sach
OSError: [Errno 101] Network is unreachable
Tue Sep 22, 2020 12:41 pm
I was trying to use mqtt but get error OSError: [Errno 101] Network is unreachable
neilgl
Re: OSError: [Errno 101] Network is unreachable
Tue Sep 22, 2020 4:11 pm
Which OS are you using on the pi Raspberry Pi OS or something else and which mqtt have you installed (e.g. mosquitto)?
Tue Sep 22, 2020 4:38 pm
Is the network active and working?
Get the results from
ip addr show
ip route
ping -c3 $(ip route | awk '/default/ {print $3}')
ping -c3 8.8.8.8
ping -c3 google.com
cat /etc/resolv.conf
sach
Thu Sep 24, 2020 1:45 am
hi, i am using Raspbian and for MQTT mosquitto.
sach
Thu Sep 24, 2020 1:47 am
raspbian operating system and mosquitto for mqtt
sach
Thu Sep 24, 2020 1:53 am
ip addr show
ip route
ping -c3 8.8.8.8
ping -c3 google.com
ping is working fine for me there is no packet loss.
pi@raspberrypi:~ $ cat /etc/resolv.conf
# Generated by resolvconf
nameserver 192.168.1.1
pi@raspberrypi:~ $ ip route
default via 192.168.1.1 dev wlan0 proto dhcp src 192.168.1.108 metric 303
192.168.1.0/24 dev wlan0 proto dhcp scope link src 192.168.1.108 metric 303
pi@raspberrypi:~ $ ip addr show
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
link/ether b8:27:eb:44:43:87 brd ff:ff:ff:ff:ff:ff
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether b8:27:eb:11:16:d2 brd ff:ff:ff:ff:ff:ff
inet 192.168.1.108/24 brd 192.168.1.255 scope global dynamic noprefixroute wlan0
valid_lft 86167sec preferred_lft 75367sec
inet6 fe80::5b21:4a96:e6ee:9a7a/64 scope link
sach
Thu Sep 24, 2020 2:38 am
this is the error :
%Run fclient.py
File "/home/pi/py-sds011/fclient.py", line 73, in <module>
client.connect("test.mosquitto.org", 1883, 60)
File "/home/pi/.local/lib/python3.7/site-packages/paho/mqtt/client.py", line 937, in connect
return self.reconnect()
File "/home/pi/.local/lib/python3.7/site-packages/paho/mqtt/client.py", line 1071, in reconnect
sock = self._create_socket_connection()
File "/home/pi/.local/lib/python3.7/site-packages/paho/mqtt/client.py", line 3522, in _create_socket_connection
return socket.create_connection(addr, source_address=source, timeout=self._keepalive)
File "/usr/lib/python3.7/socket.py", line 727, in create_connection
raise err
File "/usr/lib/python3.7/socket.py", line 716, in create_connection
sock.connect(sa)
>>> %Run client.py
File "/home/pi/py-sds011/client.py", line 61, in <module>
raise err
sock.connect(sa)
I have attached my CLIENT code as well :
# MQTT Client demo
# Continuously monitor two different MQTT topics for data,
# check if the received data matches two predefined 'commands'
import board
import busio
import adafruit_ccs811
import paho.mqtt.client as mqtt
import Adafruit_DHT
import time
import datetime
import csv
from sds011 import *
csvfile = "Final.csv"
sensor = SDS011("/dev/ttyUSB0")
sensor.sleep(sleep=False)
time.sleep(10)
pmt_2_5, pmt_10 = sensor.query()
i2c = busio.I2C(board.SCL, board.SDA)
ccs811 = adafruit_ccs811.CCS811(i2c)
# Wait for the sensor to be ready
while not ccs811.data_ready:
pass
# The callback for when the client receives a CONNACK response from the server.
def on_connect(client, userdata, flags, rc):
print("Connected with result code "+str(rc))
# Subscribing in on_connect() - if we lose the connection and
# reconnect then subscriptions will be renewed.
client.subscribe("CoreElectronics/test")
client.subscribe("CoreElectronics/topic")
# The callback for when a PUBLISH message is received from the server.
def on_message(client, userdata, msg):
print(msg.topic+" "+str(msg.payload))
while True:
msg.payload == "Hello"
print(f" PMT2.5: {pmt_2_5} μg/m3 ", end='')
print(f"PMT10 : {pmt_10} μg/m3")
sensor.sleep(sleep=True)
print("CO2: {} PPM, TVOC: {} PPB".format(ccs811.eco2, ccs811.tvoc))
humidity,temperature= Adafruit_DHT.read_retry(Adafruit_DHT.DHT11,4)
if humidity is not None and temperature is not None:
humidity= round(humidity,2)
temperature= round(temperature,2)
print ('Temperature = {0:0.1f}*C Humidity = {1:0.1f}%'.format(temperature, humidity))
timeC = time.strftime("%I")+':' +time.strftime("%M")+':'+time.strftime("%S")
data = [timeC,temperature,humidity,ccs811.eco2,ccs811.tvoc,pmt_2_5, pmt_10]
with open(csvfile, "a")as output:
writer = csv.writer(output, delimiter=",", lineterminator = '\n')
writer.writerow(data)
time.sleep(60)
if msg.payload == "World!":
print("print'can not connect to the server'")
# Do something else
# Create an MQTT client and attach our routines to it.
client = mqtt.Client()
client.on_connect = on_connect
client.on_message = on_message
# Process network traffic and dispatch callbacks. This will also handle
# reconnecting. Check the documentation at
# https://github.com/eclipse/paho.mqtt.python
# for information on how to use other loop*() functions
client.loop_forever()
neilgl
Thu Sep 24, 2020 8:10 am
Can you re-post your script(s) using Code tags so we can see the indentation? And are there two scripts? (fclient.py and client.py).
And what was the result of ping google.com
Thu Sep 24, 2020 8:21 am
It looks like your DNS lookup is being provided by your router at 192.168.1.1 (from your resolv.conf).
Also the router is the default gateway, which should be correct.
Did all three ping commands work?
The first is to confirm that you Pi can see your router.
The second is to confirm your traffic is being routed to the internet correctly.
The third is to confirm that DNS lookup for external sites is working correctly.
sock.connect(sa)
That is the important part of the error message, which I suspect is caused by this line of code
Is that the correct hostname to connect to?
What do you get with these commands?
host test.mosquitto.org
ping -c 1 test.mosquitto.org
Unreadable squiggle
neilgl
Thu Sep 24, 2020 8:25 am
If you have installed mosquitto clients [install if needed], try this from a terminal (not IDLE, mu, Thonny)
 mosquitto_sub -h test.mosquitto.org -t "#" -v
sach
Thu Sep 24, 2020 1:12 pm
sock.connect(sa)
hi, i have attached the ping statistics below:
$ ping -c3 $(ip route | awk '/default/ {print $3}')
PING 192.168.1.1 (192.168.1.1) 56(84) bytes of data.
64 bytes from 192.168.1.1: icmp_seq=1 ttl=64 time=2.48 ms
64 bytes from 192.168.1.1: icmp_seq=2 ttl=64 time=2.17 ms
64 bytes from 192.168.1.1: icmp_seq=3 ttl=64 time=1.75 ms
--- 192.168.1.1 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 5ms
rtt min/avg/max/mdev = 1.754/2.135/2.483/0.300 ms
pi@raspberrypi:~ $ ping -c3 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=119 time=11.8 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=119 time=11.10 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=119 time=11.2 ms
--- 8.8.8.8 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 4ms
rtt min/avg/max/mdev = 11.166/11.653/11.980/0.362 ms
pi@raspberrypi:~ $ ping -c3 google.com
PING google.com (142.250.66.206) 56(84) bytes of data.
64 bytes from syd09s23-in-f14.1e100.net (142.250.66.206): icmp_seq=1 ttl=119 time=9.99 ms
64 bytes from syd09s23-in-f14.1e100.net (142.250.66.206): icmp_seq=2 ttl=119 time=12.4 ms
64 bytes from syd09s23-in-f14.1e100.net (142.250.66.206): icmp_seq=3 ttl=119 time=10.3 ms
--- google.com ping statistics ---
rtt min/avg/max/mdev = 9.987/10.905/12.416/1.083 ms
pi@raspberrypi:~ $
test.mosquitto.org has address 5.196.95.208
test.mosquitto.org has IPv6 address 2001:41d0:a:fed0::1
pi@raspberrypi:~ $ ping -c 1 test.mosquitto.org
PING test.mosquitto.org (5.196.95.208) 56(84) bytes of data.
64 bytes from ks2.ral.me (5.196.95.208): icmp_seq=1 ttl=53 time=305 ms
--- test.mosquitto.org ping statistics ---
1 packets transmitted, 1 received, 0% packet loss, time 0ms
rtt min/avg/max/mdev = 304.504/304.504/304.504/0.000 ms
sach
Thu Sep 24, 2020 1:15 pm
Hi, from where i can install mosquitto clients?
neilgl
Thu Sep 24, 2020 1:46 pm
sudo apt install -y mosquitto mosquitto-clients
sach
Thu Sep 24, 2020 1:59 pm
I have two scripts fclient.py and client.py. i did some changes in client.py to get rid of error and made new script fclient. they almost same.
code is for client.py
# MQTT Client demo
import board
import busio
import Adafruit_DHT
import time
import datetime
#Taking data from the dust sensor
time.sleep(10)
#Monitoring data from CCS811 (Dust sensor) via I2C
    pass
    while True:
        # Do something else
sach
Thu Sep 24, 2020 2:11 pm
i tried running that in terminal but nothing happened.
neilgl
Thu Sep 24, 2020 4:00 pm
OK that server seems to be down. In one terminal start a sub
mosquitto_sub -t 'F215166/test' -v -h mqtt.eclipse.org
. Then in another terminal publish
mosquitto_pub -t 'F215166/test' -h mqtt.eclipse.org -m "$(date +%Y%m%d)"
You should see the topic appear in the sub window F215166/test 20200924
sach
Fri Sep 25, 2020 1:18 am
yup this one works. how can i use this in my code?
neilgl
Fri Sep 25, 2020 7:01 am
In your code, connect to mqtt.eclipse.org instead of test.mosquitto.org
sach
Fri Sep 25, 2020 12:43 pm
thanks mate its working now :D
neilgl
Fri Sep 25, 2020 12:46 pm
Good one!
