gkovacsp
could not open moddep file '/lib/modules/4.19.75-v7l+/modules.dep.bin'
Sat Jan 25, 2020 1:42 pm
My Pi has rebooted after many-many weeks due to a power outage. Strange things started to happen.
The first symptom of the problems was that it could not mount cifs mounts from fstab.
$ sudo mount /mnt/nas
mount error: cifs filesystem not supported by the system
mount error(19): No such device
Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
It seems the root of the problem is that the "/lib/modules/4.19.75-v7l+" folder is missing, so there is no way to find the files in it.
$ modprobe cifs
modprobe: ERROR: ../libkmod/libkmod.c:586 kmod_search_moddep() could not open moddep file '/lib/modules/4.19.75-v7l+/modules.dep.bin'
modprobe: FATAL: Module cifs not found in directory /lib/modules/4.19.75-v7l+
Content of the /lib/modules folder, 4.19.75-v7l+ is not there
$ ls /lib/modules/
total 24K
drwxr-xr-x  6 root root 4.0K Jan 21 06:21 ./
drwxr-xr-x 16 root root 4.0K Jan  2 12:14 ../
drwxr-xr-x  3 root root 4.0K Jan 25 12:49 4.19.93+/
drwxr-xr-x  3 root root 4.0K Jan 25 12:49 4.19.93-v7+/
drwxr-xr-x  3 root root 4.0K Jan 25 12:49 4.19.93-v7l+/
drwxr-xr-x  3 root root 4.0K Jan 25 12:49 4.19.93-v8+/
This is my version
$ uname -a
Linux rpi4-ssd 4.19.75-v7l+ #1270 SMP Tue Sep 24 18:51:41 BST 2019 armv7l GNU/Linux
My Pi4 boots from an USB disk, using modification in the SD card's cmdline.txt
cat /boot/cmdline.txt
console=serial0,115200 console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait root=/dev/sda2 rootfstype=ext4 rootwait
Any help from anyone?
I would hate to reinstall everything from scratch...
Re: could not open moddep file '/lib/modules/4.19.75-v7l+/modules.dep.bin'
Sat Jan 25, 2020 6:29 pm
Your /boot folder used to boot the system doesn't match the /boot folder that was mounted when sudo apt upgrade installed the new kernel.
sudo umount /boot
sudo mount /dev/mmcblk0p1 /boot
sudo apt install --reinstall raspberrypi-bootloader
sudo reboot
gkovacsp
Sat Jan 25, 2020 6:51 pm
Thanks a lot! That Worked!
gkovacsp
Sat Feb 08, 2020 3:47 pm
In case others run into the same issue, this is the apt command to fix all, I've added the kernel as well
sudo umount /boot
sudo apt install --reinstall raspberrypi-bootloader raspberrypi-kernel
sudo reboot
DarkoSan
Mon Feb 17, 2020 1:20 pm
Thank you!
It works great!
What things we have to do until we have official USB / SSD Boot support.
sudo umount /boot
sudo reboot
RobCranfill
Wed Dec 16, 2020 8:15 pm
Thanks for the above solution! It does work, but on my Pi it's kinda slow, and I was wondering if there's a reason we can't just copy the files from the SSD card (which is what got the updated boot files) to the SD card (which is what really boots)?
