ejolson
Memory Bandwidth of the Pi 4B
Thu Apr 16, 2020 3:02 am
I ran John McCalpin's classic stream program for measuring memory-bandwidth from
https://www.cs.virginia.edu/stream/
on the Pi 4B with 2GB of RAM and obtained
$ gcc -O3 -mtune=native -march=native -o stream.10M stream.c
$ ./stream.10M
STREAM version $Revision: 5.10 $
This system uses 8 bytes per array element.
Array size = 10000000 (elements), Offset = 0 (elements)
Memory per array = 76.3 MiB (= 0.1 GiB).
Total memory required = 228.9 MiB (= 0.2 GiB).
Each kernel will be executed 10 times.
 The *best* time for each kernel (excluding the first iteration)
 will be used to compute the reported bandwidth.
Your clock granularity/precision appears to be 1 microseconds.
Each test below will take on the order of 58407 microseconds.
   (= 58407 clock ticks)
Increase the size of the arrays if this shows that
you are not getting at least 20 clock ticks per test.
WARNING -- The above is only a rough guideline.
For best results, please be sure you know the
precision of your system timer.
Function    Best Rate MB/s  Avg time     Min time     Max time
Copy:            5311.6     0.032188     0.030123     0.048096
Scale:           5581.7     0.029104     0.028665     0.032257
Add:             4562.3     0.052809     0.052605     0.053455
Triad:           4380.8     0.054941     0.054784     0.055248
Solution Validates: avg error less than 1.000000e-13 on all three arrays
Similar runs were performed on earlier models of Pi, a first generation Ryzen desktop computer and some others. The results summarized are
                   Copy    Scale      Add    Triad
PIII 650MHz       175.2    176.1    203.6    200.8
Athlon 1400MHz    507.1    634.1    692.8    692.7
Pi B+             738.7    222.2    306.5    293.4
Pi Zero           838.5    290.5    398.4    385.7
Pi 2B v1.1       2021.9   1041.3    739.0    581.9
Pi 3B+           2683.8   2500.2   2216.0   1962.2
Pi 4B 2GB        5311.6   5581.7   4562.3   4380.8
Pi 4B 4GB        5511.8   5531.7   4835.8   4829.5
Odroid N2        6868.2   6854.6   6665.7   6715.2
Jetson Nano      7170.4   6753.6   7145.0   7015.7
i3 550 3.2GHz    7992.4   7838.9   8747.0   8692.6
Xeon Gold 6162  10211.3  11678.0  13283.3  13097.5
Ryzen7 1700     28368.6  17044.8  18710.6  18770.3
Do the 1GB and 4GB models of Pi 4B have the same memory bandwidth as the 2GB model tested here?
I find it amazing how the speed of memory in computers has changed over time and would be very happy if someone could run the same test on the Nvidia Jetson Nano for comparison along with any other ARM-based single-board computers that are available. Results for IBM Power9, as well as a best-effort Pi 4B overclock would also be great.
Edit: Updated with results for the Pi Zero, the Odroid N2, the Jetson Nano, the Pi 4B with 4GB RAM and the Pi 2B.
jahboater
Re: Memory Bandwidth of the Pi 4B
Thu Apr 16, 2020 3:39 am
Here are some results:
Pi4 4GB (stock speed, GCC 9.3)
$ ./stream.10M
Each test below will take on the order of 59444 microseconds.
   (= 59444 clock ticks)
Copy:            5511.8     0.029078     0.029029     0.029128
Scale:           5531.7     0.028962     0.028924     0.029019
Add:             4835.8     0.049655     0.049630     0.049684
Triad:           4829.5     0.049721     0.049695     0.049770
and for the Odroid N2 (stock speed, GCC 9.3):
$ ./stream.10M
Each test below will take on the order of 33980 microseconds.
   (= 33980 clock ticks)
Copy:            6868.2     0.023330     0.023296     0.023350
Scale:           6854.6     0.023356     0.023342     0.023371
Add:             6665.7     0.036027     0.036005     0.036095
Triad:           6715.2     0.035799     0.035740     0.036150
for the Pi Zero (stock speed, GCC 6.3)
$ ./stream.10M
Each test below will take on the order of 568083 microseconds.
   (= 568083 clock ticks)
Copy:             838.5     0.190989     0.190806     0.191115
Scale:            290.5     0.551285     0.550845     0.551427
Add:              398.4     0.602703     0.602377     0.603549
Triad:            385.7     0.622724     0.622290     0.622985
Heater
Thu Apr 16, 2020 3:46 am
$ uname -a
Linux jetson-nano 4.9.140-tegra #1 SMP PREEMPT Mon Dec 9 22:47:42 PST 2019 aarch64 aarch64 aarch64 GNU/Linux
dlinano@jetson-nano:~/stream$ make clean
rm -f stream_f.exe stream_c.exe *.o
gcc -O3 stream.c -o stream_c.exe
dlinano@jetson-nano:~/stream$ ./stream_c.exe
Each test below will take on the order of 25575 microseconds.
   (= 25575 clock ticks)
Copy:            7170.4     0.023451     0.022314     0.025240
Scale:           6753.6     0.025202     0.023691     0.028262
Add:             7145.0     0.036036     0.033590     0.038900
Triad:           7015.7     0.036885     0.034209     0.038899
ejolson
Thu Apr 16, 2020 4:46 am
Wow! That was fast! I'll update the first post with the new numbers.
Thanks! It looks like the 4GB Pi 4B might be slightly faster than the 2GB model. I wonder if that is simply random measurement error or whether there is a slight difference with the memory timings. On the other hand, maybe it is the effects of gcc version 9.3. I used the system compiler--gcc version 8.3 in Raspbian--for the tests with the 2GB model.
Hm. I just tried gcc version 9.2 on the Pi 4B with 2GB and the results are the same as for the system compiler. I don't have 9.3 installed.
Heater
Thu Apr 16, 2020 6:21 am
I notice that code is written to be able to make use of OpenMP. Using OpenMP gives a nice boost:
$ uname -a
gcc -O3 -fopenmp stream.c -o stream_c.exe
Number of Threads requested = 4
Number of Threads counted = 4
Each test below will take on the order of 20647 microseconds.
   (= 20647 clock ticks)
Copy:           10828.4     0.016232     0.014776     0.019214
Scale:          10685.1     0.016704     0.014974     0.019135
Add:             8791.6     0.028727     0.027299     0.031163
Triad:           8664.6     0.030757     0.027699     0.032986
jahboater
Thu Apr 16, 2020 10:09 am
I doubt gcc 9.3 vs 9.2 would make any difference, just a bug fix release.
I should note that the Pi4 4GB is running the 64-bit kernel (which may be faster with large memory usage).
(and also I am running the experimental 5.4 kernel).
Here is the Pi4 4GB result with the 32-bit kernel.
$ uname -a
Linux raspberrypi 5.4.29-v7l+ #1304 SMP Tue Apr 7 18:38:20 BST 2020 armv7l GNU/Linux
$ ./stream.10M
Each test below will take on the order of 57377 microseconds.
   (= 57377 clock ticks)
Copy:            5497.0     0.029177     0.029107     0.029200
Scale:           5562.7     0.028820     0.028763     0.028871
Add:             4834.1     0.049665     0.049647     0.049695
Triad:           4831.4     0.049688     0.049675     0.049714
Larger sized memory and SD cards may be faster because it is split over multiple chips which may be accessed in parallel.
ejolson
Thu Apr 16, 2020 9:35 pm
$ uname -a
$ ./stream.10M
I'm do not think the SD card would affect this RAM speed test, however, you may be right that the 4GB memory chip has an internal structure that is more parallel by design. It looks like you are getting about 10% more memory bandwidth on the triad test. Could you verify there are no special RAM or schmoo settings in config.txt?
See, for example,
viewtopic.php?t=6201&start=1000#p893286
jahboater
Thu Apr 16, 2020 9:55 pm
Definitely not ....
I don't think the schmoo stuff is applicable to the Pi4 anyway.
The only memory setting for this headless Pi4 is "gpu_mem=16" which I shouldn't think matters.
I have today received a new 2GB Pi4, so soon I'll try and verify the difference here.
ejolson
Thu Apr 16, 2020 10:22 pm
Definitely not ....
Thanks for checking. It's too bad there are no schmoo settings for the Pi 4B, as I remember them being very good--better than sliced bread.
Maybe that's something enjoyable to read during the quarantine, which so far has been a disappointment for me due to a persistent cough. Fortunately, my cough seems only bronchitis now getting better. I wish everyone were as lucky.
As suggested above where
I'm now running stream compiled as
$ gcc -O3 -march=native -mtune=native \
-fopenmp -o streamomp.10M stream.c
with OpenMP enabled and getting some strange results on the 4B. I'll post as soon as I verify what's going on.
Note that stream timings with OpenMP for many systems appear as part of Michael Larabel's open benchmarking
https://openbenchmarking.org/test/pts/stream-1.3.1
In my opinion, it is also important to have the single-core results to understand how total memory bandwidth and cache is matched to number of cores.
ejolson
Fri Apr 17, 2020 2:02 am
Here are the results I obtained when running the OpenMP version of stream on the Pi 4B 2GB and the Pi 3B+ using taskset to choose the number of cores on which to run. For example,
$ taskset -c 0,1 ./streamomp.10M
runs the program on two cores. Three runs were performed for each test and only the best plotted. The results are
For many SMP architectures the total aggregate memory bandwidth increases as more cores are selected. Surprisingly, this seems not to be the case for the either of the Pi models, except with Add and Triad on the Pi 3B+ when moving from 1 to 2 cores. On the other hand, it is nice to see some decreasing graphs during these days of exponential growth and infection. I suspect the decrease in bandwidth for the Pi is a shared cache effect. That is, the cache is divided between the different cores and this results in a larger number of stalls when fetching data from main memory.
Would anyone like to profile the stream program with the Linux performance counters to verify what's happening?
It would also be interesting to see what happens when the script
#!/bin/bash
cpuset="0"
for i in 1 2 3 4
do
    echo Running on CPUs $cpuset ...
    taskset -c $cpuset ./streamomp.10M
    cpuset="$cpuset,$i"
done
is run three times on the Jetson Nano for comparison.
Heater
Fri Apr 17, 2020 4:18 am
$ uname -a
dlinano@jetson-nano:~/stream$ gcc -Wall -O3 -fopenmp -o streamomp.10M stream.c
stream.c: In function ‘mysecond’:
stream.c:424:13: warning: variable ‘i’ set but not used [-Wunused-but-set-variable]
         int i;
dlinano@jetson-nano:~/stream$ ./run.sh ; ./run.sh ; ./run.sh
Running on CPUs 0 ...
Number of Threads requested = 1
Number of Threads counted = 1
Each test below will take on the order of 26298 microseconds.
   (= 26298 clock ticks)
Copy:            7325.7     0.022007     0.021841     0.022323
Scale:           7328.7     0.022122     0.021832     0.023336
Add:             7270.3     0.033175     0.033011     0.033609
Triad:           7235.5     0.033546     0.033170     0.035344
Running on CPUs 0,1 ...
Number of Threads requested = 2
Number of Threads counted = 2
Each test below will take on the order of 21574 microseconds.
   (= 21574 clock ticks)
Copy:            9638.6     0.016671     0.016600     0.016836
Scale:           9655.4     0.016620     0.016571     0.016750
Add:             8156.6     0.029746     0.029424     0.031254
Triad:           8116.3     0.029667     0.029570     0.029740
Running on CPUs 0,1,2 ...
Number of Threads requested = 3
Number of Threads counted = 3
Each test below will take on the order of 18723 microseconds.
   (= 18723 clock ticks)
Copy:           10090.2     0.015904     0.015857     0.015953
Scale:          10138.7     0.015853     0.015781     0.016147
Add:             8667.7     0.027854     0.027689     0.028733
Triad:           8655.2     0.027884     0.027729     0.028096
Running on CPUs 0,1,2,3 ...
Each test below will take on the order of 19763 microseconds.
   (= 19763 clock ticks)
Copy:           10894.8     0.014873     0.014686     0.015956
Scale:          10967.1     0.014635     0.014589     0.014680
Add:             8884.3     0.027369     0.027014     0.029035
Triad:           8889.6     0.027352     0.026998     0.029121
Each test below will take on the order of 25851 microseconds.
   (= 25851 clock ticks)
Copy:            7376.3     0.021878     0.021691     0.022711
Scale:           7407.4     0.021736     0.021600     0.022116
Add:             7318.4     0.033250     0.032794     0.034416
Triad:           7279.8     0.033131     0.032968     0.033497
Each test below will take on the order of 21566 microseconds.
   (= 21566 clock ticks)
Copy:            9705.2     0.016618     0.016486     0.016930
Scale:           9705.2     0.016717     0.016486     0.017850
Add:             8165.8     0.029591     0.029391     0.030675
Triad:           8174.7     0.029525     0.029359     0.030020
Each test below will take on the order of 19167 microseconds.
   (= 19167 clock ticks)
Copy:           10102.3     0.015917     0.015838     0.015980
Scale:          10137.4     0.015915     0.015783     0.016778
Add:             8674.6     0.027888     0.027667     0.028522
Triad:           8648.9     0.027829     0.027749     0.027946
Each test below will take on the order of 20539 microseconds.
   (= 20539 clock ticks)
Copy:           10903.7     0.014744     0.014674     0.014797
Scale:          10987.4     0.014682     0.014562     0.015124
Add:             8879.3     0.027226     0.027029     0.028272
Triad:           8900.1     0.027262     0.026966     0.028233
Each test below will take on the order of 25820 microseconds.
   (= 25820 clock ticks)
Copy:            7399.8     0.021951     0.021622     0.023257
Scale:           7399.5     0.021755     0.021623     0.022091
Add:             7316.6     0.033276     0.032802     0.035188
Triad:           7282.3     0.033113     0.032957     0.033262
Each test below will take on the order of 21511 microseconds.
   (= 21511 clock ticks)
Copy:            9672.2     0.016599     0.016542     0.016700
Scale:           9683.5     0.016725     0.016523     0.017887
Add:             8190.5     0.029505     0.029302     0.030065
Triad:           8148.6     0.029553     0.029453     0.029721
Each test below will take on the order of 18769 microseconds.
   (= 18769 clock ticks)
Copy:           10084.4     0.015916     0.015866     0.016007
Scale:          10140.0     0.015832     0.015779     0.016003
Add:             8655.6     0.027944     0.027728     0.028976
Triad:           8657.6     0.027838     0.027721     0.027922
Each test below will take on the order of 18656 microseconds.
   (= 18656 clock ticks)
Copy:           10894.8     0.014779     0.014686     0.014848
Scale:          11030.6     0.014603     0.014505     0.014679
Add:             8886.6     0.027161     0.027007     0.027520
Triad:           8865.9     0.027461     0.027070     0.029704
Mo' cores, mo' better.
ejolson
Fri Apr 17, 2020 4:54 am
That data looks good. Here is the graph:
Note the Add curve is mostly obscured by the Triad results. For good measure, I tested a 6-core Xeon E5-1650 v3 and obtained another increasing graph.
I wonder why the Pi computers show a decreasing bandwidth. Could a dose of hydroxychloroquine or remdesivir be responsible? At least the Xeon E5 is plateauing. Maybe the Pi 4B would also show an increasing trend with the 64-bit kernel or the 4GB model.
Heater
Fri Apr 17, 2020 8:04 am
Pi 4, 4GB, Raspbian:
pi@pi4:~/stream $ uname -a
Linux pi4 4.19.97-v7l+ #1294 SMP Thu Jan 30 13:21:14 GMT 2020 armv7l GNU/Linux
pi@pi4:~/stream $ free -h
              total        used        free      shared  buff/cache   available
Mem:          3.8Gi        89Mi       3.6Gi       8.0Mi       101Mi       3.6Gi
Swap:          99Mi          0B        99Mi
pi@pi4:~/stream $ gcc -Wall -O3 -fopenmp -o streamomp.10M stream.c
         int i;
stream.c: In function ‘checkSTREAMresults’:
stream.c:479:42: warning: format ‘%lu’ expects argument of type ‘long unsigned int’, but argument 2 has type ‘unsigned int’ [-Wformat=]
   printf("WEIRD: sizeof(STREAM_TYPE) = %lu\n",sizeof(STREAM_TYPE));
                                        %u
pi@pi4:~/stream $ ./run.sh
Each test below will take on the order of 56854 microseconds.
   (= 56854 clock ticks)
Copy:            5525.8     0.028980     0.028955     0.029035
Scale:           5552.3     0.028866     0.028817     0.028969
Add:             4883.8     0.049168     0.049142     0.049222
Triad:           4875.8     0.049259     0.049223     0.049300
Each test below will take on the order of 60302 microseconds.
   (= 60302 clock ticks)
Copy:            4479.8     0.037653     0.035716     0.039994
Scale:           3701.9     0.043908     0.043221     0.045058
Add:             3990.2     0.060244     0.060148     0.060330
Triad:           4055.9     0.059286     0.059173     0.059328
Each test below will take on the order of 61237 microseconds.
   (= 61237 clock ticks)
Copy:            3394.8     0.049149     0.047131     0.050778
Scale:           3356.3     0.049299     0.047672     0.050476
Add:             3413.4     0.070756     0.070311     0.071169
Triad:           3380.4     0.071438     0.070997     0.072346
Each test below will take on the order of 58586 microseconds.
   (= 58586 clock ticks)
Copy:            3670.1     0.044410     0.043596     0.045814
Scale:           3678.2     0.045179     0.043499     0.046334
Add:             3392.6     0.072850     0.070741     0.074430
Triad:           3342.5     0.075828     0.071802     0.082318
pi@pi4:~/stream $
Technocolour
Fri Apr 17, 2020 8:37 am
Thank you for your effort with the data, everyone! :)
It's interesting.
Heater
Fri Apr 17, 2020 8:42 am
Pi 4, 4GB, Raspbian 64 bit (nspawn):
$ uname -a
Linux debian-buster-64 4.19.97-v8+ #1294 SMP PREEMPT Thu Jan 30 13:27:08 GMT 2020 aarch64 GNU/Linux
pi@debian-buster-64:~/stream $ free -h
Mem:          3.7Gi       119Mi       3.1Gi       8.0Mi       503Mi       3.5Gi
Swap:          99Mi          0B        99Mi
pi@debian-buster-64:~/stream $ gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/aarch64-linux-gnu/8/lto-wrapper
Target: aarch64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Debian 8.3.0-6' --with-bugurl=file:///usr/share/doc/gcc-8/README.Bugs --enable-languages=c,ada,c++,go,d,fortran,objc,obj-c++ --prefix=/usr --with-gcc-major-version-only --program-suffix=-8 --program-prefix=aarch64-linux-gnu- --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --enable-bootstrap --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-libquadmath --disable-libquadmath-support --enable-plugin --enable-default-pie --with-system-zlib --disable-libphobos --enable-multiarch --enable-fix-cortex-a53-843419 --disable-werror --enable-checking=release --build=aarch64-linux-gnu --host=aarch64-linux-gnu --target=aarch64-linux-gnu
Thread model: posix
gcc version 8.3.0 (Debian 8.3.0-6)
pi@debian-buster-64:~/stream $ gcc -Wall -O3 -fopenmp -o streamomp.10M stream.c
         int i;
pi@debian-buster-64:~/stream $ ./run.sh ; ./run.sh ; ./run.sh
Each test below will take on the order of 59629 microseconds.
   (= 59629 clock ticks)
Copy:            5426.1     0.029606     0.029487     0.030237
Scale:           5506.8     0.029117     0.029055     0.029254
Add:             4736.1     0.050715     0.050675     0.050739
Triad:           4694.3     0.051198     0.051126     0.051331
Each test below will take on the order of 62619 microseconds.
   (= 62619 clock ticks)
Copy:            4219.1     0.039184     0.037923     0.040375
Scale:           3711.7     0.043809     0.043107     0.044489
Add:             3908.9     0.061444     0.061398     0.061506
Triad:           3961.5     0.060630     0.060583     0.060691
Each test below will take on the order of 60485 microseconds.
   (= 60485 clock ticks)
Copy:            3540.1     0.045948     0.045197     0.047625
Scale:           3473.5     0.046372     0.046063     0.046612
Add:             3268.0     0.073785     0.073440     0.074125
Triad:           3437.7     0.070172     0.069815     0.070442
Each test below will take on the order of 59525 microseconds.
   (= 59525 clock ticks)
Copy:            3451.6     0.046944     0.046355     0.047843
Scale:           3718.8     0.044152     0.043025     0.045274
Add:             3291.4     0.073877     0.072917     0.075240
Triad:           3253.0     0.074533     0.073779     0.075255
Each test below will take on the order of 59698 microseconds.
   (= 59698 clock ticks)
Copy:            5417.5     0.029607     0.029534     0.029730
Scale:           5504.7     0.029112     0.029066     0.029197
Add:             4725.9     0.050832     0.050784     0.050911
Triad:           4679.5     0.051316     0.051288     0.051430
Each test below will take on the order of 62061 microseconds.
   (= 62061 clock ticks)
Copy:            4147.2     0.039571     0.038580     0.041167
Scale:           3716.6     0.043713     0.043050     0.044059
Add:             3895.3     0.061698     0.061613     0.061753
Triad:           3936.0     0.061027     0.060975     0.061079
Each test below will take on the order of 60931 microseconds.
   (= 60931 clock ticks)
Copy:            3362.8     0.049671     0.047580     0.052043
Scale:           3370.5     0.047724     0.047471     0.048038
Add:             3143.8     0.076699     0.076341     0.077099
Triad:           3333.7     0.072607     0.071992     0.073065
Each test below will take on the order of 61228 microseconds.
   (= 61228 clock ticks)
Copy:            3331.0     0.048920     0.048033     0.049906
Scale:           3645.6     0.044595     0.043888     0.045386
Add:             3213.6     0.075035     0.074682     0.075698
Triad:           3204.3     0.075369     0.074900     0.076134
Copy:            5413.8     0.029589     0.029554     0.029631
Scale:           5510.8     0.029088     0.029034     0.029151
Add:             4728.4     0.050821     0.050757     0.050915
Triad:           4683.4     0.051375     0.051245     0.052019
Each test below will take on the order of 62449 microseconds.
   (= 62449 clock ticks)
Copy:            3856.4     0.042674     0.041490     0.044648
Scale:           3708.2     0.043976     0.043148     0.044730
Add:             3843.2     0.062549     0.062448     0.062685
Triad:           3853.2     0.062347     0.062286     0.062415
Each test below will take on the order of 60369 microseconds.
   (= 60369 clock ticks)
Copy:            3438.7     0.048310     0.046529     0.050204
Scale:           3444.9     0.046806     0.046445     0.047192
Add:             3135.5     0.076741     0.076542     0.077033
Triad:           3322.3     0.072500     0.072239     0.072907
Each test below will take on the order of 60132 microseconds.
   (= 60132 clock ticks)
Copy:            3558.9     0.047131     0.044958     0.050026
Scale:           3521.2     0.046606     0.045439     0.047983
Add:             3447.1     0.072796     0.069624     0.076257
Triad:           3439.9     0.072690     0.069769     0.074759
Heater
Fri Apr 17, 2020 8:53 am
So what is going on here?
This must be the first time ever I have seen performance drop when adding cores.
How come the Pi does that but no other machine tested?
Fri Apr 17, 2020 10:15 am
Contention? More cores trying to access memory that is already reached maximum bandwidth will cause contention. ("Trashing" in CPU terms). Just a guess.
jahboater
Fri Apr 17, 2020 10:33 am
I have just compared a 2GB Pi4 with a 4GB Pi4 and the results are the same (well within the margin of error).
Same config, same compiler, same kernel.
Heater
Fri Apr 17, 2020 10:36 am
I thought "contention" as well.
But then I could not make any sense out of it. If the job is memory bandwidth limited I'd expect it to go up a bit with cores and then saturate as the memory bandwidth is consumed. As seen in the graphs for the other machines. As Amdahl's Law suggests.
But then we have the caches to think about. Perhaps I would expect a teeny weeny shared cache to be "thrashed". What is the cache layout and sizes on the Pi 4? Do the cores share all cache?
Or is it just that scheduling those cores has a massive overhead in this case for some reason?
Heater
Fri Apr 17, 2020 10:37 am
That is in agreement with my results above.
Technocolour
Fri Apr 17, 2020 10:58 am
But then we the caches to think about. Perhaps I would expect a teeny weeny shared cache to be "thrashed". What is the cache layout and sizes on the Pi 4? Do the cores share all cache?
It's 1MB of unified L2 iirc, L1 should be standard for the A72 (I'm guessing the wiki link is correct)?
https://en.wikipedia.org/wiki/ARM_Cortex-A72
Fri Apr 17, 2020 1:24 pm
SDRAM is complicated.
Pages (rows) have to be opened before using and that is a multi-cycle operation.
You can have a small number of pages open at once, and accessing an open page is much quicker.
I think pages may be 4k or 8K in size.
Running too many threads of a memory test may cause thrashing, where new requests are closing pages that are still wanted.
There is also the concept of banks where switching between banks on consecutive accesses may be cheaper than using the same bank.
Banks are selected through some higher order address lines, so care about physical memory addresses.
That is largely hidden from linux where you just see virtual memory addresses unrelated to the physical memory.
We did find in early testing that some benchmark results after boot were bimodal - purely dependent on where in physical memory the buffers were allocated. Interestingly the longer linux was running the more blurred these result became as the virtual memory became more scattered in the physical address map.
ejolson
Fri Apr 17, 2020 7:23 pm
I thought trashing was what happened after shorting out the GPIO pins.
I made a plot which combines the recently posted Raspbian Pi 4B 4G results (only one run apparently) and the 64-bit nspawn environment (best out of the posted three runs in each category) on the same graph.
All the curves are decreasing, but unlike my Pi 4B 2G results, they plateau between 3 and 4 processor cores. As I'm still running the original firmware on the 2G model, I wonder if this reflects a firmware-related change in memory timings. Does anyone know whether any such changes were made in the firmware? Alternatively, since it's been running for 26 days, maybe physical memory is fragmented on my Pi.
Is the schmoo stuff really gone?
Here are stream results for the 2B version 1.1 with the ARMv7 CPU.
Except for the copy operation, all the other kernels show an increasing trend. This may explain why, when the Pi 2B first came out, I was so impressed with how well parallel codes scaled on it. More information is at
viewtopic.php?f=33&t=102743
I've also updated the table in the original post with the single-core timings. Does anyone with a version 1.2 issue of the Pi 2B want to post results?
ejolson
Sun Apr 19, 2020 3:17 am
I went to the dog house to consult with the lead developer of FidoBasic about how many rows of memory the RAM subsystem in the Raspberry Pi could have open at one time, but the canine coder only growled and barked something about social distancing and Corona beer. Thinking it better not to drink alone I knocked once more, but the door would not open. However, upon returning home I had an idea: I sent Fido a Zoom invitation on the Raspberry Pi.
https://www.raspberrypi.org/blog/workin ... pberry-pi/
Although the sound quality was satisfactory, the barking was mostly incoherent. In the end I understood that due to a lack of schmoo stuff and paper products, the only way to overclock memory on the Pi 4B was to underclock the CPU and then speed the time component of the whole space-time continuum up by a factor of two. It seemed worth a try, so I edited the config.txt file to set
arm_freq=750
and rebooted. The results were
Note for simplicity (and fear of the good doctor) that I did not attempt to change the flow of time itself and have only reported the weird stuff which happens when the CPU is set to 750 MHz.
Thinking I might have misunderstood the dog developer, I tried again using a factor of 4 by setting
arm_freq=375
arm_freq_min=375
and obtained
At last, here is a result in which the aggregate memory bandwidth of the Pi 4B does not decrease substantially as more cores are added! Now I need an excuse to borrow that sonic screwdriver.
ejolson
Tue Apr 21, 2020 1:16 am
Here is another memory bandwidth versus number of cores graph, this time for the Ryzen 7 Pro 1700, a first-generation Ryzen processor released March 2017. To get more accurate timings I increased the memory used for the test 10 fold with
$ gcc -DSTREAM_ARRAY_SIZE=100000000 \
-O3 -mtune=native -march=native -fopenmp \
-o streamomp.100M stream.c
and used a similar script as before to obtain the graph
Note that two tests were run, one in which only one hardware thread was used per core shown by the solid line and the other which tested all threads dashed. Except for the case of using only one core with two threads, higher bandwidth resulted when using only one thread per core. The Copy test shows a 4B-like decrease in bandwidth as more cores are added with a slight increase again when moving from 4 to 5 cores. This suggests internally that the cores are clustered in two groups of four. This could probably be verified by looking at the marketing literature. The Scale, Add and Triad results plateau early, but again have a slight bump between 4 and 5 cores, hopefully not due to relaxing the shelter at home quarantine.
Do the numbers for the Pi 4B 4GB change if the stream program is compiled as above to use more memory? I can't test this using the 2GB model here because that's not enough.
