HawaiianPi
hdparm, HDIO_DRIVE_CMD(identify) failed: Invalid argument
Thu Dec 19, 2019 11:13 am
Why does hdparm generate this error when testing SD cards in Buster?
Pi 3B+ with fresh Buster Lite install (no updates):
pi@raspberrypi:~ $ sudo hdparm -tT /dev/mmcblk0
/dev/mmcblk0:
Timing cached reads: 1420 MB in 2.00 seconds = 709.78 MB/sec
Timing buffered disk reads: 68 MB in 3.02 seconds = 22.55 MB/sec
Happens in direct mode as well...
pi@raspberrypi:~ $ sudo hdparm -t --direct /dev/mmcblk0
/dev/mmcblk0:
Timing O_DIRECT disk reads: 68 MB in 3.07 seconds = 22.18 MB/sec
And on the Pi 4B with fully upgraded Raspbian too...
tim@RaspberryPi4B2:~ $ sudo hdparm -t --direct /dev/mmcblk0
/dev/mmcblk0:
Timing O_DIRECT disk reads: 122 MB in 3.03 seconds = 40.23 MB/sec
Doesn't happen when testing USB-SSD.
tim@RaspberryPi4B2:~ $ sudo hdparm -t --direct /dev/sda
/dev/sda:
Timing O_DIRECT disk reads: 974 MB in 3.00 seconds = 324.19 MB/sec
Never saw this error in Jessie or Stretch. Image
amcdonley
Re: hdparm, HDIO_DRIVE_CMD(identify) failed: Invalid argument
Sun Aug 09, 2020 1:26 pm
Aug 2020 - still get this error msg, SD card speed is output ok.
Can't see a way to avoid the error msg.
trejan
Sun Aug 09, 2020 2:11 pm
Ignore that error. hdparm is designed for HDs and assumes the device will support all of the SCSI/ATA commands such as IDENTIFY DRIVE. The SD interface is completely different and doesn't have this command so gives that error. It is harmless.
Looking at the hdparm source, it is trying to work out the size of the drive so it can adjust the amount of data it reads. Larger drive = more data read.
