tvservice -o -v 7
tvservice -p -v 7
On the other hand,
vcgencmd display_power 0
does anyone know what I could do to get this working and whether it is possible to do so or not on the pi 4?
Ta
tvservice -o -v 7
tvservice -p -v 7
They added support for individually turning on/off the HDMI PHYs in the development firmware on 1st November.mohyddin wrote: ↑Tue Nov 19, 2019 12:41 pmOn the other hand,worked but it turned both ports off at the same time.Code: Select all
what about letting us know which cable you're using (is it the official one) and how it looks like when plugged in to HDMI0 and HDMI1 (pictures please)?Tom Austin wrote: ...
5. I don't know if the PI was defective or if the cable was, but the fit was not proper. Every cable I use wiggles and doesn't snap in. Is this normal for micro HDMI? Was it me that damaged the ports by pushing enough for it to snap in? I didn't push that hard. I just want to know what to expect.
I'm using the micro HDMI cable supplied by CanaKit. They graciously sent me another cable, since I couldn't tell whether the PI damaged the cable or vice versa. It doesn't fit HDMI 1 any better than the first one did, which is now damaged.aBUGSworstnightmare wrote: ↑Wed May 06, 2020 5:02 amwhat about letting us know which cable you're using (is it the official one) and how it looks like when plugged in to HDMI0 and HDMI1 (pictures please)?Tom Austin wrote: ...
Why do you want to keep it if it arrived damaged? Have it returned under warranty (o.k. Not possible in case you did the damage).
Should be firm, with a click click as it goes in. If its wiggling it's broken.Tom Austin wrote: ↑Wed May 06, 2020 4:27 pmI'm using the micro HDMI cable supplied by CanaKit. They graciously sent me another cable, since I couldn't tell whether the PI damaged the cable or vice versa. It doesn't fit HDMI 1 any better than the first one did, which is now damaged.aBUGSworstnightmare wrote: ↑Wed May 06, 2020 5:02 amwhat about letting us know which cable you're using (is it the official one) and how it looks like when plugged in to HDMI0 and HDMI1 (pictures please)?Tom Austin wrote: ...
I don't know if the PI arrived damaged or whether I somehow damaged it. I can see a bent pin in HDMI 0, which I"m guessing happened when I plugged in the cable.
This is my fifth PI and I know how to use them, yet this is my first experience with micro HDMI. It wiggled and was not plugged in the slot all the way, leaving a gap about the width of a credit card. This is why I'm asking those with experience to describe how micro HDMI feels and acts when it gets plugged in. Should it be a clean fit, or should I expect it to stick out some and wiggle?
Have you got a picture of the problem? That would be useful.ghochenauer wrote: ↑Thu Jun 18, 2020 9:05 amI have the same problem. Both HDMI micro ports seem to have some extra metal pin on the upper left, causing damage to the cable when inserting it.
