pi@Pi3B:~ $ uname -a
Linux Pi3B 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l GNU/Linux
pi@Pi3B:~ $ sudo apt-get update
Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
Hit:3 http://packages.microsoft.com/repos/vscode stable InRelease
Reading package lists... Done
pi@Pi3B:~ $ sudo apt-get upgrade
Building dependency tree
Calculating upgrade... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
vlc-bin : Depends: libvlc-bin (= 3.0.8-0+deb10u1+rpt1) but 3.0.8-0+deb10u1+rpt7 is to be installed
vlc-plugin-skins2 : Depends: vlc-plugin-qt (= 3.0.8-0+deb10u1+rpt7) but 3.0.8-0+deb10u1+rpt1 is to be installed
E: Broken packages
pi@Pi3B:~ $
