CaptainMidnight
Raspberry Pi 4B UAS compatible external drive enclosure - system response and transfer speeds.
Sun Jun 14, 2020 1:58 pm
After playing around with different USB 3.0 external drive enclosures, for use with the Raspberry Pi, the first I tried to use had the issue of random disocnnects and read errors - this was related to UAS issues - use of the 'quirks' option in /boot/cmdline.txt sorted the issues 100% - reduced performance but still quick.
Reading that ASMedia controller based enclosures seemed to do quite well, I changed to this CSL USB 3.0 to M.2 NGFF external drive enclosure - it uses the ASM1153E controller chip and is UAS compatible with the RPi4B. I loaded it with a spare M.2 256GB drive made by Micron, it was left over from a laptop hard drive upgrade a couple of years ago, but they're now cheaply and readily available on eBay (approx £30) or there's many a bargain M.2 NGFF high capacity drive if you so desire.
With it being UAS compatible, the transfer sppeds are pretty good :D
  • Sequential write speed 329326 KB/sec
  • Random write speed 17084 IOPS
  • Random read speed 15738 IOPS
All in all, this setup results in a very nice low power desktop replacement system with great responses and ample quick storage 8-)
USB 3.0 to M.2 NGFF enclosure pictured below, it costs £14.85 ( https://www.amazon.co.uk/CSL-Enclosure- ... 567&sr=8-1 )
CSL USB 3.0 to M.2 NGFF external drive enclosure.
CSL M.2 Enclosure.png (199.9 KiB) Viewed 4867 times
Micron 256GB M.2 NGFF hard drive.
Micron 1100-2.png (107.66 KiB) Viewed 4867 times
'dmesg' output related to the CSL enclosure and drive: -
[    1.311286] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[    1.332205] usb 2-2: New USB device found, idVendor=174c, idProduct=55aa, bcdDevice= 1.00
[    1.333362] usb 2-2: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[    1.334474] usb 2-2: Product: USB3.0 External M.2 SSD
[    1.335660] usb 2-2: Manufacturer: ASMedia
[    1.336826] usb 2-2: SerialNumber: 2016050000B9
[    1.345575] scsi host0: uas
[    1.347557] scsi 0:0:0:0: Direct-Access     Micron 1 100 SATA 256GB   0    PQ: 0 ANSI: 6
[    1.349602] sd 0:0:0:0: [sda] 500118192 512-byte logical blocks: (256 GB/238 GiB)
[    1.350753] sd 0:0:0:0: [sda] 4096-byte physical blocks
[    1.352105] sd 0:0:0:0: [sda] Write Protect is off
[    1.353319] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[    1.353511] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.355276] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes not a multiple of physical block size (4096 bytes)
"Never get out of the boat."
Absolutely goddamn right!
Unless you were goin' all the way...
ejolson
Re: Raspberry Pi 4B UAS compatible external drive enclosure - system response and transfer speeds.
Sun Jun 14, 2020 2:53 pm
What program did you use to check the performance? Is the case plastic or made of aluminium? How hot does it get?
CaptainMidnight
Sun Jun 14, 2020 3:02 pm
Hi, to check the performance I used the standard RPi diagnostic SDTest tool, as seen below, just tested again now: -
pi@phoenix-pi-x64:~ $ sh /usr/share/agnostics/sdtest.sh
Run 1
prepare-file;0;0;327680;640
seq-write;0;0;330989;646
rand-4k-write;0;0;87732;21933
rand-4k-read;62894;15723;0;0
Sequential write speed 330989 KB/sec (target 10000) - PASS
Random write speed 21933 IOPS (target 500) - PASS
Random read speed 15723 IOPS (target 1500) - PASS
It's a metal case with plastic end caps and doesn't get too warm really, the USB3.0 cable is about 20/30cm long from memory, just not there at the moment but will check.
Kendek
Sun Jun 14, 2020 3:35 pm
Don't forget about the TRIM/UNMAP. The ASM1153E is capable, but you will probably need a firmware update. There are two compatible firmware; 140509_A1_82_40 and 141126_A1_EE_82. I'm using the first one with StarTech SATA to USB Cable.
CaptainMidnight
Sun Jun 14, 2020 5:14 pm
Thanks for the info, I'll look into that - your 1st link (140509_A1_82_40) doesn't appear to work - I'll have a look on the CSL-Computer website, cheers
Kendek
Sun Jun 14, 2020 5:24 pm
Thanks for the info, I'll look into that - your 1st link (140509_A1_82_40) doesn't appear to work.
It works for me, but you can download my update pack from Dropbox. :)
CaptainMidnight
Sun Jun 14, 2020 5:42 pm
Thanks, need to look into this.
CaptainMidnight
Sun Jun 14, 2020 7:56 pm
Hmm, from the looks of it my unit is running the other firmware
1153E Firmware.png (10.73 KiB) Viewed 4599 times
.... so I would assume I should potentially be looking at using 141126_A1_EE_82.bin
@Kendek
Q. When you flashed your firmware did it wipe the drive?
CaptainMidnight
Sun Jun 14, 2020 8:09 pm
Sorted, now on latest firmware ;)
1153E Updated Firmware.png (10.85 KiB) Viewed 4589 times
Kendek
Sun Jun 14, 2020 8:10 pm
@Kendek
No, it didn't. But it's not necessary to have a drive attached for firmware update.
Kendek
Sun Jun 14, 2020 8:16 pm
Yeah, now you can test the UNMAP support.
/etc/udev/rules.d/01-unmap.rules
ACTION=="add|change", ATTRS{idVendor}=="174c", ATTRS{idProduct}=="55aa", SUBSYSTEM=="scsi_disk", ATTR{provisioning_mode}="unmap"
CaptainMidnight
Sun Jun 14, 2020 11:10 pm
Q. How would you go about testing this after creating the file and presumably a reboot?
Some version of fstrim maybe?
CaptainMidnight
Sun Jun 14, 2020 11:44 pm
.... with just a bit more tinkering: -
pi@phoenix-pi-x64:~$sudo systemctl enable fstrim.timer
pi@phoenix-pi-x64:~$sudo systemctl start fstrim.timer
pi@phoenix-pi-x64:~$sudo systemctl status fstrim.timer
● fstrim.timer - Discard unused blocks once a week
   Loaded: loaded (/lib/systemd/system/fstrim.timer; enabled; vendor preset: enabled)
   Active: active (waiting) since Mon 2020-06-15 00:28:03 BST; 1min 3s ago
   Trigger: Mon 2020-06-22 00:00:00 BST; 6 days left
     Docs: man:fstrim
I presume all I can do now is wait and see if it works?
Edit: well actually maybe not: -
pi@phoenix-pi-x64:~$ sudo fstrim -a -v
/boot: 197.7 MiB (207252480 bytes) trimmed on /dev/sda1
/: 89.3 MiB (93663232 bytes) trimmed on /dev/sda2
:D
Kendek
Mon Jun 15, 2020 6:08 am
Yeah, the fstrim is good, but you can check the actual result with the trim_test.sh script.
Test discard mount option:
> sudo mount -o remount,discard /
> sudo ./trim_test.sh /
n
1
Test fstrim command:
> sudo mount -o remount,nodiscard /
y
1
CaptainMidnight
Mon Jun 15, 2020 8:49 am
n
1
y
1
After installing hdparm ;) and running through those procedures - full success, whoop whoop 8-)
pi@phoenix-pi-x64:~ $ sudo mount -o remount,discard /
pi@phoenix-pi-x64:~ $ sudo ./trim_test.sh /
Use fstrim? [y/N]n
Choose a method:
[1] hdparm (will fail in LUKS on LVM)
[2] filefrag (warning: you may have to force quit - close the terminal - in some cases of success trim if you see an output that never ends)
Entrying /
Creating the file test-trim-by-desgua at /
10+0 records in
10+0 records out
5242880 bytes (5.2 MB, 5.0 MiB) copied, 0.138847 s, 37.8 MB/s
Syncing and sleeping 2 seconds.
test-trim-by-desgua:
 filesystem blocksize 4096, begins at LBA 532480; assuming 512 byte sectors.
 byte_offset  begin_LBA    end_LBA    sectors
           0    3350528    3360767      10240
As you can see, the file was created and its LBA begins at 3350528
Removing file test-trim-by-desgua
This is readed from sector 3350528:
/dev/sda:
reading sector 3350528: succeeded
0000 0000 0000 0000 0000 0000 0000 0000
Success!!!
pi@phoenix-pi-x64:~ $ sudo mount -o remount,nodiscard /
Use fstrim? [y/N]y
Choose a method:
Entrying /
10+0 records in
10+0 records out
5242880 bytes (5.2 MB, 5.0 MiB) copied, 0.123137 s, 42.6 MB/s
fstrim / && sleep 2
/dev/sda:
Success!!!
Thank you very much for your help and patience, much appreciated !!
snahl
Tue Jan 12, 2021 4:15 pm
Link is dead
Would you mind to upload it again, please.
CaptainMidnight
Tue Jan 12, 2021 7:20 pm
Link is dead
If you look back up to the previous post by Kendek link below, both links are working (the firmware, not upgrade pack)
https://www.raspberrypi.org/forums/vie ... 0#p1679047
Michel84
Tue Feb 23, 2021 5:18 pm
When you use an X829 shield, use the 140509_A1_82_40 firmware.
The Pi 4 won't boot when using the 141126_A1_EE_82 firmware in combination with external power for the shield.
