Raspberry Pi Imager - Where do images get downloaded to?
When using the Raspberry Pi Imager (on Win 7 PC) and selecting Raspbian to write to my SD. Where does the Raspbian image get downloaded to, before being written to the SD card? Does the Raspbian image get deleted after being written to the SD, or does it stay in a temp folder somewhere on my Win 7 PC?
Re: Raspberry Pi Imager - Where do images get downloaded to?
I had the same question, and got the answer here from one of the developers.
Differs by OS.
Typically somewhere under c:\users\your-username\AppData\Local or ~/.cache or ~/Library/Caches
AppData folder -like most other system folders- is hidden by default in Windows explorer.
Easily install anything on your Pi using Pi-Apps. Over 2 million users.
Over 200 apps including image editors, IDEs, games, web browsers, appearance themes, and more to upgrade your Raspberry Pi desktop.
images are being downloaded in the directory i.e., Local Disk C:\users\your-username\AppData\Local or ~/.cache or ~/Library/Caches or sometime in AppData
mccannd wrote: ↑Sun May 03, 2020 10:58 amWhere does the Raspbian image get downloaded to...on my Win 7 PC?/quote]
In such cases, I open the command prompt and issueorCode: Select all
dir c:\".img /s/p
dir c:\*raspbi* /s/p
kaksi wrote: ↑Sun May 03, 2020 9:50 pmHave you actually tried this?mccannd wrote: ↑Sun May 03, 2020 10:58 amWhere does the Raspbian image get downloaded to...on my Win 7 PC?/quote]
dir c:\".img /s/p
Because on my system, the downloaded file does not end with .img, is not raw disk image format, and does not include "raspbi" in the filename.
Thanks for all the replies, appreciate it
So in this folder:
C:\Users\<username>\AppData\Local\Raspberry Pi\Imager\cache
I have a 1.10GB file
lastdownload.cache
So I suspect that's Raspbian. Is it ok to delete this file and cache folder?
Just trying to clear up some disk space.
So in this folder:
lastdownload.cache
On my Raspbian system the cache file is also called "lastdownload.cache", so it looks like you found it.mccannd wrote: ↑Mon May 04, 2020 9:56 amThanks for all the replies, appreciate it
So in this folder:
lastdownload.cache
It deleted fine for me. Just remember you're in the AppData folder, which is hidden away from users. So be especially careful.
Sorry to hijack thread, same question but on a Mac, I tried looking for them but I can't find cached images
_________________________________________________________________________
Pi model B / Pi 2 / Pi 3 / Pi 4 / Pi 5 / Pi 400 / Pi Zero W / Pi Zero 2 W / Pico
Thank you, perfect, found it
incognitum wrote: ↑Fri Oct 23, 2020 11:12 pm"Go" -> "Go to Folder..." -> ~/Library/Caches/Raspberry Pi
