clickonben
Raspberry Pi Pico inputs floating
Sun Jan 24, 2021 3:55 pm
I am working my way through the Get Started With Micropython on Raspberry Pi Pico book and I am currently on the section dealing with inputs. It says that each of the GPIO pins has a resistor that by default is in pull-down mode. However, when I run the below code with nothing connected to any pins, it flips between printing 1 and 0, suggesting that the input is floating. It does not seem to matter which pin I try they all appear to be floating.
import machine
button = machine.Pin(0, machine.Pin.IN)
while True:
    print(button.value())
Does anyone know what I am missing? Do I need to enable the pull-down resistors somehow?
hippy
Re: Raspberry Pi Pico inputs floating
Sun Jan 24, 2021 4:20 pm
From Page 13 of the "Pico Python SDK" -
p2 = Pin(2, Pin.IN, Pin.PULL_UP)
There's also a Pin.PULL_DOWN constant as well.
There is no Pin.PULL_NONE so I'm not sure if there's a default and/or permanent pull which can't be disabled. Couldn't find any info on that when skimming through the datasheets.
My pins don't seem to float; consistently read 0 with no pull specified or Pin.PULL_DOWN, 1 when Pin.PULL_UP.
Are you sitting under a florescent light or other EMI source ?
clickonben
Sun Jan 24, 2021 4:28 pm
Thanks, that works.
The official getting started book published by Raspberry Pi Press says that the default is pull down and the code examples are all of the form:
Pin(2, Pin.IN)
Which simply omits the parameter to specify whether it is pull down or pull up. The net result is that it seems to float so I think the book must be wrong.
artag
Sun Jan 24, 2021 6:04 pm
I understood the manual to say that the processor resets with all pulldowns active. However, when the code related to pin configuration runs, it will set a new state on the pin. The pin mode is the list of all the things you want to do to it, so if you don't set pull up or pull down then it changes to floating.at that time.
This is also the answer to the question of PULL_NONE : it's just the absence of the other things. If you want to make it explicit, define it to zero.
To put it another way, the values you put into pin mode REPLACE rather than supplement the previous values.
You might think this is silly as the pulldown is irrelevant if it isn't a default in the code. But it's important if you're connecting hardware - it tells you what the pin will do in the time between power coming on and your code running. It's not very long but if it turns on the laser in your engraver for a moment every time you power the system up, it's important.
I would hope that the micro also pulls down the pins while reset is being asserted, not just when it's released. Otherwise it's still necessary to fit an external pulldown resistor in order to be sure it's safe for that period, too. Most devices tend to float their outputs at power up.
Hashdef
Mon Jan 25, 2021 11:36 am
I too found that the default behaviour does not seem to be as described in "Get Started With Micropython on Raspberry Pi Pico" book. When continuously reading an input pin the value randomly fluctuated between 1 and 0. It was fixed by explicitly specifying PULL_DOWN.
button = machine.Pin(16, machine.Pin.IN, machine.Pin.PULL_DOWN)
Superkris
Fri Jan 29, 2021 9:41 pm
I think i have the same problem. As i have no experience with Phyton i thought i'd just buy the book and work trough it for a basic understanding of how to program with MicroPhyton. I guess its a book that's mostly for children so it does make me feel a little bit stupid but i guess its fine to learn the basics.
So once you get to page 54 they explain that when you use the argument "machine.Pin.In" it defaults to a input with a pull down resistor. I got very random readings and feared i might have damaged the input with 5V logic. Other pins gave the same problem, and replacing the switch didnt either. Adding a pulldown however fixed it.
Luckily i have some Arduino experience so i understood what was happening. I was also lucky enough to find this topic because a quick google search did not help me in finding the right arguments. Hashdef's code works fine. Thank you dude!
I'm wondering what caused this. Obviously there was some time between the writing of the book, and the first Pico to be sold. Maybe the machine library changed, or something else was changed in code. In the book however its stated that for all experiments its not needed to activate a pull down resistor, and this seems to be very wrong!
Fri Jan 29, 2021 10:16 pm
I'm not sure how the mistake crept in, just one of those things that occasionally escape. Considering we have produced over 1000 pages of docs and this book, there's bound to be a few teething issues. And you are right, the book had to go to printing well before the actual release, and lots of stuff was changing right up to that point.
Superkris
Fri Jan 29, 2021 10:47 pm
Many thanks for your reply. Does this mean you confirm that by design the pins are floating when only "Pin.IN" is used?
Either that needs to be fixed in the book, or there is a error in the library's im using.
Sat Jan 30, 2021 11:55 am
The book will be updated for its next printing I believe. I guess the PDF will be changed more quickly.
Superkris
Sat Jan 30, 2021 8:42 pm
Thanks again for you reply. I really love the concept of the RP2040 and microphyton. I really hope the community for this microcontroller grows to similar size as the Atmel Arduino's. At this point its still hard to make a fair comparison, but i think the potential is huge!
SilentRhetoric
Sun Jan 31, 2021 10:23 pm
Thanks, that works.
Pin(2, Pin.IN)
I just started working through the book today and found other examples, too. In the traffic light with pedestrian button example, the given code will throw a NameError because “button” isn’t defined as a global variable inside and outside of the function used by the _thread. Had I not some experience with Python and help from the Python Discord (no response in the Raspberry Pie Discord, sadly), I would have been stuck.
I had a great time with the original Raspberry Pi book, but this Pico book has been more frustration than fun, so far.
Mon Feb 01, 2021 10:30 am
Thanks, that works.
Pin(2, Pin.IN)
Can you post any issue you find with the book in the github pico-feedback issue tracker please. We'll get them fixed as soon as possible.
https://github.com/raspberrypi/pico-feedback/issues
Might be worth checking to see if it already been reported first.
philkingmagpi
Mon Feb 01, 2021 5:00 pm
Sorry about this. We have since found that adding a small delay to the function's while loop will prevent this intermittent error appearing:
def button_reader_thread():
    global button_pressed
    while True:
        if button.value() == 1:
            button_pressed = True
        utime.sleep(0.01)
_thread.start_new_thread(button_reader_thread, ())
scruss
Mon Feb 01, 2021 6:01 pm
There is; since the Python SDK document is a potted summary of available commands, you have to go to the MicroPython docs for machine.Pin()
pull specifies if the pin has a (weak) pull resistor attached, and can be one of:
None - No pull up or down resistor.
Pin.PULL_UP - Pull up resistor enabled.
Pin.PULL_DOWN - Pull down resistor enabled.
So pull=None should do it, in the rare occasions you'd want it.
Explicitly setting pull=Pin.PULL_UP|Pin.PULL_DOWN is probably a good idea to avoid the floaties.
Pronouns: he/him
Superkris
Tue Feb 02, 2021 2:24 pm
jamesh wrote: The book will be updated for its next printing I believe. I guess the PDF will be changed more quickly.
Today i received a mail from the store that you/they will be providing new books free of charge.
Thank you very much for this great support. Keep up the good work!
Tue Feb 02, 2021 4:04 pm
Excellent news!
DirkS
Tue Feb 02, 2021 4:33 pm
To add to that: the PDF version as available through the Pi Bookshelf (and manual download) has had a couple of updates over the last week or so. Don't know exactly what changed though.
fabmenezes
Mon Apr 19, 2021 11:58 am
An errata was published for the first edition of the book Get Started With MicroPython on Raspberry Pi Pico. Download the new version of the book.
"Get Started with MicroPython on
Raspberry Pi Pico
Errata
Chapters 4–7
We have identified an error in some code examples in the first print run of Get Started with MicroPython on Raspberry Pi Pico. We're very sorry for this mistake, and we have corrected it in the PDF edition of the book. We have withdrawn the incorrect print edition from sale and asked our distributors to do the same, and a new, updated, edition is being printed. Customers who have purchased the incorrect edition of the book from the Raspberry Pi Press store or from a Raspberry Pi Approved Reseller will receive a copy of the updated edition free of charge from their retailer.
The error means that the projects in chapters 4 to 7 of the book, which use a digital input device (either a push-button or PIR sensor), will give erratic results if readers copy the code examples as they appear.
This is because many of these code examples are missing a necessary parameter. (If you're already familiar with Python, you'll recognise that this parameter is needed to pull down the pin’s resistor manually.)
To avoid the problem, you need to add the missing parameter machine.Pin.PULL_DOWN to each line of code that sets up the pin input with the code machine.Pin.IN. Every time a code example includes machine.Pin.IN, you need to add to it so that it reads machine.Pin.IN, machine.Pin.PULL_DOWN.
For example, on page 54:
button = machine.Pin(14, machine.Pin.IN)
…should change to:
button = machine.Pin(14, machine.Pin.IN, machine.Pin.PULL_DOWN)
And on page 82:
sensor_pir = machine.Pin(28, machine.Pin.IN)
…should change to:
sensor_pir = machine.Pin(28, machine.Pin.IN, machine.Pin.PULL_DOWN)
Other lines containing ‘machine.Pin.IN’ should be changed in a similar manner.
This is because Raspberry Pi Pico’s GPIO pin resistors aren’t automatically pulled down by default, as stated in the book.
Further explanation
When Pico powers up, MicroPython does not touch any GPIO state of the hardware, so the pins should be in whatever state they started in.
If the user constructs a Pin object by specifying the mode (eg IN, OUT), but does not specify any pull, then MicroPython defaults to setting the pin to "no pull" mode (i.e. disables pull-up and pull-down).
If the user constructs a Pin object by specifying the mode and the pull, then MicroPython configures the pin as requested."
Return to “General”
