Hi.
I've been using arduino based boards for a while but now need to use a Pi for my next project so I have a question about fan control.
I am putting together a 3D printer control box and it needs cooling when in use so I was going to hook the fans up to the Pi so I had better control of them.
The fan's I am looking at come as standard(3 pin) or PWM(4 pin).
The fans and the PWM voltage are all 5V.
Looking around for examples I have found most use a 3 pin fan and use a transistor to PWM the voltage to the fan. One example I found for the 4 pin fan was still using a transistor to pulse 5v on the PWM input.
So seeing as the same hardware is required for both options is their any benefit of using a 4 pin fan over a 3 pin fan?
Re: Fan Controller - Which way to do it?
A 3 pin fan doesn't include a PWM input, it does however include a tachometer output (hook that up to your Pi directly and it might not work for long)
55:55:44:44:4C
52:4C:52:42:41
52:4C:52:42:41
I know a 3 Pin fan doesn't have a PWM input but there are numerous examples online of people using a PWM signal from the Pi to pulse the VCC to control fan speed.
Basically I just want to know if using a fan with a separate PWM input has any benefit over just using the PWM signal from the Pi to pulse the VCC?
According to Noctua https://noctua.at/en/nf-s12a-pwm their PWM enabled fan(s) have
"Noctua's novel, custom-designed NE-FD1 PWM IC that integrates Smooth Commutation Drive (SCD) technology. By providing smoother torque impulses, SCD suppresses PWM switching noises and thus makes the fan quieter at low speeds."
Edit - my Pi 4B fan, a Noctua NF-A4x10 5V is either fully on or off, and it's already very very quiet. But I suppose a bigger fan is bound to be louder.
