spcharc
Poor bluetooth audio quality playing with VLC player
Mon Jul 13, 2020 4:49 am
I am experiencing terrible audio quality with my bluetooth headset. The audio format is ".flac"
The device is a Pi 3B, running latest raspbian buster.
At first I thought it's a hardware problem. I tried disabling on-board WiFi as some posts suggested it may cause bluetooth connection issue. But the audio quality is still poor.
Until I tried:
ffmpeg -i XXX.flac -f s16le -ar 44100 -ac 2 - | aplay -f cd -
this time the quality is much better.
I want to know why this happens.
The VLC player supports far more audio formats than "aplay" so I don't need "ffmpeg" to do conversion. And it can play videos too. If possible I want to use VLC instead of "aplay".
spcharc
Re: Poor bluetooth audio quality playing with VLC player
Tue Jul 14, 2020 3:50 am
Reason found!
It's because the volume bar in VLC is dragged to 125%. I've tried so many options in VLC without thinking about the volume.
I found out that if the volume is above 100%, the quality would be poor.
So
(125% in VLC + 40% system wide volume) != (100% in VLC + 50% system wide volume)
So it turns out to be a volume problem. And I still don't understand why volume setting can cause this problem.
Jozzey07
Tue Jul 14, 2020 4:20 am
How did you connect your Bluetooth headset to your raspberry pi, i haven't been able to figure it out
spcharc
Thu Jul 16, 2020 10:59 pm
I just did this:
pi@raspberrypi:~ $ bluetoothctl
[bluetooth]# scan on
Wait until your device appeared (remember to put it into pairing mode)
[bluetooth]# pair XX:XX:XX:XX:XX:XX
[bluetooth]# connect XX:XX:XX:XX:XX:XX
[bluetooth]# trust XX:XX:XX:XX:XX:XX
Then right click on the volume icon at the top right, choose your headset as the sound output
