rpiMike
Script to build development Vulkan driver and demos
Sat Jun 13, 2020 4:23 pm
Here is a script to build the early development Vulkan driver and sample Vulkan demos.
https://github.com/mikehooper/PiScripts ... ll_v3dv.sh
The following should download and run the script (note does update and full-upgrade):
cd ~
wget https://raw.githubusercontent.com/mikehooper/PiScripts/master/install_v3dv.sh
chmod +x install_v3dv.sh
./install_v3dv.sh
To run the demos (32bit):
export VK_ICD_FILENAMES=/home/pi/local-install/share/vulkan/icd.d/broadcom_icd.armv7l.json
(64bit):
export VK_ICD_FILENAMES=/home/pi/local-install/share/vulkan/icd.d/broadcom_icd.aarch64.json
cd ~/Vulkan/build/bin/
./gears
Tested on Raspberry Pi OS 32bit and 64bit beta.
Please let me know if you get this working or I can make improvements.
Video: https://www.youtube.com/watch?v=ygBB3D5vryw
Blog: https://www.raspberrypi.org/blog/vulkan ... urce-code/
Driver: https://blogs.igalia.com/apinheiro/2020 ... ome-demos/
fbe
Re: Script to build development Vulkan driver and demos
Sat Jun 13, 2020 5:06 pm
7/10 Build v3dv
./install_v3dv.sh: 35: ./install_v3dv.sh: meson: not found
pi@raspberrypi:~ $ echo $PATH
/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
pi@raspberrypi:~ $
This is because /home/pi/.local/bin was created after login.
rpiMike
Sat Jun 13, 2020 5:19 pm
7/10 Build v3dv
pi@raspberrypi:~ $
Any suggestion to fix this?
BRX7
Sat Jun 13, 2020 5:31 pm
I tried your script, its seems to have run properly, but I still get this message
Fatal : VkResult is "ERROR_INITIALIZATION_FAILED" in /home/pi/Vulkan/base/vulkanexamplebase.cpp at line 826
gears: /home/pi/Vulkan/base/vulkanexamplebase.cpp:826: bool VulkanExampleBase::initVulkan(): Assertion `res == VK_SUCCESS' failed.
Aborted
is there a log i can refer to?
rpiMike
Sat Jun 13, 2020 5:33 pm
Aborted
Which OS? Which Pi? Connected to hdmi screen?
BRX7
Sat Jun 13, 2020 5:35 pm
Aborted
Which OS? Which Pi?
Raspberrypi OS 32BIT, RPI4 8GB, updated , the kernel is still 32bit though i didnt switch to 64bit via rpi-update
I run this
$ export VK_ICD_FILENAMES=/home/pi/local-install/share/vulkan/icd.d/broadcom_icd.armv7l.json
then ./gears
fbe
Sat Jun 13, 2020 5:39 pm
echo $PATH | grep $HOME/.local/bin || export PATH=$HOME/.local/bin:$PATH
should fix the path.
rpiMike
Sat Jun 13, 2020 5:43 pm
I don't think export will work in a script?
rpiMike
Sat Jun 13, 2020 5:47 pm
Aborted
Which OS? Which Pi?
I run this
then ./gears
Maybe log an issue here: https://gitlab.freedesktop.org/apinheiro/mesa/-/issues
fbe
Sat Jun 13, 2020 6:10 pm
It works, but it's scope ends when the script ends (if you don't source the script).
fbe
Sat Jun 13, 2020 6:58 pm
Build worked, "gears" work.
Raspberry Pi 4B 4GB
Raspberry Pi OS (32-bit) with desktop (2020-05-27)
Most settings default in /boot/config.txt (except for gpu_mem)
BRX7
Sat Jun 13, 2020 8:33 pm
ok confirming it works on a 32bit raspberry os image on a rpi4 4gb 1.2, usb boot .
not on a rpi4 8gb (sd boot)
rpiMike
Sat Jun 13, 2020 8:36 pm
Raspberry Pi 4B 4GB
Thanks, just added your path fix.
rpiMike
Sat Jun 13, 2020 8:37 pm
Thanks, looks like you logged the issue, nice.
BRX7
Sat Jun 13, 2020 10:05 pm
fixed it,
its the native resolution issue, i am using a 4k tv and os resolution was full hd, ive switched to 4k and just like minecraft-pi its works native res
Gavinmc42
Sun Jun 14, 2020 3:38 am
It is working on a new 32bit Raspbian with the 5.4.44 update/upgrade :D
I had to update the OS on a Pi3B+ as my Pi4 already had the new bootloader, which does not like the 4.19 boot files.
Might have to play in 32bit land until the 64bit driver/script is sorted.
Thanks Mike.
I'm dancing on Rainbows.
MattPurland
Wed Jul 01, 2020 3:08 pm
Just tried this out, has a small issue with the version of meson not being correct (had to manually update it) but all working well.
I'm getting 113fps on the sphericalenvmapping example, and 575fps on gears. Looks great!
I'm overclocked to 2ghz CPU and 700mhz GPU
rpiMike
Wed Jul 01, 2020 3:13 pm
Thanks for the feedback, updated script to force meson reinstall.
rpiMike
Sat Jul 04, 2020 7:12 am
Thanks for the link to the update.
rpiMike
Sat Jul 04, 2020 11:47 am
Development Vulkan driver now works on RPiOS64 beta.
Gavinmc42
Sun Jul 05, 2020 12:32 am
pi@raspberrypi:~/sascha-willems/build/bin $ ./gears
Could not create Vulkan instance :
Same issue. Path? Must have missed a step
Everything compiles fine.
rpiMike
Sun Jul 05, 2020 6:35 am
Which OS? Did you delete the mesa folder to make sure you get the latest v3dv?
Gavinmc42
Sun Jul 05, 2020 7:17 am
Linux raspberrypi 5.4.47-v8+ #1322 SMP PREEMPT Wed Jun 17 18:05:46 BST 2020 aarch64 GNU/Linux
Did not delete mesa, just renamed them and then git the new one.
I end up with a "broadcom_icd.aarch64.json" file and change the path to that name.
Could have missed another needed change for 64bit?
EDIT- copied broadcom_icd.aarch64.json into /etc/vulkan/icd.d
Now working, gears fps seems slower than OpenGL. 140 v 800.
Time for some fun :D
Gavinmc42
Mon Jul 27, 2020 9:56 am
A repost- just in case I lose it.
Have not been on my Pi's for a few days, just noticed this.
vkquake is working.
http://planet.igalia.com/
Return to “Graphics programming”
