Karbono
A copy of the C library was found in an unexpected directory
Mon Dec 10, 2012 8:15 pm
After doing an apt-get update / upgrade, I get this:
A copy of the C library was found in an unexpected directory:
  '/lib/arm-linux-gnueabihf/libc-2.13.so'
It is not safe to upgrade the C library in this situation;
please remove that copy of the C library or get it out of
'/lib/arm-linux-gnueabihf' and try again.
It happens at the end of the upgrade process.
Now I can't install or uninstall anything because apt-get states there are unsolved dependencies. It suggests I run
apt-get -f install
But that doesn't work because
I'm not starting with a clean image, but with one that I'm *almost* certain contains no errors. I would prefer to "save" this installation... Any help is appreciated.
Karbono
Re: A copy of the C library was found in an unexpected direc
Mon Dec 10, 2012 8:18 pm
when I remove /lib/arm-linux-gnueabihf/libc-2.13.so all hell breaks loose and no command works
TarjeiB
Tue Feb 26, 2013 12:17 pm
Same problem. Can't find a fix! I've moved it all over the place with ldconfig and the works, but it will always complain.
rurwin
Tue Feb 26, 2013 12:21 pm
Have you tried apt-get dist-upgrade?
