mojuba
Bluetooth keyboard (solved)
Mon Dec 17, 2012 9:17 pm
Hi!
I have problem connecting a Microsoft Wedge Bluetooth Keyboard.
I'm running Raspbian “wheezy”.
When I use the following bluez commands on a logitech bluetooth keyboard everything works fine.
bluez-simple-agent hci0 7C:1E:52:nn:nn:nn
bluez-test-device trusted 7C:1E:52:nn:nn:nn yes
bluez-test-input connect 7C:1E:52:nn:nn:nn
But when I try the same on MS Wedge Keyboard it failes. No auth PIN prompt are displayed. Just this error:
> bluez-simple-agent hci0 75:EF:82:nn:nn:nn
DisplayPasskey (/org/bluez/1871/hci0/dev_7C:1E:52:nn:nn:nn, 859669)
Creating device failed: org.bluez.Error.AuthenticationFailed: Authentication Failed
When I use command "sudo hidd --search" it connect my MS Wedge Keyboard without auth and it works. But when I reboot the pairing are lost.
How can I get this to work?
Thanks!
/Christian
JPB-HK
Re: Bluetooth keyboard
Tue Dec 18, 2012 4:46 am
mojuba wrote:Hi!
Thanks!
/Christian
I had found this somewhere else and it worked for me:
echo 0000|bluez-simple-agent hci0 7C:1E:52:nn:nn:nn
Then on the keyboard, type ‘0000’ and then press <enter>
Regards,
John
NCR 310 - ZX81 - Apple II+ - Dell/Intel - Mac mini... Raspberry Pi!
mojuba
Tue Dec 18, 2012 5:46 pm
Hi!
Thank you for the reply.
It did not work. I received the same error :(
More tips?
/Christian
Offsite
Thu Jan 03, 2013 2:43 am
Patch the /usr/bin/bluez-simple-agent script. Replace "KeyboardDisplay" with "DisplayYesNo".
mojuba
Thu Jan 03, 2013 8:59 pm
Offsite wrote:Patch the /usr/bin/bluez-simple-agent script. Replace "KeyboardDisplay" with "DisplayYesNo".
Hi!
Thank you so much! It worked like a charm :)
/C
Fallout82
Sun Apr 07, 2013 6:32 am
I am having the exact same problem how do I "patch" bluez simple agent to change that exactly. Any further guidance would be appreciated.
mojuba
Re: Bluetooth keyboard (solved)
Sun Apr 07, 2013 10:17 pm
Hi!
Just edit the script file and change to displayyesno
/C
carlhage
Sat Mar 15, 2014 1:58 am
Thanks! I had trouble getting a Rii Mini bluetooth keyboard to work on the RPi. It would not connect in the bluez-simple-agent hci0 command. But this worked (with one adapter but not another) using the patch described above:
Gadgety
Tue Jun 10, 2014 1:12 pm
@carlhage
Would you mind sharing which BT adapter that worked, please.
donydi
Sun Apr 26, 2015 9:28 pm
mojuba wrote:Hi!
/C
I can edit the file but I cannot save as permission is denied. I can't even set permissions to everyone instead of just owner. The file won't let me, is there another way to do it?
