I've spent so many hours trying to connect WiFi with my Belkin USB dongle (RTL8192CU chipset) and really can't manage
I hope anyone here my give me a clue
uname:
Linux xxxxxx 4.9.35-v7+ #1014 SMP Fri Jun 30 14:47:43 BST 2017 armv7l GNU/Linux
lsusb
Bus 001 Device 004: ID 050d:2103 Belkin Components F7D2102 802.11n N300 Micro Wireless Adapter v3000 [Realtek RTL8192CU]
lsmod
Module Size Used by
8192cu 582217 0
cfg80211 543027 1 8192cu
iwlist wlan0 scan
Cell 07 - Address: 98:DA:aa:bb:xx:yy
ESSID:"xxxxxxxx"
Protocol:IEEE 802.11bgn
Mode:Master
Frequency:2.432 GHz (Channel 5)
Encryption key:on
Bit Rates:300 Mb/s
Extra:wpa_ie=dd1a0050f20101000050f20202000050f2040050f20201000050f202
IE: WPA Version 1
Group Cipher : TKIP
Pairwise Ciphers (2) : CCMP TKIP
Authentication Suites (1) : PSK
Extra:rsn_ie=30180100000fac020200000fac04000fac020100000fac020000
IE: IEEE 802.11i/WPA2 Version 1
Group Cipher : TKIP
IE: Unknown: DD800050F204104A0001101044000102103B00010310470010876543219ABCDEF0123498DAC46944651021000754502D4C696E6B1023000941726368657220433610240003312E301042000C4172636865722043362076321054000800060050F20400011011000A417263686572433676321008000200001049000600372A000120
Quality=72/100 Signal level=46/100
allow-hotplug wlan0
auto wlan0
# wifi
iface wlan0 inet dhcp
/etc/wpa_supplicant/wpa_supplicant.conf:
network={
ssid="XXXXXXXXX"
psk="XXXXXXX"
wpa_supplicant -i wlan0 -c /etc/wpa_supplicant/wpa_supplicant.conf
(although it says auth_failure I copied and pasted the password...)
Successfully initialized wpa_supplicant
nl80211: send_and_recv->nl_recvmsgs failed: -33
wlan0: Trying to associate with 98:da:bb:aa:XX:YY (SSID='XXXXXXXX' freq=2432 MHz)
wlan0: CTRL-EVENT-DISCONNECTED bssid=98:da:bb:aa:XX:YY reason=0
wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
wlan0: Trying to associate with 98:da:bb:69:XX:YY (SSID='XXXXXXXX' freq=2432 MHz)
wlan0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="XXXXXXXX" auth_failures=1 duration=10 reason=CONN_FAILED
wlan0: CTRL-EVENT-SSID-REENABLED id=0 ssid="XXXXXXXX"
wlan0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="XXXXXXXX" auth_failures=2 duration=23 reason=CONN_FAILED
I really don't know what to try or how to continue... may anyone give me a clue?
Any help will be really appreciated
Merci!
BR,
d.
