peter895
Raspberry pi 4b Kodi HEVC
Thu Mar 26, 2020 4:39 pm
Hello
I'm new to raspberry, I bought pi 4b and installed raspbian, I installed openmediavault in raspbian. Raspbian runs transmission server and kodi. I have a problem with playing HEVC video in kodi.vlc in raspbiane can play HEVC, but if I turn it on in kodi, kodi turns off.
sora03
Re: Raspberry pi 4b Kodi HEVC
Sat Mar 28, 2020 1:57 am
Hello
You should research this on the Kodi forums. I have not used kodi in a while.
It could a segmentation fault, can you try to run kodi on a terminal emulator:
$ kodi
Then try to play the HEVC video, after kodi crashes. Copy the output from that terminal to this thread.
Mastodon: https://mastodon.social/@ssora
gkreidl
Sat Mar 28, 2020 5:48 am
Minimal Kiosk Browser (kweb)
illuminatedc
Fri Oct 02, 2020 7:40 am
Crash Report after running Kodi via Terminal Emulator & playing a MKV movie 1080p HEVC h.265 via Kodi:
pi@raspberrypi:~ $ kodi
rpi_ctrl_ffmpeg_init
id=0x911740f8
setup_io: 00000000 -> 0xad1d9000 (fd:35)
setup_io: 00000000 -> 0xad1c9000 (fd:48)
usrvcsm: [vcsm_malloc_cache]: [16115] [Video Frame]: ioctl mem-alloc FAILED [-1] (hdl: 0)
kodi.bin_v8: src/libavcodec/rpi_ctrl_ffmpeg.c:86: gpu_malloc_uncached_internal: Assertion `p->vcsm_handle' failed.
Aborted (core dumped)
Crash report available at /home/pi/kodi_crashlog-20201002_173516.log
[E] Invalid arguments ' '
Rascas
Fri Oct 02, 2020 11:28 am
id=0x911740f8
If you had read the post before yours, it would be fixed already. Not enough GPU memory.
