Double L
VLC player - Full screen doesn't show video
Mon Jan 27, 2020 9:35 pm
I have minor problem with VLC player when it is playing a video in Raspbian. When I click on full screen the player maximises but the video does not appear. Just a black screen is displayed. The audio continues to run.
Has anyone else observed this? :D
rpiMike
Re: VLC player - Full screen doesn't show video
Mon Jan 27, 2020 10:03 pm
Are you using Raspbian Buster fully updated? Which model Pi? What resolutions screen? What format and resolution of video?
Double L
Mon Jan 27, 2020 10:56 pm
I think that Raspbian is fully updated. I recently ran the "sudo apt full-upgrade". How do I check?
Its a RPi 4B. The screen resolution is 1920x1080. I don't think it is something to do with the type of video because it happens with all videos I have tried.
alextoind
Thu Jan 30, 2020 4:47 pm
Hello there,
Same bug here with Raspberry Pi 4B after upgrading packages few days ago.
During the upgrade I've seen some video driver packages, so it may be due to one of those, but it is only affect when VLC is maximised to fullscreen.
Any thoughts?
Double L
Tue Feb 04, 2020 10:01 pm
It is pretty strange. Youtube videos work fine in full screen. So it only seems to be VLC player....
amikot
Sun Feb 23, 2020 2:52 am
Same problem here on RPi 4B - 4GB.
I don't know if it's related, but similar problem have with Minecraft Pi - maximised window is black except the rectangle of original window size, but screen is sized so in full screen I see only part of the Minecraft Pi screen.
Any solution ?
elsen
Sat Mar 28, 2020 5:53 am
I had the same issue, pressing `f` toggle `fullscreen` and I can see the video.
I can't `escape` and leave VLC, everything is black until I restart though.
paololop
Mon Mar 30, 2020 9:00 am
Hello World, same trouble here on a Raspberry pi 4B. I'm trying to watch a 1080 movie on full screen but after a few seconds I fall stuck on a black screen. I'm using the latest release of Rasbian. Thanks for your support!
LegitimateLibrarian
Tue Mar 31, 2020 7:48 pm
Hi all,
I have the same problem, cannot see any video (full mode or not) on Pi 4B 4GB...
Geeviz
Sat Apr 04, 2020 10:35 am
Funny thing though that the intro screens play fully functional fullscreen but the movies not... oh wait i can now play fullscreen movies in VLC even with my windows shared dvd player as well
I have it well working now
at preferences - video I use "open gl video"
"fullscreen default"
"display setting - full screen"
(so that are 3 different options)
at the codes i use
"hardware accelerated auto"
that should be working allright
I am in the house :lol:
mkfyr65z
Sat May 02, 2020 10:24 pm
This is certainly still NOT working.
Loaded 4 movies onto Pi4 and using various suggestions - most notably the latest claiming a fix - and video still blacks out entire screen at Full Screen mode.
Transferred the same movies to the Pi3 and no issues whatsoever.
Geeviz
Sun May 03, 2020 9:32 am
Strange. At my place the black fullscreen problem occurs at the pi 4 and vlc when I run normal dvds. I did my settings tricks and all works well now without problems.
Sun May 03, 2020 9:57 am
sudo apt update; sudo dist-upgrade -y will fix it.
eddie3000
Sat Jun 06, 2020 8:12 am
I had this problem today with everything up to date. I switched hdmi output and fixed the issue. I switched back to the previous hdmi to double check and the black screen problem returned. It seems to work on the hdmi closest to the power conector.
HawaiianPi
Sat Jun 06, 2020 8:56 am
Yes, HDMI-0 is the one you should be using with a single display.
Geeviz
Sat Jun 06, 2020 10:00 am
I have mine (tv) on the hdmi 1. Its the port away from the power connector . It won't even run on hdmi 0
TomPotts
Sat Jun 13, 2020 11:12 pm
I switched hdmi output and fixed the issue... It seems to work on the hdmi closest to the power conector.
This worked for me when all others failed. Thanks!
mahjongg
Sat Jun 13, 2020 11:48 pm
As far as I know, the secondary HDMI port (port1, the right one) should never be used unless you attach two displays, but I might be wrong.
some software upgrades have been done since the release of the RPI4, and behaviour might have been updated since.
in any case, I would always start by using the LEFT (primary) HDMI-0 connector!
HawaiianPi
Sun Jun 14, 2020 12:44 am
I have seen references to fixes, and posts suggesting that either port can be used now, but more often than not, when someone is having trouble, using HDMI-0 solves their problem.
Literally the first time I've heard this. It's always the other way around in posts I've seen (either both ports work, or HDMI-0 works, never only HDMI-1 works). ¯\_(ツ)_/¯
Geeviz
Sun Jun 14, 2020 8:12 am
Hdmi0 works perfect on my normal monitor, but my tv works only at port hdmi 1. thats all :)
Sun Jun 14, 2020 8:23 am
My 1080p FullHD TV works on either HDMi0 or HDMi1
VLC works AOK.
Cellloh
Mon Aug 10, 2020 3:14 pm
For me, switching to OpenGL mode did not work (Raspi4, 8GB, fully updated). Then, it did not even play in window mode (audio playing OK, video flickering between black and the cone).
However, switching to one of the MMAL modes helped. And now, I can switch back to Auto mode, which didn't work before trying OpenGL; but maybe switching to HDMI 0 (next to power) before between OpenGL and MMAL is the explanation for this behaviour.
I hope this helps others running into the same problem creating a more reliable description.
larrykluger
Thu Oct 08, 2020 4:35 pm
RPi 4 8G, Rasputin is completely up to date.
One monitor installed on HDMI-1 (closest to power input)
Same issue -- VLC works fine except that "fullscreen" mode shows blank screen (audio continues to play fine).
Solutions suggested above don't work.
Thank you for suggestions.
Geeviz
Thu Oct 08, 2020 8:25 pm
strange ;)
AkulaMD
Sat Nov 14, 2020 3:56 pm
Same here.
The problem still persists until today even after months worth of update to Raspberry Pi OS.
Anyone found the solution yet?
Raspberry Pi OS (32-bit) with desktop and recommended software
Raspberry Pi 4 Model B 8GB at stock speed (never overclock)
Never overclock your Pi.
Encourage optimization instead.
