Upside down display
I have a Raspberry pi 4 with a 7 inch 'cd touch display (connected via ribbon cable as provided with the screen) but Its booting with display upside down I did try and edit the boot/config.txt in another device that I did the format to get it operating as far as the system working but it doesn't detect the fact that it needs to rotate to where the case it upright physically. What do I need to do to force rotate? I tried the command on the pi 4 Model B but wouldn't change it and as mentioned It won't rotate to text settings.
- RaspbianUser1
Re: Upside down display
try using the arandr tool then go to “Orientation” in one of the tabs at the top, sorry I forgot which one
Running Arch Linux on my personal computer
https://www.raspberrypi.org/documentati ... /arandr.md
also refer to https://www.raspberrypi.org/documentati ... /README.md for more options (as the touch needs to be rotated too)
I tried everything but the screen doesnt allow it to rotate as needed. Considering that its running a ribbon cable connection could it be forced or trick it into thinking that it isnt upright?
What (?) have you done? Have you ran the screen configuration utility, selected the DSI display and then changed orientation? Clicked the green button (apply settings)? This will rotate your display into all possible orientations.
Touch needs ro be rotated seperately (search for touch transformation matrix).
And no, you can't change the screen orientation by changing the ribbon cable!
And, if you don't mange to turn it in software simply rotate the entire thing. Again .. Touch needs to be rotated seperately!
In config.txt add lcd_rotate=2 fixes both the screen and the touch.
They really should have a paper with this in the box with the screen.
I have tried everything software wise and i used the SD Card Formatter (came with the Cana Kit set up) to format the sd card but turning the system upside down is a hassle because i want it to stand upright along with the touch and display.aBUGSworstnightmare wrote: ↑Sun Aug 02, 2020 4:53 amWhat (?) have you done? Have you ran the screen configuration utility, selected the DSI display and then changed orientation? Clicked the green button (apply settings)? This will rotate your display into all possible orientations.
Have you done what has been recommended? Use screen configuration utility to change the display rotation and then change touch transformation matrix by command.IchigoNitro wrote: ↑Tue Aug 04, 2020 4:44 amI have tried everything software wise and i used the SD Card Formatter (came with the Cana Kit set up) to format the sd card but turning the system upside down is a hassle because i want it to stand upright along with the touch and display.aBUGSworstnightmare wrote: ↑Sun Aug 02, 2020 4:53 amWhat (?) have you done? Have you ran the screen configuration utility, selected the DSI display and then changed orientation? Clicked the green button (apply settings)? This will rotate your display into all possible orientations.
Is it really that complicated to:
andFKMS Mode
FKMS mode is used by default on the Raspberry Pi 4B. FKMS uses the DRM/MESA libraries to provide graphics and 3D acceleration.
To set screen orientation when running the graphical desktop, select the Screen Configuration option from the Preferences menu. Right click on the DSI display rectangle in the layout editor, select Orientation then the required option.
You can also change the touch transformation matrix with is more common in the Linux world Touchscreen orientation viewtopic.php?f=108&t=219333&p=1348198& ... n#p1348198Touchscreen orientation
Additionally, you have the option to change the rotation of the touchscreen independently of the display itself by adding a dtoverlay instruction in config.txt, for example:
dtoverlay=rpi-ft5406,touchscreen-swapped-x-y=1,touchscreen-inverted-x=1
The options for the touchscreen are:
DT parameter Action
touchscreen-size-x Sets X resolution (default 800)
touchscreen-size-y Sets Y resolution (default 600)
touchscreen-inverted-x Invert X coordinates
touchscreen-inverted-y Invert Y coordinates
touchscreen-swapped-x-y Swap X and Y cordinates
I tried everything but it says that the config.txt file is read only. And ive tried other methods as well as updating the system (some were installed and some didnt install idk if this a kernel configuration issue or a bug theres not telling what it was.)aBUGSworstnightmare wrote: ↑Tue Aug 04, 2020 5:21 amHave you done what has been recommended? Use screen configuration utility to change the display rotation and then change touch transformation matrix by command.IchigoNitro wrote: ↑Tue Aug 04, 2020 4:44 amI have tried everything software wise and i used the SD Card Formatter (came with the Cana Kit set up) to format the sd card but turning the system upside down is a hassle because i want it to stand upright along with the touch and display.aBUGSworstnightmare wrote: ↑Sun Aug 02, 2020 4:53 amWhat (?) have you done? Have you ran the screen configuration utility, selected the DSI display and then changed orientation? Clicked the green button (apply settings)? This will rotate your display into all possible orientations.
Is it really that complicated to:andFKMS Mode
To set screen orientation when running the graphical desktop, select the Screen Configuration option from the Preferences menu. Right click on the DSI display rectangle in the layout editor, select Orientation then the required option.You can also change the touch transformation matrix with is more common in the Linux world Touchscreen orientation viewtopic.php?f=108&t=219333&p=1348198& ... n#p1348198Touchscreen orientation
DT parameter Action
use sudo in front of the command to edit /boot/config.txt
Major update: fixed the rotation issue now i need the touch capacitor to be where the display is... Command to fix this? (Display is as the stand case is but the touch capacitor is 90 degrees off center)
Well .. Although you seem quite advice resistant you got it working. But: how?
Do you take the time to read other users replay on this thread? Solution for fixing (rotating) the touch have been mentioned already.
So, good luck and hope you get touch fixed soon!
Well, i had to write a new sd card (128gb) and this time the system allowed writing onnthe files even while the system is operating and i figured out how to fix the problem. Hopefully itll stay after the updates. Speaking of, even after the updates are applied will it effect the screen rotation?
