dherrenvt
sudo bug? Update plans!
Fri Jan 29, 2021 5:00 pm
Greetings-
Like many I learned today about the apparently very old bug in sudo allowing any user to gain root status. Any plan on when the underlying OS will be updated? I appears the latest version on Raspberry PI OS is 1.8.27 (from Debian) and is vulnerable.
B.Goode
Re: sudo bug? Update plans!
Fri Jan 29, 2021 5:06 pm
Greetings-
Any citation or source for what you and many learnt today?
Fri Jan 29, 2021 5:10 pm
https://www.debian.org/security/2021/dsa-4839
Should flow through to RaspiOS Buster in the very near future.
It's already fixed in Mint V20 and Ubuntu Groovy Gorilla which I run in a VirtualBox.
jdb
Fri Jan 29, 2021 5:12 pm
It's already in apt. There is no version number change of the base program, but the package plus debian patches includes the fix.
sudo/stable,now 1.8.27-1+deb10u3 arm64 [installed]
Provide limited super user privileges to specific users
Running apt update && apt upgrade will pull in the fix.
Rockets are loud.
https://astro-pi.org
B.Goode
Fri Jan 29, 2021 5:17 pm
I am seeing, on an RPi2 running RasPiOS Buster -
pi@raspberrypi:~/cov19 $ apt-cache policy sudo
sudo:
  Installed: 1.8.27-1+deb10u3
  Candidate: 1.8.27-1+deb10u3
  Version table:
 *** 1.8.27-1+deb10u3 500
        500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages
        100 /var/lib/dpkg/status
Seems all is well... Nothing to see here... ?
HappyTux
Fri Jan 29, 2021 6:00 pm
sudo passwd root to set the root password and be done with it. Who would have thought all these years of going against the trend of lower security would be good for me. As no one is ever going to convince me that having to get two passwords to take over a machine is less secure than only one. As some have tried to with their black is white arguments for it, in favour of the reduced security sudo method. Theirs is just plain laziness on having to remember two passwords...
pidd
Fri Jan 29, 2021 6:34 pm
Perhaps that may be true in your circumstances but not everybody's.
I probably have over 100 passwords, I probably use sudo over 50 times a day (many more on some days), I have a strong password for Pi (around about 20 characters).
Cracking two 10 character passwords is far easier than cracking one 20 character password.
wh7qq
Sat Jan 30, 2021 7:47 pm
Isn't it nice that Linux lets you have it either way? We don't (can't) lock our house when away, even on vacation...no need after 21 years...so it seems a good idea to utilize the password requirement.
debuti
Sat Jan 30, 2021 10:11 pm
Last login: Sat Jan 30 21:31:12 2021 from 192.168.1.4
debuti@dwnldr:~ $ apt-get changelog sudo
Get:1 store: sudo 1.8.27-1+deb10u3 Changelog
Fetched 46.6 kB in 0s (0 B/s)
sudo (1.8.27-1+deb10u3) buster-security; urgency=high
  * Non-maintainer upload by the Security Team.
  * Sanity check size when converting the first record to TS_LOCKEXCL
  * Heap-based buffer overflow (CVE-2021-3156)
    - Reset valid_flags to MODE_NONINTERACTIVE for sudoedit
    - Add sudoedit flag checks in plugin that are consistent with front-end
    - Fix potential buffer overflow when unescaping backslashes in user_args
    - Fix the memset offset when converting a v1 timestamp to TS_LOCKEXCL
    - Don't assume that argv is allocated as a single flat buffer
 -- Salvatore Bonaccorso <carnil@debian.org>  Wed, 20 Jan 2021 13:26:17 +0100
