root device PARTUUID=95da7f7b-02...
[ 0.954761] random: fast init done
[ 0.963582] mmc1: new high speed SDIO card at address 0001
[ 0.978226] mmc0: host does not support reading read-only switch, assuming write-enable
[ 0.982090] mmc0: new high speed SDHC card at address aaaa
[ 0.983270] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
[ 0.986362] mmcblk0: p1 p2
[ 1.012018] Indeed it is in host mode hprt0 = 00021501
[ 1.014849] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.014907] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.015701] devtmpfs: mounted
[ 1.073945] Freeing unused kernel memory: 1024K
[ 1.102274] Run /sbin/init as init process
[ 1.221890] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.222040] Indeed it is in host mode hprt0 = 00001101
[ 1.462257] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[ 1.462272] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.463002] hub 1-1:1.0: USB hub found
[ 1.463094] hub 1-1:1.0: 4 ports detected
[ 1.683998] systemd[1]: System time before build time, advancing clock.
[ 1.781906] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 1.810989] NET: Registered protocol family 10
[ 1.812468] Segment Routing with IPv6
[ 1.856464] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 1.857387] systemd[1]: Detected architecture arm.
[ 1.871415] systemd[1]: Set hostname to <raspberrypi>.
[ 1.883277] systemd[1]: Failed to bump fs.file-max, ignoring: Invalid argument
[ 1.912376] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[ 1.912406] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.917170] hub 1-1.1:1.0: USB hub found
[ 1.917395] hub 1-1.1:1.0: 3 ports detected
[ 2.012008] usb 1-1.3: new full-speed USB device number 4 using dwc_otg
[ 2.157172] usb 1-1.3: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.01
[ 2.157187] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.157196] usb 1-1.3: Product: USB Receiver
[ 2.157205] usb 1-1.3: Manufacturer: Logitech
[ 2.205070] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 2.205094] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 2.686255] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.691962] usb 1-1.1.1: new high-speed USB device number 5 using dwc_otg
[ 2.698787] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.699607] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.699936] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.705322] systemd[1]: Created slice system-getty.slice.
[ 2.706102] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 2.707609] systemd[1]: Created slice User and Session Slice.
[ 2.822517] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
[ 2.822538] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.941507] i2c /dev entries driver
[ 3.087428] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): No External EEPROM. Setting MAC Speed
[ 3.088773] libphy: lan78xx-mdiobus: probed
[ 3.133650] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): int urb period 64
[ 3.558496] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.658877] systemd-journald[110]: Received request to flush runtime journal from PID 1
[ 4.787680] media: Linux media interface: v0.10
[ 4.789298] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.794026] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 4.794056] [vc_sm_connected_init]: start
[ 4.798807] [vc_sm_connected_init]: installed successfully
[ 4.847761] videodev: Linux video capture interface: v2.00
[ 4.923983] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.924032] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.932544] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.957591] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.958916] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.974085] bcm2835_audio soc:audio: card created with 8 channels
[ 4.988618] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 4.988634] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 4.995946] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 4.995966] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 5.010821] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 5.010839] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 5.108332] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.172995] logitech-djreceiver 0003:046D:C52B.0003: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-3f980000.usb-1.3/input2
[ 5.252748] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 5.320537] input: Logitech Unifying Device. Wireless PID:400e Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.2/0003:046D:C52B.0003/0003:046D:400E.0004/input/input0
[ 5.321639] input: Logitech Unifying Device. Wireless PID:400e Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.2/0003:046D:C52B.0003/0003:046D:400E.0004/input/input1
[ 5.323073] input: Logitech Unifying Device. Wireless PID:400e Consumer Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.2/0003:046D:C52B.0003/0003:046D:400E.0004/input/input2
[ 5.324337] hid-generic 0003:046D:400E.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech Unifying Device. Wireless PID:400e] on usb-3f980000.usb-1.3:1
[ 5.338538] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 5.352493] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.355190] usbcore: registered new interface driver brcmfmac
[ 5.615270] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.669752] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Feb 27 2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04
[ 5.687920] random: crng init done
[ 5.687937] random: 7 urandom warning(s) missed due to ratelimiting
[ 5.939620] input: Logitech K400 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.2/0003:046D:C52B.0003/0003:046D:400E.0004/input/input6
[ 5.943104] logitech-hidpp-device 0003:046D:400E.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech K400] on usb-3f980000.usb-1.3:1
[ 7.192034] Under-voltage detected! (0x00050005)
[ 7.915626] uart-pl011 3f201000.serial: no DMA platform data
[ 8.021625] 8021q: 802.1Q VLAN Support v1.8
[ 8.329243] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 8.464754] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.464778] brcmfmac: power management disabled
[ 8.827144] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.827160] 8021q: adding VLAN 0 to HW filter on device eth0
[ 8.828556] lan78xx 1-1.1.1:1.0 eth0: kevent 4 may have been dropped
[ 8.851796] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 14.467188] fuse init (API version 7.27)
[ 14.666345] Bluetooth: Core ver 2.22
[ 14.666488] NET: Registered protocol family 31
[ 14.666498] Bluetooth: HCI device and connection manager initialized
[ 14.666531] Bluetooth: HCI socket layer initialized
[ 14.666547] Bluetooth: L2CAP socket layer initialized
[ 14.666767] Bluetooth: SCO socket layer initialized
[ 14.708129] Bluetooth: HCI UART driver ver 2.3
[ 14.708152] Bluetooth: HCI UART protocol H4 registered
[ 14.708436] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 14.708748] Bluetooth: HCI UART protocol Broadcom registered
[ 15.405312] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 15.405327] Bluetooth: BNEP filters: protocol multicast
[ 15.405355] Bluetooth: BNEP socket layer initialized
[ 15.520172] Bluetooth: RFCOMM TTY layer initialized
[ 15.520209] Bluetooth: RFCOMM socket layer initialized
[ 15.520255] Bluetooth: RFCOMM ver 1.11
pi@raspberrypi:~ $ lsmod
Module Size Used by
rfcomm 49152 4
bnep 20480 2
hci_uart 40960 1
btbcm 16384 1 hci_uart
serdev 20480 1 hci_uart
bluetooth 389120 29 hci_uart,bnep,btbcm,rfcomm
ecdh_generic 28672 1 bluetooth
fuse 110592 3
8021q 32768 0
garp 16384 1 8021q
stp 16384 1 garp
llc 16384 2 garp,stp
evdev 24576 3
joydev 20480 0
hid_logitech_hidpp 36864 0
brcmfmac 311296 0
brcmutil 16384 1 brcmfmac
hid_logitech_dj 20480 0
sha256_generic 20480 0
raspberrypi_hwmon 16384 0
hwmon 16384 1 raspberrypi_hwmon
cfg80211 614400 1 brcmfmac
rfkill 28672 6 bluetooth,cfg80211
bcm2835_codec 36864 0
snd_bcm2835 24576 2
v4l2_mem2mem 24576 1 bcm2835_codec
bcm2835_v4l2 45056 0
snd_pcm 102400 1 snd_bcm2835
bcm2835_mmal_vchiq 32768 2 bcm2835_codec,bcm2835_v4l2
v4l2_common 16384 1 bcm2835_v4l2
videobuf2_dma_contig 20480 1 bcm2835_codec
videobuf2_vmalloc 16384 1 bcm2835_v4l2
snd_timer 32768 1 snd_pcm
videobuf2_memops 16384 2 videobuf2_dma_contig,videobuf2_vmalloc
videobuf2_v4l2 24576 3 bcm2835_codec,bcm2835_v4l2,v4l2_mem2mem
snd 73728 7 snd_timer,snd_bcm2835,snd_pcm
videobuf2_common 45056 4 bcm2835_codec,bcm2835_v4l2,v4l2_mem2mem,videobuf2_v4l2
videodev 200704 6 bcm2835_codec,v4l2_common,videobuf2_common,bcm2835_v4l2,v4l2_mem2mem,videobuf2_v4l2
vc_sm_cma 36864 5 bcm2835_mmal_vchiq
media 36864 2 videodev,v4l2_mem2mem
uio_pdrv_genirq 16384 0
uio 20480 1 uio_pdrv_genirq
fixed 16384 0
i2c_dev 20480 0
ip_tables 24576 0
x_tables 32768 1 ip_tables
ipv6 450560 40
pi@raspberrypi:~ $ uname -a
Linux raspberrypi 4.19.57-v7+ #1244 SMP Thu Jul 4 18:45:25 BST 2019 armv7l GNU/Linux
pi@raspberrypi:~ $ sudo vcdbg log msg
001492.724: brfs: File read: /mfs/sd/config.txt
001493.729: brfs: File read: 1734 bytes
001573.509: brfs: File read: /mfs/sd/config.txt
001794.292: gpioman: gpioman_get_pin_num: pin DISPLAY_DSI_PORT not defined
001796.380: *** Restart logging
001796.446: brfs: File read: 1734 bytes
001826.907: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
001830.118: brfs: File read: /mfs/sd/cmdline.txt
001830.222: Read command line from file 'cmdline.txt':
001830.284: 'dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=PARTUUID=95da7f7b-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles'
001830.603: brfs: File read: 187 bytes
002199.121: brfs: File read: /mfs/sd/kernel7.img
002199.182: Loading 'kernel7.img' to 0x8000 size 0x50de50
002855.477: No kernel trailer - assuming DT-capable
002855.568: brfs: File read: 5299792 bytes
002861.747: brfs: File read: /mfs/sd/bcm2710-rpi-3-b-plus.dtb
002861.811: Loading 'bcm2710-rpi-3-b-plus.dtb' to 0x515e50 size 0x69ca
003016.248: brfs: File read: 27082 bytes
003020.407: brfs: File read: /mfs/sd/config.txt
003021.063: dtparam: audio=on
004995.969: gpioman: gpioman_get_pin_num: pin EMMC_ENABLE not defined
005097.287: Device tree loaded to 0x2eff9100 (size 0x6e25)
005099.886: gpioman: gpioman_get_pin_num: pin SDCARD_CONTROL_POWER not defined
006415.343: vchiq_core: vchiq_init_state: slot_zero = 0xfad80000, is_master = 1
006421.333: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
006427.189: TV service:host side not connected, dropping notification 0x00000002, 0x00000001, 0x00000010
010391.781: TV service:host side not connected, dropping notification 0x00000002, 0x00000001, 0x00000010
010568.482: brfs: File read: 1734 bytes
011478.936: TV service:host side not connected, dropping notification 0x00000001, 0x00000002, 0x00000000
082003.612: TV service:host side not connected, dropping notification 0x00000002, 0x00000001, 0x00000010
087443.054: TV service:host side not connected, dropping notification 0x00000001, 0x00000002, 0x00000000
095010.903: TV service:host side not connected, dropping notification 0x00000002, 0x00000001, 0x00000010
095034.511: TV service:host side not connected, dropping notification 0x00000001, 0x00000002, 0x00000000
103866.963: TV service:host side not connected, dropping notification 0x00000002, 0x00000001, 0x00000010
Wire one or even two diodes in series with the fan and you won't notice the noise or be annoyed by it. I have a Pi4 running flat out doing audio work with a 5V fan in series with two diodes and it keeps the processor below 40degC at all times and I never hear it at all. This is a far more reliable solution than switching the fan on or off when it reaches what is still a 'too hot to touch' temperature.
Always interested in innovative audio startups needing help and investment. Look for InPoSe Ltd or Future Horizons on LinkedIn to find me (same avatar photograph)
- ShiftPlusOne
This is definitely the official PoE HAT?
https://www.raspberrypi.org/products/poe-hat/
It all seems a bit strange.
1) By default, as soon as power is applied, the fan will spin a tiny bit and then turn off until linux takes over. It should be off well before the Linux starts loading.
2) There's no evidence of a HAT being connected in the output
For sure the official one!!!
I will post a picture from the Pi. Had to shrink the picture, because it's to big for upload.
- ShiftPlusOne
Uhoh, I got an idea: I use a modified header between the Pi and the HAT to get access to the GPIO. I think PIN 1, 7 and 9 aren't connected to the POE HAT anymore.2) There's no evidence of a HAT being connected in the output
Which Pins are used by the POE HAT and which are passed through?
- ShiftPlusOne
5V, 3V3, GND, ID_SD, ID_SC
If you didn't connect 3V3 then the microcontroller wouldn't start and take control over the fan or identify itself as a HAT.
Well, that's it. I replaced the header an everything works as expected.
Thanks for fast help. Great!
