Ram.Sh
FFmpeg & v4l2 error: Dequeued v4l2 buffer contains 4177920 bytes, but 4147200 were expected. Flags: 0x00002001
Sun Apr 05, 2020 1:28 pm
following 6by9 huge help and support in making this work I'm trying to capture my GoPro HDMI stream with FFmpeg, the error I get is:
Dequeued v4l2 buffer contains 4177920 bytes, but 4147200 were expected. Flags: 0x00002001.
using PI4 4G Linux raspberrypi 4.19.97-v7l+ #1294 SMP Thu Jan 30 13:21:14 GMT 2020 armv7l GNU/Linux
FFmpeg command is:
ffmpeg -y -f v4l2 -loglevel debug -framerate 30 -s 1920x1080 -i /dev/video0 -t 5 test.mp4
full log is:
ffmpeg version 4.1.4-1+rpt7~deb10u1 Copyright (c) 2000-2019 the FFmpeg developers
  built with gcc 8 (Raspbian 8.3.0-6+rpi1)
  configuration: --prefix=/usr --extra-version='1+rpt7~deb10u1' --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared --libdir=/usr/lib/arm-linux-gnueabihf --cpu=arm1176jzf-s --arch=arm
  WARNING: library configuration mismatch
  avutil      configuration: --prefix=/usr --extra-version='1+rpt7~deb10u1' --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs
  avcodec     configuration: --prefix=/usr --extra-version='1+rpt7~deb10u1' --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs
  avformat    configuration: --prefix=/usr --extra-version='1+rpt7~deb10u1' --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs
  avdevice    configuration: --prefix=/usr --extra-version='1+rpt7~deb10u1' --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs
  avfilter    configuration: --prefix=/usr --extra-version='1+rpt7~deb10u1' --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs
  avresample  configuration: --prefix=/usr --extra-version='1+rpt7~deb10u1' --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs
  swscale     configuration: --prefix=/usr --extra-version='1+rpt7~deb10u1' --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs
  swresample  configuration: --prefix=/usr --extra-version='1+rpt7~deb10u1' --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs
  postproc    configuration: --prefix=/usr --extra-version='1+rpt7~deb10u1' --toolchain=hardened --incdir=/usr/include/arm-linux-gnueabihf --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-omx-rpi --enable-mmal --enable-neon --enable-rpi --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --libdir=/usr/lib/arm-linux-gnueabihf/neon/vfp --cpu=cortex-a7 --arch=armv6t2 --disable-thumb --enable-shared --disable-doc --disable-programs
  libavutil      56. 22.100 / 56. 22.100
  libavcodec     58. 35.100 / 58. 35.100
  libavformat    58. 20.100 / 58. 20.100
  libavdevice    58.  5.100 / 58.  5.100
  libavfilter     7. 40.101 /  7. 40.101
  libavresample   4.  0.  0 /  4.  0.  0
  libswscale      5.  3.100 /  5.  3.100
  libswresample   3.  3.100 /  3.  3.100
  libpostproc    55.  3.100 / 55.  3.100
Splitting the commandline.
Reading option '-y' ... matched as option 'y' (overwrite output files) with argument '1'.
Reading option '-f' ... matched as option 'f' (force format) with argument 'v4l2'.
Reading option '-loglevel' ... matched as option 'loglevel' (set logging level) with argument 'debug'.
Reading option '-framerate' ... matched as AVOption 'framerate' with argument '30'.
Reading option '-s' ... matched as option 's' (set frame size (WxH or abbreviation)) with argument '1920x1080'.
Reading option '-i' ... matched as input url with argument '/dev/video0'.
Reading option '-t' ... matched as option 't' (record or transcode "duration" seconds of audio/video) with argument '5'.
Reading option 'test.mp4' ... matched as output url.
Finished splitting the commandline.
Parsing a group of options: global .
Applying option y (overwrite output files) with argument 1.
Applying option loglevel (set logging level) with argument debug.
Successfully parsed a group of options.
Parsing a group of options: input url /dev/video0.
Applying option f (force format) with argument v4l2.
Applying option s (set frame size (WxH or abbreviation)) with argument 1920x1080.
Opening an input file: /dev/video0.
[video4linux2,v4l2 @ 0x2426220] fd:3 capabilities:85200001
[video4linux2,v4l2 @ 0x2426220] Current input_channel: 0, input_name: Camera 0, input_std: 0
[video4linux2,v4l2 @ 0x2426220] The V4L2 driver changed the pixel format from 0x32315559 to 0x56595559
[video4linux2,v4l2 @ 0x2426220] Trying to set codec:rawvideo pix_fmt:yuv420p
[video4linux2,v4l2 @ 0x2426220] The V4L2 driver changed the pixel format from 0x32315659 to 0x56595559
[video4linux2,v4l2 @ 0x2426220] Trying to set codec:rawvideo pix_fmt:yuv422p
[video4linux2,v4l2 @ 0x2426220] The V4L2 driver changed the pixel format from 0x50323234 to 0x56595559
[video4linux2,v4l2 @ 0x2426220] Trying to set codec:rawvideo pix_fmt:yuyv422
[video4linux2,v4l2 @ 0x2426220] ioctl(VIDIOC_G_PARM): Inappropriate ioctl for device
[video4linux2,v4l2 @ 0x2426220] Time per frame unknown
[video4linux2,v4l2 @ 0x2426220] Dequeued v4l2 buffer contains 4177920 bytes, but 4147200 were expected. Flags: 0x00002001.
Input #0, video4linux2,v4l2, from '/dev/video0':
  Duration: N/A, bitrate: N/A
    Stream #0:0, 0, 1/1000000: Video: rawvideo, 1 reference frame (YUY2 / 0x32595559), yuyv422, 1920x1080 (0x0), 0/1, 1000k tbr, 1000k tbn, 1000k tbc
Successfully opened the file.
Parsing a group of options: output url test.mp4.
Applying option t (record or transcode "duration" seconds of audio/video) with argument 5.
Opening an output file: test.mp4.
[file @ 0x242ae10] Setting default whitelist 'file,crypto'
Stream mapping:
  Stream #0:0 -> #0:0 (rawvideo (native) -> h264 (libx264))
Press [q] to stop, [?] for help
cur_dts is invalid (this is harmless if it occurs once at the start per stream)
    Last message repeated 1926 times
/dev/video0: Invalid data found when processing input
detected 4 logical cores
[graph 0 input from stream 0:0 @ 0x242c6e0] Setting 'video_size' to value '1920x1080'
[graph 0 input from stream 0:0 @ 0x242c6e0] Setting 'pix_fmt' to value '1'
[graph 0 input from stream 0:0 @ 0x242c6e0] Setting 'time_base' to value '1/1000000'
[graph 0 input from stream 0:0 @ 0x242c6e0] Setting 'pixel_aspect' to value '0/1'
[graph 0 input from stream 0:0 @ 0x242c6e0] Setting 'sws_param' to value 'flags=2'
[graph 0 input from stream 0:0 @ 0x242c6e0] Setting 'frame_rate' to value '1000000/1'
[graph 0 input from stream 0:0 @ 0x242c6e0] w:1920 h:1080 pixfmt:yuyv422 tb:1/1000000 fr:1000000/1 sar:0/1 sws_param:flags=2
[format @ 0x242cd50] Setting 'pix_fmts' to value 'yuv420p|yuvj420p|yuv422p|yuvj422p|yuv444p|yuvj444p|nv12|nv16|nv21|yuv420p10le|yuv422p10le|yuv444p10le|nv20le'
[auto_scaler_0 @ 0x242dab0] Setting 'flags' to value 'bicubic'
[auto_scaler_0 @ 0x242dab0] w:iw h:ih flags:'bicubic' interl:0
[format @ 0x242cd50] auto-inserting filter 'auto_scaler_0' between the filter 'Parsed_null_0' and the filter 'format'
[AVFilterGraph @ 0x242bd30] query_formats: 5 queried, 3 merged, 1 already done, 0 delayed
[auto_scaler_0 @ 0x242dab0] picking yuv422p out of 11 ref:yuyv422 alpha:0
[auto_scaler_0 @ 0x242dab0] w:1920 h:1080 fmt:yuyv422 sar:0/1 -> w:1920 h:1080 fmt:yuv422p sar:0/1 flags:0x4
[mp4 @ 0x2427f10] Frame rate very high for a muxer not efficiently supporting it.
Please consider specifying a lower framerate, a different muxer or -vsync 2
[libx264 @ 0x2429350] using mv_range_thread = 88
[libx264 @ 0x2429350] MB rate (8160000000) > level limit (16711680)
[libx264 @ 0x2429350] using cpu capabilities: ARMv6 NEON
[libx264 @ 0x2429350] profile High 4:2:2, level 6.2, 4:2:2 8-bit
[libx264 @ 0x2429350] 264 - core 155 r2917 0a84d98 - H.264/MPEG-4 AVC codec - Copyleft 2003-2018 - http://www.videolan.org/x264.html - options: cabac=1 ref=3 deblock=1:0:0 analyse=0x3:0x113 me=hex subme=7 psy=1 psy_rd=1.00:0.00 mixed_ref=1 me_range=16 chroma_me=1 trellis=1 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=-2 threads=6 lookahead_threads=1 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=2 keyint=250 keyint_min=25 scenecut=40 intra_refresh=0 rc_lookahead=40 rc=crf mbtree=1 crf=23.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 ip_ratio=1.40 aq=1:1.00
Output #0, mp4, to 'test.mp4':
  Metadata:
    encoder         : Lavf58.20.100
    Stream #0:0, 0, 1/1000000: Video: h264 (libx264), 1 reference frame (avc1 / 0x31637661), yuv422p, 1920x1080, 0/1, q=-1--1, 1000k fps, 1000k tbn, 1000k tbc
    Metadata:
      encoder         : Lavc58.35.100 libx264
    Side data:
      cpb: bitrate max/min/avg: 0/0/0 buffer size: 0 vbv_delay: -1
[out_0_0 @ 0x242cc20] EOF on sink link out_0_0:default.
No more output streams to write to, finishing.
frame=    0 fps=0.0 q=0.0 Lsize=       0kB time=00:00:00.00 bitrate=N/A speed=   0x
video:0kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown
Input file #0 (/dev/video0):
  Input stream #0:0 (video): 0 packets read (0 bytes); 0 frames decoded;
  Total: 0 packets (0 bytes) demuxed
Output file #0 (test.mp4):
  Output stream #0:0 (video): 0 frames encoded; 0 packets muxed (0 bytes);
  Total: 0 packets (0 bytes) muxed
0 frames successfully decoded, 0 decoding errors
[AVIOContext @ 0x242aed0] Statistics: 2 seeks, 3 writeouts
the output of ffmpeg -f v4l2 -list_formats all -i /dev/video0:
[video4linux2,v4l2 @ 0xcba1c0] Raw       :       rgb24 :     24-bit RGB 8-8-8 :
[video4linux2,v4l2 @ 0xcba1c0] Raw       :     uyvy422 :           UYVY 4:2:2 :
/dev/video0: Immediate exit requested
in the FFmpeg manual under List device capabilities it shows that the reply of this command should include resolutions which isn't my case, could that be part of the problem?
[video4linux2,v4l2 @ 0xf07d80] Raw : yuyv422 : YUV 4:2:2 (YUYV) : 640x480 160x120 176x144 320x176 320x240 352x288 432x240 544x288 640x360
[video4linux2,v4l2 @ 0xf07d80] Compressed: mjpeg : MJPEG : 640x480 160x120 176x144 320x176 320x240 352x288 432x240 544x288 640x360
my current settings are as follow:
cma=256M
gpu_mem=256
i set EDID for 30 FPS v4l2-ctl --set-edid=file=1080P30EDID.txt --fix-edid-checksums
1080P30EDID.zip
(375 Bytes) Downloaded 30 times
CTA-861 Header
  IT Formats Underscanned: yes
  Audio:                   yes
  YCbCr 4:4:4:             no
  YCbCr 4:2:2:             no
HDMI Vendor-Specific Data Block
  Physical Address:        3.0.0.0
  YCbCr 4:4:4 Deep Color:  no
  30-bit:                  no
  36-bit:                  no
  48-bit:                  no
CTA-861 Video Capability Descriptor
  RGB Quantization Range:  yes
  YCC Quantization Range:  no
  PT:                      Supports both over- and underscan
  IT:                      Supports both over- and underscan
  CE:                      Supports both over- and underscan
and set v4l2-ctl --set-dv-bt-timings query
BT timings set
I've searched the web for a solution that i can solve on my own without any success, some say that using 720P could fix that but i can't find any EDID file for 720P@30FPS.
Many thanks in advance for your support!
Best,
Ram
6by9
Re: FFmpeg & v4l2 error: Dequeued v4l2 buffer contains 4177920 bytes, but 4147200 were expected. Flags: 0x00002001
Sun Apr 05, 2020 2:26 pm
Sorry, this is ffmpeg being over enthusiastic.
The hardware requires an alignment to 16 lines under some conditions, even if the number of active pixels within the buffer is lower than that. The video codecs are a prime example of that as they work on macroblocks of 16x16. The selection api is then used to define the number of active pixels.
1080 is not a multiple of 16, so it is rounded up to 1088 lines.
1920*1080*2 (yuyv is 16bpp) = 4147200
1920*1088*2 = 4177920
A bigger buffer is sufficient to carry the image described, but ffmpeg uses = instead of >=, and complains.
Ram.Sh
Sun Apr 05, 2020 3:01 pm
thank you for your quick reply!!!
i tried to suppress FFmpeg error handling with ignore_err but that didn't change anything.
so I gather there's no solution for that besides tweaking the FFmpeg code? if that's the case what I can use instead of FFmpeg to capture/hold in a ramdisk a buffer for the last 30 seconds of the camera stream (equivalents to FFmpeg's “Circular Buffer” if I remember correctly)?
6by9
Mon Apr 06, 2020 10:06 am
It's a one line change
https://github.com/FFmpeg/FFmpeg/blob/m ... 4l2.c#L540
        if (s->frame_size > 0 && buf.bytesused != s->frame_size) {
            av_log(ctx, AV_LOG_WARNING,
                   "Dequeued v4l2 buffer contains %d bytes, but %d were expected. Flags: 0x%08X.\n",
                   buf.bytesused, s->frame_size, buf.flags);
            buf.bytesused = 0;
That first line becomes
        if (s->frame_size > 0 && buf.bytesused < s->frame_size) {
See https://www.raspberrypi.org/forums/view ... 8&t=199775 for quick instructions on building FFmpeg.
I thought we'd dropped the padding from the Unicam driver, but that might be for the 5.4 version that is being finalised at the moment.
Otherwise reset it down to 1 at https://github.com/raspberrypi/linux/bl ... cam.c#L129
Ram.Sh
Mon Apr 06, 2020 11:15 am
thank you for the links!
Can you pls help me and confirm the steps I think need to be done:
1. download the FFmpeg code from Github
2. change the line as your instruction
3. save the FFmpeg files as ffmpeg-4.0.2.tar.bz2
4. create folder /home/pi/Vidware_Downloads and copy ffmpeg-4.0.2.tar.bz2 there
5. remove the line from the Build FFmpeg and mpv script:
wget -q --show-progress --no-use-server-timestamps https://ffmpeg.org/releases/ffmpeg-4.0.2.tar.bz2
6. run script
is that correct?
not sure what to do with the following:
6by9 wrote: I thought we'd dropped the padding from the Unicam driver, but that might be for the 5.4 version that is being finalised at the moment.
lastly, but most important, although I'm currently using PI4, the final setup is supposed to be powered by Pi Zero/w, would it all work on the zero as well?
