gregwa
I2C.start() returns an error
Thu Feb 11, 2021 7:22 pm
When using i2c.start() I get an error...
MicroPython v1.14 on 2021-02-05; Raspberry Pi Pico with RP2040
Type "help()" for more information.
>>> from machine import I2C
>>> i2c = I2C(0)
>>> i2c.scan()
[57, 119]
>>> i2c.start()
  File "<stdin>", line 1, in <module>
OSError: I2C operation not supported
Is this simply not included in the current version of MicroPython and will be included in the future?
I seems that it is supposed to be implemented...
>>> dir(I2C)
['__class__', '__name__', 'readinto', 'start', 'stop', 'write', '__bases__', '__dict__', 'init', 'readfrom', 'readfrom_into', 'readfrom_mem', 'readfrom_mem_into', 'scan', 'writeto', 'writeto_mem', 'writevto']
espresso1736
Re: I2C.start() returns an error
Fri Feb 12, 2021 9:59 pm
Not sure, but I think you may need to specify the SCL and SDA pins, either in the construction, or via a call to init().
fivdi
Sat Feb 13, 2021 7:36 am
The MicroPython I2C documentation lists several Primitive I2C operations which are only available on the machine.SoftI2C class and not on the machine.I2C class. I2C.start() is one of these operations.
For further information see GitHub issue https://github.com/micropython/micropython/issues/6856.
https://github.com/fivdi
gregwa
Sat Feb 13, 2021 10:56 am
Thank you for the link and the explanation.
fivdi
Sat Feb 13, 2021 11:00 am
You're welcome :)
Return to “MicroPython”
