kuntaltest
Ubuntu 20.04 64bit Full Desktop on Raspberry Pi 4 Installation and Demo(VIDEO)
Thu Apr 02, 2020 5:20 pm
Excited about Ubuntu 20.04 Focal Fossa? Let’s see what new changes this LTS release will have.
Check out UI demo and Installation Ubuntu 20.04 on Raspberry Pi 4 (VIDEO) on youtube:
https://www.youtube.com/watch?v=RE_6PU7MNKo
New features in Ubuntu 20.04
Since it’s an LTS release, stability is of the upmost importance. Canonical team won’t try any radical changes here. Ubuntu 18.04 LTS users would surely notice the visual changes and performance improvements but I don’t think you’ll see many changes between 19.10 and 20.04.
1. Improved default theme
Canonical is experimenting with themes again. In Ubuntu 19.10, the default Yaru theme introduced a dark version.
Ubuntu 20.04 will also have the dark and light variant of the Yaru theme. However, it will have slightly different look with emphasis on aubergine as second accent color (instead of blue and green).
Ubuntu Yaru Light Dark Theme
Yaru theme dark and light version comaprison
In fact, you don’t need to install GNOME Tweaks to switch between the default theme variants. This option is embed into the Settings application.
2. GNOME 3.36 and all the visual and performance improvements that come with it
Ubuntu 20.04 will have the latest GNOME 3.36 release. This means that all the new features in 3.36 will also be available for Ubuntu 20.04.
For example, you’ll notice a revamped lock screen.
New Login Screen in Ubuntu 20.04 Gnome
New login in Ubuntu 20.04
Though it looks good, I don’t like this new lock screen because the password field is not centrally aligned. The one more good thing is that now you don’t need to scroll down to go to the lock screen anymore. A single click and you’ll be on the login screen.
Getting distracted by desktop notifications? You can utilize the ‘do not disturb’ option to disable the desktop notifications.
3. No Amazon app anymore
For past eight years or so, Ubuntu included an Amazon app installed by default. This so-called Amazon app did nothing but open Amazon website of your country (if there is one) in a web browser with Ubuntu’s affiliate link.
4. Linux Kernel 5.4
Ubuntu 20.04 will feature the latest LTS kernel 5.4. This means that you’ll get native ExFAT support and all the other performance improvements and new hardware supports that come with it.
5. Improved ZFS support
Ubuntu became the first mainstream Linux distribution to introduce ZFS as root with Ubuntu 19.10 release.
While Linus Torvalds may not like ZFS, it is still a popular file system. Ubuntu 20.04 will see improved support for ZFS.
6. WireGuard
Though Ubuntu 20.04 won’t be using kernel 5.6 at least immediately, it is backporting WireGuard in kernel 5.4. WireGuard is the new buzz in VPN industry and thus including WireGuard in its kernel will give some boost to Ubuntu 20.04 in the cloud scenario.
7. No more Python 2
Python 2 was first release in 2000. After twenty years, Python 2 has finally reached end of life.
Ubuntu 20.04 won’t support Python 2 anymore and you’ll have to content yourself with Python 3.
Image download from ubuntu server:
http://cdimage.ubuntu.com/ubuntu-server ... EADER.html
geev03
Re: Ubuntu 20.04 64bit Full Desktop on Raspberry Pi 4 Installation and Demo(VIDEO)
Sat Apr 04, 2020 11:14 am
sudo do-release-upgrade -d
Everything went on smoothly and 'remmina' is, just like in Manjaro but not in Gentoo for me, working ...
sakaki
Sat Apr 04, 2020 6:03 pm
Do I sense an embedded Gentoo bug report? ^-^
OT for this thread - apologies - but I've just built (for Gentoo) net-misc/remmina with appropriate USE flags + deps and pushed the packages to the binhost (and masks etc. to the overlay). Seems to run OK.
To install (assuming you have my gentoo-on-rpi-64bit image), simply do:
demouser@pi64 ~ $ sudo emaint sync --repo genpi64
demouser@pi64 ~ $ sudo emerge -v net-misc/remmina
Please ensure you have closed out any prior-installation instances (use "pkill remmina" to be sure) before testing.
This should install v1.3.10 (v1.4.1 still has a few UI issues) from binary packages, if all is well. Any issues, please report on this thread (in the Gentoo subforum) - thanks!
Best,
sakaki
geev03
Sat Apr 04, 2020 8:20 pm
Best,
sakaki
Extremely grateful for the solution... remmina is working and the screen resolution is also better than the less than full HD I have now in Ubuntu 20.04 :)
belisleian
Sat Apr 11, 2020 12:22 am
Hi, im new to raspberry pi and having couple problems.
I have the 4gb version
1- The date and time at boot is not the good one and giving an error.
When ubuntu 20.04 launche, it shit the good date and time.
2- Im having a spi-2835 could not get clk: -517 error
3- I updated the pi firmware to latest with rasbian.
I coudn't get it overclocked to 2000.
I can up to 1750. Higher it won't launch.
My pi is cooled.
The ubuntu 20.04 seem slow.
Thanks for your help
kuntaltest
Fri Apr 24, 2020 9:25 am
Have you tried latest stable image?
tigernero
Sat Apr 25, 2020 9:29 am
is it possible to find rpi-eeprom packages for ubuntu 20.04 in order to have bootloader updates also on ubuntu server / desktop?
https://www.raspberrypi.org/documentati ... teeprom.md
or is there any other way to keep the pi4 bootloader updated on ubuntu stable for pi4?
embrance
Sat Apr 25, 2020 1:48 pm
Can anyone Clone a clean setup with all the stuff included and make it a bootable ISO?
I always tend to make a srong step and have to try againn and again. Rasbian on its own,with all its problems its a no go for me.
Tried instaaling MATE then lost my WIFi etc.
KALI doesnt boot...
JonG
Sat Apr 25, 2020 5:46 pm
Successfully upgraded my RPi 4 64-bit 19.10 system with MATE desktop to 20.04.
In general I have found that I can get higher overclocking frequencies with 32-bit systems (at best 2050MHz) than 64-bit systems (1900MHz).
The "could not get clk: -517" error message can be prevented by adding:
dtparam=spi=off
to /boot/firmware/usercfg.txt
amol18
Mon May 11, 2020 4:57 am
I managed to get 20.04 working on my raspberry pi 4b 4GB. But the camera does not work, anyone got the camera working, it is not the usb camera. If I try to use is in opencv it produces an error. Do I need to install any other packages to make other devices, gpio, usb devices work with my pi?
SlowMoJoe
Sun May 24, 2020 2:49 pm
Neither will my pi v2 camera nor my pi hq camera work on 20.04 64 bit on a pi 4... Has anyone gotten it working?
re-zero246
Sun Jun 21, 2020 12:14 am
Hi guys,
Is the screen resolution and 3.5mm jack sound working fine for you?
Sideeffect
Sat Jun 27, 2020 11:47 am
With Ubuntu 20.04 with latest 5.4.0-1012-raspi kernel I have only two CPU frequencies working 600mhz and 1850Mhz which is my minimum and maximum.
Is there any way to improve the CPU frequency scaling on Ubuntu so it works more like Raspbian?
pi_life
Sun Jun 28, 2020 11:31 pm
Has anyone managed to get the V3D driver to work? No matter what I do, I cannot get it going. lsmod | grep v3d shows:
v3d 73728 0
gpu_sched 45056 1 v3d
drm 569344 6 gpu_sched,drm_kms_helper,v3d,vc4
Sorry, I had to type by hand, rather than copy and paste.
Glxinfo always shows llvmpipe.
kerry_s
Mon Jun 29, 2020 1:35 am
llvmpipe is the new driver, there moving towards software acceleration only so it won't matter what kind of gpu there is, it will all run the same.
it's work in progress, last i tested it couldn't even get the resolution right.
suggest you file a bug, but desktop is not there priority, there's a reason they call it server img
pi_life
Mon Jun 29, 2020 7:23 am
I will file a bug, sucks though that the "solution" at Canonical is just to disable acceleration.
kerry_s
Mon Jun 29, 2020 8:08 am
no there's acceleration, it's just not going to be "hardware" acceleration. software acceleration is more flexible so they say.
just google it, they did an article on why, i only briefly skimmed it cause ubuntu just no longer interests me.
AIS+ECDIS
Sun Jul 05, 2020 3:16 pm
Does this new version of Ubuntu Linux also work on the Raspberry Pi 4B with 8GB memory?
This because Raspbian Buster Linux 2019 version that worked on my Pi 4B 4GB, did not work on my Pi 4B 8GB model, so I had to install the latest version of Raspbian Buster Linux called RaspiOS from 27th May 2020.
So there are more differences than the amount of memroy alone ;-).
Until now I only used Raspbian (Wheezy, Jessie, Stretch and Buster) Linux and RISC OS at different Pi B models.
Thanks for help.
Henri.
bogorad
Tue Jul 21, 2020 8:10 pm
Have you tried actually using ZFS?
I've got ubuntu-server v20.04, 64-bit installed on my Raspberry-pi 4 with 8 GiB RAM.
As instructed here:
https://ubuntu.com/tutorials/setup-zfs- ... alling-zfs
I installed zfsutils-linux.
But I still get this error:
root@controller:~# /sbin/modprobe zfs
modprobe: FATAL: Module zfs not found in directory /lib/modules/5.4.0-1012-raspi
Any ideas? I thought ZFS was supposed to be working out-of-the-box.
stef70
Wed Jul 22, 2020 12:53 am
I did not try it but the zfs module is available in the kernel 5.4.0-1014-raspi.
I installed that kernel to solve the HW acceleration in OpenGL. That works fine with dtoverlay=vc4-fkms-v3d in usercfg.txt
# glxinfo -B
OpenGL vendor string: Broadcom
OpenGL renderer string: V3D 4.2
OpenGL version string: 2.1 Mesa 20.0.8
OpenGL shading language version string: 1.20
That kernel is not yet in the official package list for Focal but the deb files can be downloaded and installed manually from http://ports.ubuntu.com/ubuntu-ports/po ... nux-raspi/
I just noticed that it was recently replaced by 5.4.0-1015-raspi
stef70
Wed Jul 22, 2020 9:17 am
Also the bug that is currently preventing V3D hw accelerated OpenGL on Ubuntu 20.20 is discussed here: https://bugs.launchpad.net/ubuntu/+sour ... ug/1880125
Return to “Ubuntu”
