I have got a APC Back-UPS ES 500 and its got Data port (so that we can connect it to computer and do power management). APC provides a software named PowerChute for this purpose. I could find this software for windows only.
Is there any other software available for the same purpose which we can install in debian (raspbian)?
Simon Mandy
APC PowerChute for raspberry pi.
http://raspisimon.no-ip.org
Raspberry Pi Model B x 2, Raspberry Pi 2 x 2, Transcend 32GB Class 10, Transcend 16GB Class 10, Transcend 8GB Class 4, Custom 12V 1.5A (stepped down to 5.5V)
- terrycarlin
Re: APC PowerChute for raspberry pi.
There is an open source project to provide a PowerChute like program for APC UPS.
Link to source: http://sourceforge.net/projects/power/f ... 0.2.tar.gz
Check it out and see if it meets your requirements.
If it ain't broke, take it apart and see how it works.
I downloaded that and extracted. Now I have a folder named powerd-2.0.2 and so many files under it (looks like source code). As usual I did 'make' and got error message "make: *** No targets specified and no makefile found. Stop."terrycarlin wrote:There is an open source project to provide a PowerChute like program for APC UPS.
How do install the program?
A quick Google brings up apcupsd (UPS software for APC on armel Debian Squeeze, Wheezy or sid).
My Raspberry Pi Project Page:
https://www.flaminghellmet.com/launch/
- terrycarlin
Standard open source method. cd into the source directory then:sim_tcr wrote:I downloaded that and extracted. Now I have a folder named powerd-2.0.2 and so many files under it (looks like source code). As usual I did 'make' and got error message "make: *** No targets specified and no makefile found. Stop."terrycarlin wrote:There is an open source project to provide a PowerChute like program for APC UPS.
./configure
make install
The make install will build the software and install it.
After the install finishes, you can do a
man powerd
to see how to use it.
I found another one called apcupsd. opened new thread at http://www.raspberrypi.org/phpBB3/viewt ... 63&t=26695
Have you tried installing Network UPS Tools (apt-get install nut)? This should work with the ES 500 using the usbhid-ups driver.sim_tcr wrote:Hello,
Simon Mandy
NUT will monitor the status of the UPS over USB, and shut down the host device when the UPS switches to on battery and/or when the battery is low (typically 10% run time remaining, though this is configurable). Any other networked devices that are running the nut-client (there is a Windows version available) would be considered as slaves to the Pi UPS "master", and would be instructed by the Pi over the network to gracefully shutdown when required, so you can UPS protect multiple devices using NUT with your ES 500.
I'm guessing that's not the right link...sim_tcr wrote:I found another one called apcupsd. opened new thread at http://www.raspberrypi.org/phpBB3/viewt ... 63&t=26695
Cannot edit my original reply. Here is the correct one http://www.raspberrypi.org/phpBB3/viewt ... 63&t=26713milhouse wrote:I'm guessing that's not the right link...sim_tcr wrote:I found another one called apcupsd. opened new thread at http://www.raspberrypi.org/phpBB3/viewt ... 63&t=26695
Hello.......I told you about this yesterday.sim_tcr wrote:I found another one called apcupsd.
yes . I missed that post. thank you anyway.pjc123 wrote:Hello.......I told you about this yesterday.sim_tcr wrote:I found another one called apcupsd.
