Page 1 of 1
[quick-guide] CAN bus on raspberry pi with MCP2515 and Arduino
Posted: Fri Dec 25, 2020 4:08 am
by Sundar19
I am seeing many people who want to establish CAN communication between Raspberry Pi and Arduino and that made me post the solution here .
VERY IMPORTANT NOTE:
1.Most of my steps are from viewtopic.php?t=141052 , Please check that out before coming here
2. You should not give 5V to MCP2515 at it may damage your Raspberry pi GPIOs , So there is a step for giving 3.3V to MCP2515(CAN controller) and 5V for TJA1050(CAN transceiver) , That soldering step is available in viewtopic.php?t=141052 , Please do that first and come here or else your raspberry pi will be damaged.
[OR]
You can use a logic level shifter similar to this https://learn.sparkfun.com/tutorials/bi ... -guide/all , Please share if you do so!!
Connections:
RPi to CAN module
3.3V (Physical Pin 1) <==> Vcc CAN module
5V (Physical Pin 2) <==> soldered capacitor behind CAN module
GND (Physical Pin 6) <==> GND CAN module
CE0 (Physical Pin 24) <==> CS CAN module
MISO (Physical Pin 21) <==> SO CAN module
MOSI (Physical Pin 19) <==> SI CAN module
SCLK (Physical Pin 23) <==> SCK CAN module
GPIO-BCM-12 (Physical Pin 32) <==> INT CAN module
UNO to CAN module
5V <==> Vcc
GND <==> GND
Pin 13 <==> SCK
Pin 12 <==> SO
Pin 11 <==> SI
Pin 10 <==> CS
Image at bottom of post for connections
Do the following :
1.Open the configurations file
sudo nano /boot/config.txt
2.Add these lines
dtparam=spi=on
dtoverlay=mcp2515-can0,oscillator=8000000,interrupt=12
dtoverlay=spi-bcm2835-overlay
(if dtparam=spi=on is uncommented and existing , please leave it)
3.
sudo apt-get install can-utils
4.
sudo reboot
5.The following should throw similar output
ls /sys/bus/spi/devices/spi0.0
driver  modalias  net  of_node  power  statistics  subsystem  uevent
ls /sys/bus/spi/devices/spi0.0/net
can0
ls /sys/bus/spi/devices/spi0.0/net/can0/
addr_assign_type    dev_id             link_mode         proto_down
address             dev_port           mtu               queues
addr_len            dormant            name_assign_type  speed
broadcast           duplex             netdev_group      statistics
carrier             flags              operstate         subsystem
carrier_changes     gro_flush_timeout  phys_port_id      tx_queue_len
carrier_down_count  ifalias            phys_port_name    type
carrier_up_count    ifindex            phys_switch_id    uevent
device              iflink             power
6.Setup the CAN interface
sudo ip link set can0 up type can bitrate 500000
(NOTE: to down the bus
sudo ip link set can0 down )
7.
sudo ifconfig
can0: flags=193<UP,RUNNING,NOARP>  mtu 16
        unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00  txqueuelen 10  (UNSPEC)
        RX packets 1651057  bytes 717672 (700.8 KiB)
        RX errors 1707  dropped 39  overruns 0  frame 1707
        TX packets 23  bytes 141 (141.0 B)
8. To send and receive data we can use Python for RPi and C for Arduino (In RPi we can use can-utils for testing)
LIBRARIES:
Arduino C CAN : https://github.com/Seeed-Studio/Seeed_A ... N/tree/old
Install the above library in your arduino IDE
Raspberry Pi Python CAN : https://python-can.readthedocs.io/en/master/
 pip3 install python-can
1.Run python3 can_basic_send.py in RPi and CAN_RX.ino in Uno
2.Run python3 can_basic_recv.py in RPi and CAN_TX.ino in Uno
Bitrate of RPI & UNO is 500000(set in program)
Clock frequency of RPI & UNO is 8Mhz(set in config file and program)
Remove unwanted LED stuff from arduino code if you want!!
can_basic_recv.py OUTPUT:
Timestamp: 1607220936.314801        ID: 0043    S                DLC:  8    01 02 03 04 05 06 07 08     Channel: can0
Timestamp: 1607220937.314749        ID: 0043    S                DLC:  8    01 02 03 04 05 06 07 08     Channel: can0
Timestamp: 1607220937.315004        ID: 0043    S                DLC:  8    01 02 03 04 05 06 07 08     Channel: can0
Timestamp: 1607220937.315288        ID: 0043    S                DLC:  8    01 02 03 04 05 06 07 08     Channel: can0
Timestamp: 1607220938.315610        ID: 0043    S                DLC:  8    01 02 03 04 05 06 07 08     Channel: can0
CAN_RX.ino OUTPUT:
Data from ID: 0x7EE
0	1	3	1	4	1
Data from ID: 0x7EE
0	1	3	1	4	1
Data from ID: 0x7EE
0	1	3	1	4	1
Data from ID: 0x7EE
0	1	3	1	4	1
Data from ID: 0x7EE
0	1	3	1	4	1
In Arduino Run
CAN_RX.ino
#include <SPI.h>
#include "mcp_can.h"
const int spiCSPin = 10;
const int ledPin = 2;
boolean ledON = 1;
MCP_CAN CAN(spiCSPin);
void setup()
    Serial.begin(115200);
    pinMode(ledPin,OUTPUT);
    while (CAN_OK != CAN.begin(CAN_500KBPS,MCP_8MHz))
        Serial.println("CAN BUS Init Failed");
        delay(100);
    Serial.println("CAN BUS  Init OK!");
void loop()
    unsigned char len = 0;
    unsigned char buf[8];
    if(CAN_MSGAVAIL == CAN.checkReceive())
        CAN.readMsgBuf(&len, buf);
        unsigned long canId = CAN.getCanId();
        Serial.println("-----------------------------");
        Serial.print("Data from ID: 0x");
        Serial.println(canId, HEX);
        for(int i = 0; i<len; i++)
            Serial.print(buf[i]);
            Serial.print("\t");
            if(ledON && i==0)
                digitalWrite(ledPin, buf[i]);
                ledON = 0;
                delay(500);
            else if((!(ledON)) && i==4)
                ledON = 1;
        Serial.println();
In Raspberry Pi Run
can-basic-send.py
import time
import can
bustype = 'socketcan'
channel = 'can0'
bus = can.interface.Bus(channel=channel, bustype=bustype,bitrate=500000)
msg = can.Message(arbitration_id=0xc0ffee, data=[0, 1, 3, 1, 4, 1], is_extended_id=False)
while True:
	bus.send(msg)
	time.sleep(1)
In Arduino Run
CAN_TX.ino
#include <SPI.h>
#include <mcp_can.h>
int ledHIGH    = 1;
int ledLOW     = 0;
void setup()
        Serial.println("CAN BUS init Failed");
        delay(100);
    Serial.println("CAN BUS Shield Init OK!");
unsigned char stmp[8] = {1, 2, 3, 4, 5, 6, 7, 8};
void loop()
  Serial.println("In loop");
  CAN.sendMsgBuf(0x43, 0, 8, stmp);
  delay(1000);
In Raspberry Pi Run
can-basic-recv.py
import can
import time
can_interface = 'can0'
bus = can.interface.Bus(can_interface, bustype='socketcan',bitrate=500000)
while True:
	message = bus.recv()
	print(message)
#for msg in bus:
	#print(msg.data)
