#include <stdio.h>
#include "pico/stdlib.h"
#include "hardware/gpio.h"
#include "hardware/clocks.h"
#include "hardware/pwm.h"
typedef uint16_t u16;
typedef uint32_t u32;
int main()
// set your desired inputs here
const u32 f_pwm = 440; // frequency we want to generate
const u16 duty = 60; // duty cycle, in percent
gpio_set_function(0, GPIO_FUNC_PWM); // Tell GPIO 0 it is allocated to the PWM
uint slice_num = pwm_gpio_to_slice_num(0); // get PWM slice for GPIO 0 (it's slice 0)
// set frequency
// determine top given Hz - assumes free-running counter rather than phase-correct
u32 f_sys = clock_get_hz(clk_sys); // typically 125'000'000 Hz
float divider = f_sys / 1'000'000UL; // let's arbitrarily choose to run pwm clock at 1MHz
pwm_set_clkdiv(slice_num, divider); // pwm clock should now be running at 1MHz
u32 top = 1'000'000UL/f_pwm -1; // TOP is u16 has a max of 65535, being 65536 cycles
pwm_set_wrap(slice_num, top);
// set duty cycle
u16 level = (top+1) * duty / 100 -1; // calculate channel level from given duty cycle in %
pwm_set_chan_level(slice_num, 0, level);
pwm_set_enabled(slice_num, true); // let's go!
for(;;);
return 0;
I see in the documentation that it's possible to double-buffer the duty cycle, too. I plan to exploit that capability. I'm impressed with the Pico's level of documentation.
Actually, you know what would be good? A Pico cookbook.
