I am on kernel 5.10.7-v8+, and I use the vc4-hdmi audio device ONLY. Of course I have this overlay in config.txt:
dtoverlay=vc4-kms-v3d
For STORE:
pi@raspberrypi:~ $ sudo alsactl store
alsactl: get_control:256: Cannot read control '3,0,0,Playback Channel Map,0': Invalid argument
/var/lib/alsa/asound.state
pi@raspberrypi:~ $ sudo alsactl restore
alsactl: load_state:1683: Cannot open /var/lib/alsa/asound.state for reading: No such file or directory
Found hardware: "vc4-hdmi" "" "" "" ""
Hardware is initialized using a generic method
# Configuration for the VC4-HDMI sound card using software IEC958
# subframe conversion
<confdir:pcm/hdmi.conf>
vc4-hdmi.pcm.hdmi.0 {
@args [ CARD AES0 AES1 AES2 AES3 ]
@args.CARD {
type string
@args.AES0 {
type integer
@args.AES1 {
type integer
@args.AES2 {
type integer
@args.AES3 {
type integer
type iec958
slave {
format IEC958_SUBFRAME_LE
pcm {
type hooks
slave.pcm {
type hw
card $CARD
device 0
hooks.0 {
type ctl_elems
hook_args [
name "IEC958 Playback Default"
optional true
lock true
preserve true
value [ $AES0 $AES1 $AES2 $AES3 ]
status [ $AES0 $AES1 $AES2 $AES3 ]
# default with plug
vc4-hdmi.pcm.default {
@args [ CARD ]
@args.CARD {
type string
type plug
slave.pcm {
type softvol
slave.pcm {
@func concat
strings [ "hdmi:" $CARD ]
control {
name "PCM Playback Volume"
card $CARD
