nfstoney
CM4 can't change boot EEPROM
Wed Jan 20, 2021 2:35 pm
Hello
I have a problem to change the content of the boot EEPOM on my CM4.
I have the latest raspian (2021-01-11-raspios-buster-armhf.img) on my uSDCard.
sudo CM4_ENABLE_RPI_EEPROM_UPDATE=1 -E rpi-eeprom-update
BCM2711 detected
VL805 firmware in bootloader EEPROM
BOOTLOADER: up-to-date
CURRENT: Fr Okt  2 07:44:17 UTC 2020 (1601624657)
 LATEST: Do Sep  3 12:11:43 UTC 2020 (1599135103)
 FW DIR: /lib/firmware/raspberrypi/bootloader/default
VL805: up-to-date
CURRENT:
 LATEST:
From other thread (viewtopic.php?t=293311) I run
sudo CM4_ENABLE_RPI_EEPROM_UPDATE=1 -E rpi-eeprom-config --edit
to edit the file /tmp/tmpxxxxxx/boot.conf
and safe it with Ctrl+O and leave with Ctrl+X
Then the answer of this step
Updating bootloader EEPROM
 image: /lib/firmware/raspberrypi/bootloader/default/pieeprom-2020-09-03.bin
config_src: /boot/pieeprom.upd
config: /tmp/tmp3vi5ox47/boot.conf
[all]
BOOT_UART=0
WAKE_ON_GPIO=0
POWER_OFF_ON_HALT=1
DISABLE_HDMI=0
BOOT_ORDER=0xf51
*** To cancel this update run 'sudo rpi-eeprom-update -r' ***
BCM2711 detected
*** INSTALLING /tmp/tmp3vi5ox47/pieeprom.upd  ***
BOOTFS /boot
EEPROM update pending. Please reboot to apply the update.
Now, there are three new files in /boot
- pieeeprom.sig
- pieeprom.upd
- recovery.bin
Now, I rebbot the system like guided above
sudo reboot
The system reboots and I have a look to the eeprom-content
vcgencmd bootloader_config
the content doesn't change.
If I run
the content is as I want it to be.
Where do I make the mistake so that the eeprom is not written?
Many thanks for any hints.
nfstoney
timg236
Re: CM4 can't change boot EEPROM
Wed Jan 20, 2021 2:40 pm
You can't use rpi-update-eeprom on CM4, you need to use rpiboot instead.
https://www.raspberrypi.org/documentati ... lashing.md
If you look in the recovery directory there's a simple shell-script to automate the process of updating the image + signature after editing the boot config.
cleverca22
Wed Jan 20, 2021 3:02 pm
- pieeeprom.sig
- pieeprom.upd
- recovery.bin
i believe recovery.bin is disabled on the CM4, so you either need to use rpiboot as timg236 said, or use the deprecated flashrom route
nfstoney
Wed Jan 20, 2021 4:15 pm
Many thanks for this hint. It works.
nfstoney
Wed Jan 20, 2021 4:16 pm
- pieeeprom.sig
- pieeprom.upd
- recovery.bin
Please tell me more about "the deprecated flashrom route".
cleverca22
Wed Jan 20, 2021 4:36 pm
https://github.com/raspberrypi/rpi-eepr ... update#L31
https://github.com/raspberrypi/rpi-eepr ... pdate#L239
i think you just add USE_FLASHROM=1 to the command
nfstoney
Fri Jan 22, 2021 10:10 am
Thanks for the hint. i am a few steps further but unfortunately not yet completely successful.
I changed the boot.conf and generate a new pieeprom.bin with
sudo ./update-pieeprom.sh
Then I want to write the EEPROM with
sudo CM4_ENABLE_RPI_EEPROM_UPDATE=1 USE_FLASHROM=1 rpi-eeprom-update -f /home/pi/usbboot/recovery/pieeprom.bin
Following by the return
BCM2711 detected
*** INSTALLING /home/pi/usbboot/recovery/pieeprom.bin  ***
WARNING: USE_FLASHROM is deprecated.
Applying bootloader update /home/pi/usbboot/recovery/pieeprom.bin
flashrom  on Linux 5.4.83-v7l+ (armv7l)
flashrom is free software, get the source code at https://flashrom.org
Using clock_gettime for delay loops (clk_id: 1, resolution: 1ns).
Found Winbond flash chip "W25X40" (512 kB, SPI) on linux_spi.
Reading old flash chip contents... done.
Erasing and writing flash chip...
Warning: Chip content is identical to the requested image.
Erase/write done.
The note "Warning: Chip content is identical to the requested image." I think ist strange. The pieeprom.bin is really not the same as in the EEPROM.
The note "EEPROM update pending. Please reboot to apply the update." is also strange because i think this isn't necessary.
I wrote some extra code for readout the EEPROM with the flashrom-command, but the EEPROM content doesn't change.
Can someone see a mistake or more with the description above?
timg236
Fri Jan 22, 2021 10:35 am
Presumably flashrom is correct it's just doing SPI reads.
btw. The USE_FLASHROM option is pending removal from rpi-eeprom-update but there's nothing to top anyone using the code as reference to create a simple system / init script which loads the appropriate DT overlay to configure the GPIOs and running flashrom directly.
cleverca22
Fri Jan 22, 2021 10:40 am
why remove it entirely? too many conflicts against the other spi stuff and not wanting to deal with that?
timg236
Fri Jan 22, 2021 11:43 am
Yes, there are too many cases where an arbitrary system configuration won't be in a suitable state to run flashrom or vl805 directly and will lockup hang. This makes it unsuitable for use as a generic automatic update.
Removing this simplifies the script and dependencies.
rpi-eeprom-config & rpi-eeprom-update already provide all the plumbing to generate pieeprom.bin files so if anyone wants to use flashrom then all they need to do is re-use the existing tools and then call flashrom at a suitable point (after calling dtoverlay etc)
nfstoney
Fri Jan 22, 2021 1:31 pm
It seems to me no longer advisable to pursue my goal of wanting to write the EEPROM manually. In the future, I will have to be satisfied with the available official tools.
How is it intended to manipulate the bootloader EEPROM in a setup where is no physical access to the PI(CM4)?
timg236
Fri Jan 22, 2021 9:17 pm
For industrial applications we recommend not changing it making the EEPROM read only via the jumper
Return to “Compute Module”
