Michael576
I try to run the mypi_server.pyc and get the RuntimeError: Bad magic number in .pyc file
Sun Oct 13, 2019 2:56 pm
Hi
I would like to operate equipment via internet. I am trying to use MyPi. I have followed instructions on many websites but always get the same error.
Pulling my hair out!!!!
hippy
Re: I try to run the mypi_server.pyc and get the RuntimeError: Bad magic number in .pyc file
Mon Oct 14, 2019 11:18 am
I would expect the error indicates the Python version you are using to run the .pyc file is not the same as the version which created the .pyc file.
This is why it's not recommended to distribute .pyc files as applications.
Using the "file mypi_server.pyc" should hopefully indicate which version of Python the .pyc file was built with.
Mon Oct 14, 2019 11:22 am
You should delete the *.pyc file and run the original program that imports mypi_server.py.
A pyc is a python class file and is created (automagically) when a module is imported. You can't run those things directly.
hippy
Mon Oct 14, 2019 11:28 am
Yes one can, providing the same Python version is used to run the .pyc as the Python version which created it ...
pi@Pi3B:~/tmp $ cat test.py
import xyzzy
pi@Pi3B:~/tmp $ cat xyzzy.py
print("In xyzzy.py")
pi@Pi3B:~/tmp $ python2 test.py
In xyzzy.py
pi@Pi3B:~/tmp $ python2 xyzzy.pyc
In xyzzy.py
pi@Pi3B:~/tmp $ python3 xyzzy.pyc
pi@Pi3B:~/tmp $
hippy
Mon Oct 14, 2019 11:46 am
You are probably using the "python" command rather than "python3" -
http://www.ioslinks.com/mypi/help.html
pi@Pi3B:~/tmp $ wget www.ioslinks.com/mypi/server.zip
 ... snip ...
pi@Pi3B:~/tmp $ unzip server.zip
Archive:  server.zip
  inflating: mypi_server.pyc
  inflating: mypi.cfg
pi@Pi3B:~/tmp $ python mypi_server.pyc
pi@Pi3B:~/tmp $ python3 mypi_server.pyc
MyPi TCP Server v1.6
Loading configuration file: /home/pi/tmp/mypi.cfg
... snip ...
scruss
Mon Oct 14, 2019 12:00 pm
Or you can run the pyc through uncompyle6 and get the source back. Then it should run in any Python 3 inter
Looking at the source, MyPi seems to collect your name, email and IP address if you use their dynamic DNS server. Might be a GDPR stumble if you're in Europe.
Pronouns: he/him
hippy
Mon Oct 14, 2019 12:21 pm
Funnily enough I was just trying that myself.
It is utterly pointless to try and hide pure Python source code by distributing a .pyc file when it can be so easily decompiled.
cd ~
git clone https://github.com/rocky/python-uncompyle6.git
cd python-uncompyle6
pip install -e .
sudo python setup.py install
uncompyle6 -o mypi_server.py mypi_server.pyc
