deralbert
Are there BCM2711 ARM Peripherals?
Wed Nov 06, 2019 4:47 pm
Hello everyone,
my question is the following: Where can I find the specifications for Raspberry Pi 4 model B (BCM2711 ARM Peripherals)? A specification that is as informative as the one for BCM2835?
I am particularly interested in the information about the GPIO on the Raspberry Pie 4 model B. I would be happy with something like that screen below. I also know that there is the Raspberry Pi 4 model B's Datasheet, but this datasheet is (very?..) preliminary and lacks the addresses of the general purpouse registers associated with GPIO's. I need this addresses in order to experiment with bare metal. But it would be good if I also had the complete documentation for all peripherals, not just for GPIO's.
Thank you for your answers. Best regards,
deralbert
Excerpt from the BCM2835 ARM Peripherals
trejan
Re: Are there BCM2711 ARM Peripherals?
Wed Nov 06, 2019 6:27 pm
The BCM2711 peripheral documentation hasn't been released yet. It is coming soon etc...
joan
Wed Nov 06, 2019 6:39 pm
The existing peripheral document seems to be correct for the GPIO with one known exception - the pull-ups and pull-downs are controlled differently and may be read as well as written.
The bare metal forum people will know the correct bare metal address.
deralbert
Wed Nov 06, 2019 7:20 pm
So I can then use the addresses from BCM2835? Or should I rather ask in bare metal forum for necessary address?
joan
Wed Nov 06, 2019 7:46 pm
The register offsets and the GPIO peripheral offset from the peripheral's base address is unchanged (apart from the pull registers). The peripheral base address is different for the BCM2711.
Thu Nov 07, 2019 6:49 am
Of course if it just the basic GPIO functions that you need you can access those via /dev/gpiomem. The base address isn't needed, but as mentioned earlier the majority of the offsets are the same for all models of Pi.
Unreadable squiggle
