knute
gcc 10+?
Thu Dec 10, 2020 3:52 am
A while back there was a thread with a script for downloading and compiling gcc 10 (I think it was 10 anyway). I can't seem to find it again. I have need for gcc 10. Anybody remember who posted the script or what the title was?
jahboater
Re: gcc 10+?
Thu Dec 10, 2020 4:31 am
Here it is:
#!/bin/bash
# REMEMBER TO UNCOMMENT THE CONFIGURE LINE FOR YOUR TARGET PLATFORM.
# ... and comment out the default of course.
#  This is the new GCC version to install.
VERSION=10.2.0
#  These are the languages the new compiler should support.
LANG=c,c++,fortran
#  For any computer with less than 2GB of memory.
#if [ -f /etc/dphys-swapfile ]; then
#  sudo sed -i 's/^CONF_SWAPSIZE=[0-9]*$/CONF_SWAPSIZE=1024/' /etc/dphys-swapfile
#  sudo /etc/init.d/dphys-swapfile restart
#fi
if [ -d gcc-$VERSION ]; then
  cd gcc-$VERSION
  rm -rf obj
else
  echo "Download source tree ..."
  wget ftp://ftp.fu-berlin.de/unix/languages/gcc/releases/gcc-$VERSION/gcc-$VERSION.tar.xz
  echo "Uncompress source tree ..."
  tar xf gcc-$VERSION.tar.xz
  rm -f gcc-$VERSION.tar.xz
  cd gcc-$VERSION
  contrib/download_prerequisites
fi
mkdir -p obj
cd obj
#  Now run the ./configure which must be checked/edited beforehand.
#  Uncomment the sections below depending on your platform.  You may build
#  on a Pi3 for a target Pi Zero by uncommenting the Pi Zero section.
#  To alter the target directory set --prefix=<dir>
#  For a very quick build try: --disable-bootstrap
# x86_64
#../configure --disable-multilib --enable-languages=$LANG
# AArch64 Pi4 running Raspberry Pi OS 64-bit
../configure --enable-languages=$LANG --with-cpu=cortex-a72
# Pi Zero
#../configure --enable-languages=$LANG --with-cpu=arm1176jzf-s \
#  --with-fpu=vfp --with-float=hard --build=arm-linux-gnueabihf \
#  --host=arm-linux-gnueabihf --target=arm-linux-gnueabihf
# Pi3+, Pi3, Pi4 in 32-bit mode
#../configure --enable-languages=$LANG --with-cpu=cortex-a53 \
#  --with-fpu=neon-fp-armv8 --with-float=hard --build=arm-linux-gnueabihf \
# Old Pi2
#../configure --enable-languages=$LANG --with-cpu=cortex-a7 \
#  --with-fpu=neon-vfpv4 --with-float=hard --build=arm-linux-gnueabihf \
#  Now build GCC which will take a long time.  This could range from
#  3.5 hours on a 4GB Pi4 up to about 50 hours on a Pi Zero.  It can be
#  left to complete overnight (or over the weekend for a Pi Zero :-)
#  The most likely causes of failure are lack of disk space, lack of
#  swap space or memory, or the wrong configure section uncommented.
#  The new compiler is placed in /usr/local/bin, the existing compiler remains
#  in /usr/bin and may be used by giving its version gcc-6 (say).
if make -j `nproc`
then
  echo
  read -p "Do you wish to install the new GCC (y/n)? " yn
  case $yn in
   [Yy]* ) sudo make install ;;
     * ) exit ;;
  esac
fi
knute
Re: gcc 10+?
Thu Dec 10, 2020 4:11 pm
Thanks for that!
One other question. Is there any advantage of recompiling 10 with 10?
jahboater
Re: gcc 10+?
Thu Dec 10, 2020 4:32 pm
That's what happens anyway as the final part of the normal build (one of the reasons it takes so long).
knute
Re: gcc 10+?
Fri Dec 11, 2020 12:24 am
One more question, I've compiled it but how do I install it somewhere?
jahboater
Re: gcc 10+?
Fri Dec 11, 2020 2:09 am
In the same directory that you typed "make", type:
sudo make install
then, type "gcc -v" to confirm the version of the new compiler.
knute
Re: gcc 10+?
Fri Dec 11, 2020 3:35 am
You flipped the script on me :-). I ran the original script from ~/bin. It created a directory gcc-10.2.0. There was no Makefile in ~/bin so I went to ~/bin/gcc-10.2.0/obj and entered sudo make install. I think it is working like it is supposed to. It needed a restart of the terminal.
Thanks again.
graham.reeds
Re: gcc 10+?
Mon Mar 29, 2021 10:03 am
This (as does the previous thread) fails for me. I have the latest RaspiOS with arm_64bit enabled. Does that matters?
Re: gcc 10+?
Mon Mar 29, 2021 10:16 am
FYI arm_64bit changes the Kernel to 64bit, but Userland is still 32bit.
graham.reeds
Re: gcc 10+?
Mon Mar 29, 2021 3:28 pm
Is there any way of getting a 64bit tool chain?
Heater
Re: gcc 10+?
Mon Mar 29, 2021 3:58 pm
I have been using 64 bit GCC and Rust by using the nspawn 64 bit container environment:
pi@heater-pi:~ $ sudo apt-get install raspbian-nspawn-64
pi@heater-pi:~ $ ds64-shell
pi@debian-buster-64:~ $ Connected to machine debian-buster-64. Press ^] three times within 1s to exit session.
pi@debian-buster-64:~ $ sudo apt-get install gcc
pi@debian-buster-64:~ $ gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/aarch64-linux-gnu/8/lto-wrapper
Target: aarch64-linux-gnu
Thread model: posix
gcc version 8.3.0 (Debian 8.3.0-6)
$ gcc hello.c
pi@debian-buster-64:~ $ file ./a.out
./a.out: ELF 64-bit LSB pie executable, ARM aarch64, version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux-aarch64.so.1, for GNU/Linux 3.7.0, BuildID[sha1]=ecb9ffc2d6736670604025bd67d48b6e08c2a8ab, not stripped
jahboater
Re: gcc 10+?
Mon Mar 29, 2021 6:11 pm
I use the 64-bit version of Raspberry Pi OS and build GCC with this simple configure line:
../configure --enable-languages=c,d,c++,fortran --with-cpu=cortex-a72
Then I get the full 64-bit tool chain and compiler for the Pi4.
Return to “C/C++”
