raspberry_user
Installation of RPI.GPIO failure on Pi4 running Ubuntu 20.10 Desktop
Fri Oct 23, 2020 5:03 pm
Hi, I ran the "pip3 install RPI.GPIO" command but I got a long list of errors in red. In the middle some messages in white are:
Running setup.py clean for RPI.GPIO
Failed to build RPI.GPIO
Installing collected packages: RPI.GPIO
Running setup.py install for RPI.GPIO ... error
long list of messages in red again. Anybody knows how to fix this?
croston
Re: Installation of RPI.GPIO failure on Pi4 running Ubuntu 20.10 Desktop
Fri Oct 23, 2020 5:29 pm
What version of gcc is it using? I'm in the process of fixing failing builds with gcc 10.
raspberry_user
Fri Oct 23, 2020 5:32 pm
gcc -v
gave
gcc version 10.2.0 (Ubuntu 19.2.0-13ubuntu1)
going to python3 and then
from RPI import GPIO
gave ModuleNotFoundError: No module named "RPI"
croston
Fri Oct 23, 2020 6:01 pm
Try this as a workaround:
export CFLAGS=-fcommon
pip3 install RPi.GPIO
(I haven't tested this)
raspberry_user
Fri Oct 23, 2020 6:07 pm
Thank you. It says:
Requirement already satisfied: RPI.GPIO in /usr/lib/python3/dist-packages (0.7.0)
Tried "from RPI import GPIO" inside python3 again but same "No module named 'RPI'" error.
croston
Fri Oct 23, 2020 6:17 pm
'RPi' should have a small 'i'
raspberry_user
Fri Oct 23, 2020 6:39 pm
Thank you. Now typing "from RPi import GPIO" under python3 does not give an error.
I went to the adafruit site to install Python libraries and did a test.
https://learn.adafruit.com/circuitpytho ... spberry-pi
I got a "Not running on a RPi" error even I am running it on a Pi?! Do you know what is wrong?
Hello blinka!
File "blinkatest.py", line 7, in <module>
pin = digitalio.DigitalInOut(board.D4)
File "/home/pi/.local/lib/python3.8/site-packages/digitalio.py", line 111, in __init__
self.direction = Direction.INPUT
File "/home/pi/.local/lib/python3.8/site-packages/digitalio.py", line 141, in direction
self._pin.init(mode=Pin.IN)
File "/home/pi/.local/lib/python3.8/site-packages/adafruit_blinka/microcontroller/bcm283x/pin.py", line 37, in init
GPIO.setup(self.id, GPIO.IN)
RuntimeError: Not running on a RPi!
MinePro120
Fri Oct 23, 2020 7:31 pm
About the "Not running on a RPi", you should run the script as root or add your user to the same groups as user "ubuntu".
kerry_s
Sat Oct 24, 2020 7:02 am
there expecting raspberry os(aka: raspbian), it's in the prerequisite.
https://www.raspberrypi.org/downloads/raspberry-pi-os/
ubuntu is a different beast, it's not raspberry os. if your going to use software made for raspberry os, you should be running raspberry.
there's a difference between software & device, just because your using the right device doesn't mean the software will work on any os.
croston
Sat Oct 24, 2020 10:01 am
I've discovered a possible solution from someone running Ubuntu 20.04. Ubuntu doesn't have permissions set correctly for GPIO and RPi.GPIO gives a misleading error message about not running on a RPi. I haven't tested this myself.
Create /etc/udev/rules.d/90-gpio.rules with:
KERNEL=="gpiomem", OWNER="root", GROUP="gpio"
Create the group itself and assign it to an existing user "pi":
sudo groupadd -f --system gpio
sudo usermod -a -G gpio pi
Reboot for these changes to take effect. The last command assumes your username is 'pi'. If this is different, then just substitute it in the command above.
raspberry_user
Sun Oct 25, 2020 2:28 am
Thank you but still does not work.
croston
Sun Oct 25, 2020 12:34 pm
Does it work when you run your script using sudo? If so, this points to problems with permissions, or the lack of /dev/gpiomem.
raspberry_user
Sun Oct 25, 2020 12:53 pm
I just copied and pasted your commands which had sudo included.
dave666
Mon Mar 01, 2021 5:25 pm
Thank you. It says:
To solve the same problem on Ubuntu 20.10 (Desktop) 64-bit, I used:
and it worked perfectly. Thanks!!!
Nested
Thu May 20, 2021 7:57 am
If I run my script without sudo:
python3 my_script.py
I have this error:
If I use:
sudo python3 my_script.py
It's work correct.
I add my User to root:
groups ubuntu
ubuntu : ubuntu root adm tty dialout cdrom floppy sudo audio dip video plugdev netdev lxd
Reboot, Run and have error again:
Maybe I needd to add my user to another group?
drtechno
Wed Jun 02, 2021 10:18 pm
I know from wiring pi I had to make the user pi. I should find and copy over the groups as well. But these error I see on mine (user pi on ubuntu)
 ERROR: Command errored out with exit status 1:
   command: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/setup.py'"'"'; __file__='"'"'/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-66d1ivi0
       cwd: /tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/
  Complete output (102 lines):
  running bdist_wheel
  running build
  running build_py
  creating build
  creating build/lib.linux-aarch64-3.9
  creating build/lib.linux-aarch64-3.9/RPi
  copying RPi/__init__.py -> build/lib.linux-aarch64-3.9/RPi
  creating build/lib.linux-aarch64-3.9/RPi/GPIO
  copying RPi/GPIO/__init__.py -> build/lib.linux-aarch64-3.9/RPi/GPIO
  running build_ext
  building 'RPi._GPIO' extension
  creating build/temp.linux-aarch64-3.9
  creating build/temp.linux-aarch64-3.9/source
  aarch64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/build/python3.9-xSUlVY/python3.9-3.9.5=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/build/python3.9-xSUlVY/python3.9-3.9.5=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/usr/include/python3.9 -c source/c_gpio.c -o build/temp.linux-aarch64-3.9/source/c_gpio.o
  source/c_gpio.c: In function ‘setup’:
  source/c_gpio.c:130:9: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
    130 |     if ((uint32_t)gpio_mem % PAGE_SIZE)
  source/c_gpio.c:131:34: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
    131 |         gpio_mem += PAGE_SIZE - ((uint32_t)gpio_mem % PAGE_SIZE);
  aarch64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/build/python3.9-xSUlVY/python3.9-3.9.5=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/build/python3.9-xSUlVY/python3.9-3.9.5=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/usr/include/python3.9 -c source/common.c -o build/temp.linux-aarch64-3.9/source/common.o
  aarch64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/build/python3.9-xSUlVY/python3.9-3.9.5=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/build/python3.9-xSUlVY/python3.9-3.9.5=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/usr/include/python3.9 -c source/constants.c -o build/temp.linux-aarch64-3.9/source/constants.o
  aarch64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/build/python3.9-xSUlVY/python3.9-3.9.5=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/build/python3.9-xSUlVY/python3.9-3.9.5=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/usr/include/python3.9 -c source/cpuinfo.c -o build/temp.linux-aarch64-3.9/source/cpuinfo.o
  source/cpuinfo.c: In function ‘get_rpi_info’:
  source/cpuinfo.c:139:28: warning: format ‘%llx’ expects argument of type ‘long long unsigned int *’, but argument 3 has type ‘uint64_t *’ {aka ‘long unsigned int *’} [-Wformat=]
    139 |       sscanf(revision, "%llx", &rev);
        |                            |   uint64_t * {aka long unsigned int *}
        |                         %lx
  aarch64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/build/python3.9-xSUlVY/python3.9-3.9.5=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/build/python3.9-xSUlVY/python3.9-3.9.5=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/usr/include/python3.9 -c source/event_gpio.c -o build/temp.linux-aarch64-3.9/source/event_gpio.o
  aarch64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/build/python3.9-xSUlVY/python3.9-3.9.5=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/build/python3.9-xSUlVY/python3.9-3.9.5=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/usr/include/python3.9 -c source/py_gpio.c -o build/temp.linux-aarch64-3.9/source/py_gpio.o
  source/py_gpio.c: In function ‘PyInit__GPIO’:
  source/py_gpio.c:1046:4: warning: ‘PyEval_ThreadsInitialized’ is deprecated [-Wdeprecated-declarations]
   1046 |    if (!PyEval_ThreadsInitialized())
  In file included from /usr/include/python3.9/Python.h:145,
                   from source/py_gpio.c:23:
  /usr/include/python3.9/ceval.h:129:36: note: declared here
    129 | Py_DEPRECATED(3.9) PyAPI_FUNC(int) PyEval_ThreadsInitialized(void);
  source/py_gpio.c:1047:7: warning: ‘PyEval_InitThreads’ is deprecated [-Wdeprecated-declarations]
   1047 |       PyEval_InitThreads();
  /usr/include/python3.9/ceval.h:130:37: note: declared here
    130 | Py_DEPRECATED(3.9) PyAPI_FUNC(void) PyEval_InitThreads(void);
  aarch64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/build/python3.9-xSUlVY/python3.9-3.9.5=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/build/python3.9-xSUlVY/python3.9-3.9.5=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/usr/include/python3.9 -c source/py_pwm.c -o build/temp.linux-aarch64-3.9/source/py_pwm.o
  aarch64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/build/python3.9-xSUlVY/python3.9-3.9.5=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/build/python3.9-xSUlVY/python3.9-3.9.5=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/usr/include/python3.9 -c source/soft_pwm.c -o build/temp.linux-aarch64-3.9/source/soft_pwm.o
  aarch64-linux-gnu-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fwrapv -O2 -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fwrapv -O2 -g -ffile-prefix-map=/build/python3.9-xSUlVY/python3.9-3.9.5=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-aarch64-3.9/source/c_gpio.o build/temp.linux-aarch64-3.9/source/common.o build/temp.linux-aarch64-3.9/source/constants.o build/temp.linux-aarch64-3.9/source/cpuinfo.o build/temp.linux-aarch64-3.9/source/event_gpio.o build/temp.linux-aarch64-3.9/source/py_gpio.o build/temp.linux-aarch64-3.9/source/py_pwm.o build/temp.linux-aarch64-3.9/source/soft_pwm.o -o build/lib.linux-aarch64-3.9/RPi/_GPIO.cpython-39-aarch64-linux-gnu.so
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/constants.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:41: multiple definition of `module_setup'; build/temp.linux-aarch64-3.9/source/common.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:41: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/constants.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:40: multiple definition of `setup_error'; build/temp.linux-aarch64-3.9/source/common.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:40: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/constants.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:39: multiple definition of `rpiinfo'; build/temp.linux-aarch64-3.9/source/common.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:39: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/constants.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:38: multiple definition of `gpio_direction'; build/temp.linux-aarch64-3.9/source/common.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:38: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/constants.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:37: multiple definition of `pin_to_gpio'; build/temp.linux-aarch64-3.9/source/common.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:37: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/constants.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:36: multiple definition of `pin_to_gpio_rev3'; build/temp.linux-aarch64-3.9/source/common.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:36: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/constants.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:35: multiple definition of `pin_to_gpio_rev2'; build/temp.linux-aarch64-3.9/source/common.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:35: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/constants.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:34: multiple definition of `pin_to_gpio_rev1'; build/temp.linux-aarch64-3.9/source/common.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:34: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/constants.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:33: multiple definition of `gpio_mode'; build/temp.linux-aarch64-3.9/source/common.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:33: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:33: multiple definition of `gpio_mode'; build/temp.linux-aarch64-3.9/source/common.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:33: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:40: multiple definition of `setup_error'; build/temp.linux-aarch64-3.9/source/common.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:40: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:39: multiple definition of `rpiinfo'; build/temp.linux-aarch64-3.9/source/common.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:39: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:38: multiple definition of `gpio_direction'; build/temp.linux-aarch64-3.9/source/common.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:38: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:41: multiple definition of `module_setup'; build/temp.linux-aarch64-3.9/source/common.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:41: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:37: multiple definition of `pin_to_gpio'; build/temp.linux-aarch64-3.9/source/common.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:37: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:36: multiple definition of `pin_to_gpio_rev3'; build/temp.linux-aarch64-3.9/source/common.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:36: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:34: multiple definition of `pin_to_gpio_rev1'; build/temp.linux-aarch64-3.9/source/common.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:34: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:35: multiple definition of `pin_to_gpio_rev2'; build/temp.linux-aarch64-3.9/source/common.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:35: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/constants.h:42: multiple definition of `both_edge'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/constants.h:42: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/constants.h:41: multiple definition of `falling_edge'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/constants.h:41: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/constants.h:40: multiple definition of `rising_edge'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/constants.h:40: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/constants.h:39: multiple definition of `pud_down'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/constants.h:39: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/constants.h:38: multiple definition of `pud_up'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/constants.h:38: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/constants.h:37: multiple definition of `pud_off'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/constants.h:37: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/constants.h:36: multiple definition of `bcm'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/constants.h:36: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/constants.h:35: multiple definition of `board'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/constants.h:35: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/constants.h:34: multiple definition of `unknown'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/constants.h:34: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/constants.h:33: multiple definition of `spi'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/constants.h:33: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/constants.h:32: multiple definition of `i2c'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/constants.h:32: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/constants.h:31: multiple definition of `serial'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/constants.h:31: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/constants.h:30: multiple definition of `pwm'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/constants.h:30: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/constants.h:29: multiple definition of `output'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/constants.h:29: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/constants.h:28: multiple definition of `input'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/constants.h:28: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/constants.h:27: multiple definition of `low'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/constants.h:27: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/constants.h:26: multiple definition of `high'; build/temp.linux-aarch64-3.9/source/constants.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/constants.h:26: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_pwm.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:38: multiple definition of `gpio_direction'; build/temp.linux-aarch64-3.9/source/common.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:38: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_pwm.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/py_pwm.h:23: multiple definition of `PWMType'; build/temp.linux-aarch64-3.9/source/py_gpio.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/py_pwm.h:23: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_pwm.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:41: multiple definition of `module_setup'; build/temp.linux-aarch64-3.9/source/common.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:41: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_pwm.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:40: multiple definition of `setup_error'; build/temp.linux-aarch64-3.9/source/common.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:40: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_pwm.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:39: multiple definition of `rpiinfo'; build/temp.linux-aarch64-3.9/source/common.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:39: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_pwm.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:37: multiple definition of `pin_to_gpio'; build/temp.linux-aarch64-3.9/source/common.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:37: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_pwm.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:36: multiple definition of `pin_to_gpio_rev3'; build/temp.linux-aarch64-3.9/source/common.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:36: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_pwm.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:35: multiple definition of `pin_to_gpio_rev2'; build/temp.linux-aarch64-3.9/source/common.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:35: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_pwm.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:34: multiple definition of `pin_to_gpio_rev1'; build/temp.linux-aarch64-3.9/source/common.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:34: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/py_pwm.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:33: multiple definition of `gpio_mode'; build/temp.linux-aarch64-3.9/source/common.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/common.h:33: first defined here
  /usr/bin/ld: build/temp.linux-aarch64-3.9/source/soft_pwm.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/soft_pwm.c:28: multiple definition of `threads'; build/temp.linux-aarch64-3.9/source/event_gpio.o:/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/source/event_gpio.c:60: first defined here
  collect2: error: ld returned 1 exit status
  error: command '/usr/bin/aarch64-linux-gnu-gcc' failed with exit code 1
  ERROR: Failed building wheel for RPI.GPIO
     command: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/setup.py'"'"'; __file__='"'"'/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-9aqowm9v/install-record.txt --single-version-externally-managed --compile --install-headers /usr/local/include/python3.9/RPI.GPIO
    running install
    running build
    running build_py
    creating build
    running build_ext
          |                         %lx
ERROR: Command errored out with exit status 1: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/setup.py'"'"'; __file__='"'"'/tmp/pip-install-2lg6_nh9/rpi-gpio_d94152161d1c4a448f14a1b24e1b28c2/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-9aqowm9v/install-record.txt --single-version-externally-managed --compile --install-headers /usr/local/include/python3.9/RPI.GPIO Check the logs for full command output.
Looks like the python version is too new because of the depreciated errors.BTW it won't be the first time the Ubuntu users had to pry programs out of proprietary OS installs. There is always a way.
drtechno
Thu Jun 03, 2021 4:02 am
so do this:
sudo -i
dpkg --add-architecture armhf
apt-get update
apt-get install python-dev python3-dev
apt-get install mercurial
 pip install hg+http://hg.code.sf.net/p/raspberry-gpio-python/code#egg=RPi.GPIO
 pip3 install hg+http://hg.code.sf.net/p/raspberry-gpio-python/code#egg=RPi.GPIO
Return to “Ubuntu”
