rwcooper
64-bit ubuntu 19.10 wifi not working
Mon Nov 04, 2019 2:26 pm
Hi, I'm trying to get wifi working under 64-bit ubuntu 19.10 on a RPi 4 - 4GB. Wired ethernet works fine, but the wifi only seems to work if it is also has a wired ethernet connection, that is I can successfully ping the ip address for the wifi connection. If I run raspbain wifi works fine. After installing the server version of ubuntu I installed kunbutu-desktop and wifi worked. I want to run this RPi headless most of the time and occasionally run it with a monitor/keyboard/mouse and kde. I purged network-manager and modified /etc/netplan/50-cloud-init.yaml as shown below.
# This file is generated from information provided by
# the datasource.  Changes to it will not persist across an instance.
# To disable cloud-init's network configuration capabilities, write a file
# /etc/cloud/cloud.cfg.d/99-disable-network-config.cfg with the following:
# network: {config: disabled}
network:
  version: 2
  renderer: networkd
  wifis:
    wlan0:
      dhcp4: no
      dhcp6: no
      addresses: [192.168.32.15/24]
      gateway4: 192.168.32.12
      nameservers:
        addresses: [142.161.130.155,142.161.2.155]
      access-points:
        "mylan":
          password: "secretpasswd"
  ethernets:
    eth0:
      dhcp4: no
      dhcp6: no
      optional: true
      addresses: [192.168.32.16/24]
      nameservers:
I also changed /etc/cloud/cloud.cfg.d/99-disable-network-config.cfg to contain the following.
I ran several commands in hope that someone can help me based on the output from these commands.
# service netplan-wpa@wlan0 status
● netplan-wpa@wlan0.service - WPA supplicant for netplan wlan0
   Loaded: loaded (/lib/systemd/system/netplan-wpa@.service; enabled-runtime; vendor preset: enabled)
   Active: active (running) since Thu 2019-04-11 11:28:41 CDT; 6 months 24 days ago
 Main PID: 1165 (wpa_supplicant)
    Tasks: 1 (limit: 4199)
   CGroup: /system.slice/system-netplan\x2dwpa.slice/netplan-wpa@wlan0.service
           └─1165 /sbin/wpa_supplicant -c /run/netplan/wpa-wlan0.conf -iwlan0
Apr 11 11:28:41 raspberry10 systemd[1]: Started WPA supplicant for netplan wlan0.
Apr 11 11:28:41 raspberry10 wpa_supplicant[1165]: Successfully initialized wpa_supplicant
Nov 04 07:37:21 raspberry10 wpa_supplicant[1165]: wlan0: Trying to associate with SSID 'Northumberlan'
Nov 04 07:37:24 raspberry10 wpa_supplicant[1165]: wlan0: Associated with d8:30:62:2f:9e:9d
Nov 04 07:37:24 raspberry10 wpa_supplicant[1165]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Nov 04 07:37:24 raspberry10 wpa_supplicant[1165]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=CA
Nov 04 07:37:24 raspberry10 wpa_supplicant[1165]: wlan0: WPA: Key negotiation completed with d8:30:62:2f:9e:9d [PTK=CCMP GTK=CCMP]
Nov 04 07:37:24 raspberry10 wpa_supplicant[1165]: wlan0: CTRL-EVENT-CONNECTED - Connection to d8:30:62:2f:9e:9d completed [id=0 id_str=]
# service wpa_supplicant status
● wpa_supplicant.service - WPA supplicant
   Loaded: loaded (/lib/systemd/system/wpa_supplicant.service; enabled; vendor preset: enabled)
   Active: active (running) since Mon 2019-11-04 07:38:01 CST; 35s ago
 Main PID: 1298 (wpa_supplicant)
   CGroup: /system.slice/wpa_supplicant.service
           └─1298 /sbin/wpa_supplicant -u -s -O /run/wpa_supplicant
Nov 04 07:38:00 raspberry10 systemd[1]: Starting WPA supplicant...
Nov 04 07:38:01 raspberry10 wpa_supplicant[1298]: Successfully initialized wpa_supplicant
Nov 04 07:38:01 raspberry10 systemd[1]: Started WPA supplicant.
# netstat -nr
Kernel IP routing table
Destination     Gateway         Genmask         Flags   MSS Window  irtt Iface
0.0.0.0         192.168.32.12   0.0.0.0         UG        0 0          0 wlan0
192.168.32.0    0.0.0.0         255.255.255.0   U         0 0          0 wlan0
# ip route | grep default
default via 192.168.32.12 dev wlan0 proto static
# more /run/netplan/wpa-wlan0.conf
ctrl_interface=/run/wpa_supplicant
network={
  ssid="mylan"
  key_mgmt=WPA-PSK
  psk="secretpassword"
# ifconfig wlan0
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.32.15  netmask 255.255.255.0  broadcast 192.168.32.255
        inet6 fe80::dea6:32ff:fe20:6688  prefixlen 64  scopeid 0x20<link>
        ether dc:a6:32:20:66:88  txqueuelen 1000  (Ethernet)
        RX packets 12  bytes 1676 (1.6 KB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 99  bytes 11039 (11.0 KB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
I don't know what to try next. Any suggestions are greatly appreciated. Hopefully I won't have to start over with a clean install of ubuntu.
Thanks...Randy
Re: 64-bit ubuntu 19.10 wifi not working
Mon Nov 04, 2019 4:25 pm
rwcooper
Mon Nov 04, 2019 5:26 pm
Ok I'll go there.
feelslikeautumn
Mon Nov 04, 2019 6:05 pm
No don't do that.
Somebody on here may very well know the answer. I can tell you how to do it if you are willing to re-install.
If you do want to ask on another site, then Askubuntu.com is the place. Note it is not a forum - strict questions and answers only.
feelslikeautumn
Mon Nov 04, 2019 6:56 pm
Trying to refamiliarise myself with how networking works, there are plenty of useful links out there:
https://askubuntu.com/questions/1033826 ... i-wireless
https://askubuntu.com/questions/1143287 ... rver-18-04
https://askubuntu.com/questions/1122757 ... -and-above
Have a search around if you haven't already done so, you may very well find your answer.
rwcooper
Thu Nov 07, 2019 8:33 pm
No don't do that.
If you could tell me how to do that I would really appreciate it. I'm willing to reinstall...Randy
feelslikeautumn
Sun Nov 10, 2019 10:39 pm
I can only tell you how I install, which is to use the mini iso. Because you have a pi4 and there is no generic kernel for this yet, then it is a bit of an ordeal. I wrote instructions for using the raspi2 kernels with the mini iso here https://ubuntu-mate.community/t/aarch64 ... b/16853/37 . Actually these could be improved since grub2 is now usable with the raspi2 kernels.
The advantage of this is it gives you an install like a normal computer. You can then follow all standard documentation. I normally install via ethernet (but wifi is possible too), install a graphical environment and network manager is there to manage wifi connections. If I drop to a shell or start in a shell then the network connection has always been still managed as far as I can remember. It is certainly something I have never had to think about.
I hope that helps a bit, but I'm sure the actual answer to your problem is in the links I previously provided or a bit more googling about netplan. Good luck!
(p.s. Sorry about the slow reply)
rwcooper
Mon Nov 11, 2019 7:29 pm
Thanks for the replay. I'll play around with it a bit more.
phase
Fri Nov 15, 2019 1:25 am
tis is prolly a bit late but have you solved it yet..
if not are you trying to get it working via the desktop
or the command line with not desktop installed
have a look here for the command line..
https://www.linuxbabe.com/ubuntu/connec ... supplicant
jonah1
Thu Jan 09, 2020 9:30 am
Hey, I got the same problem.
Does anyone have any idea how to solve this problem?
Sincerely yours.
jonah
phase
Thu Jan 09, 2020 11:39 am
i thought it was enabled by default seems you guy`s are having issues try adding this to the "usercfg.txt" file
dtoverlay=pi3-enable-wifi
thatchunkylad198966
Thu Jan 09, 2020 11:49 am
https://ubuntuforums.org/
Way to help, bro. :lol: :?
OP: do what as been said above my reply - hopefully it'll work for you.
[NEW] Ubuntu - CM4/RPi4B custom image(s)! XFCE4, LXQt, i3-WM, WireGuard, Samba, Kodi, Latest MESA graphics drivers!
https://www.raspberrypi.org/forums/viewtopic.php?f=131&t=314419
Thu Jan 09, 2020 11:53 am
Fruits post was from last November, any ranting about content should probably have been done then.
trejan
Thu Jan 09, 2020 12:16 pm
Eh? pi3-enable-wifi? That overlay doesn't exist.
andrum99
Thu Jan 09, 2020 12:52 pm
Ignore that suggestion - wifi is enabled by default.
sciurulus
Sun Feb 16, 2020 1:42 pm
Hi, I got this issue, too. Wifi works fine with Raspian out of the box.
With Ubuntu 19.10, Wifi is not starting out of the box, neither the dhclient -v (or -r -v) hack helps. So it's certainly not a ISP issue. I do not see any errors in the dmesg log or elsewhere. I do not know the new netplug system, so I have no clue how to debug it.
Was the system upgrade that made it work? I'm just asking because I have no cable network and it would require some effort to build one for upgrading.
Thanks for any help!
murraybd
Mon Feb 17, 2020 3:49 pm
Here is an example of how to use netplan to connect to a wireless network.
https://netplan.io/examples#connecting- ... ss-network
Software Engineer at Canonical
Ubuntu Core Developer
Return to “Ubuntu”
